Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Motor grind Loud sound and smell on occasion. Started as just short sound as turned off, +/- 2 seconds. Now does it on star up unless I tilt the unit back. Ideas? Is it worth fixing? ns
  • 2 more comments
  • normsch May 12, 2008
    Subllimegreen. Thank you. I am unaware that the floor scrubbers with the circular brushes (Floormate H3000) even have a belt. The sound is a really awful scrunching sound, more like a moter or impeller sound as opposed to a screeching belt. I found that if I tilt the machine forward a bit when turning it on there's no noise and it runs fine. I should also mention that all of the other machine functions are working. I will not be able to get back to it until this evening. I'm sorry if I was not detailed enough in my original post. ns
  • 1crazyhouse Jan 25, 2009
    We also have the grinding motor issue. I took the housing off and found small pieces of a scalloped plastic "washer/o-ring" components around the motor. This unit is 3.5 years old and is used 2-3X per week. Is it time to say good bye or is it serviceable?
  • Anonymous Feb 11, 2009
    motor makes a loun grinding sound
  • Anonymous Mar 23, 2014
    It sounds just fine until you tilt it then it make a loud grinding sound
  • 65 Answers
Try checking the belt, that is probably the smell,
might need replacing
Posted on May 12, 2008
My dc24 has started making a loud noise which seems to be coming from the ball. I switched its off when it started to smell of a slight burning or warm smell. Vacuum is only 2.5 years old, filters are...
Sounds as if there is something stuck in the vacuum causing the beater bar to stop turning while the belt continues to turn giving off the burning smell.
Oct 27, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
Vacuum turned off started smelling and got hot but only for 2 to 3 minutes then turned off
Hi There, 2 to 3 minutes is too short for a blockage in my opinion. I would suggest you have a burnt out motor. Did it make any kind of uneven sound or popping sound? If yes then you will need to replace the motor. There are a couple of good videos on youtube to help you out if you are suitably qualified or skilled. This is a pretty tricky repair though I would give it a 7/10 for difficulty.
May 31, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Burning smell loud grinding noise when tilted
Hi there SmartAlec from NelsonVacuums.com.au here. The rattle is the clutch engaging. It can happen for a couple of reasons. The best case for you is if there is something caught in the brush roller that you can simply remove. The next best is that the end caps of the brush are full of junk that you will be able to remove. Its not easy getting the brush out to clean there but it can be done.
If the brush spins in your hand easily when the brush is removed then it is the clutch itself. THe main roller often melts which is caused when the tension on the belt gets to high thus creating too much heat. THis can be resolved only with a new clutch.
Hope this helps, if you have more questions dont hesitate to reply or if you need parts just visit
NelsonVacuums.com.au.
Happy Vacuuming :)
Apr 11, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me...
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
When I turned on the vacuum it started to smell
the vacuum is either shorting or the motor or brush assembly is rubbing something.
Jul 31, 2009 | Rainbow Vacuums
Motor is getting loud and smells like is burning
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=832949
Generic problem for all Vacuums
Posted by lchill on July 25, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am not sure what type of vacuum, make or model # it is but if your motor is getting loud and it smells like it is burning, it could be 2 things, either you have a broken fan blade or your motor is on it’s last legs and is burning up and would be in need of a new fan and motor replacement. Please feel free t contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 25, 2008 | Kenmore Progressive Bagless Upright with...
Eureka 5197 self propelled bagless upright
Did you check the brush roll when you changed the belt? The smell of rubber would inducate a belt slipping. So if the brush roll (part #61308-2)isn't turning, the belt would get hot and would be slipping. If the motor sounds real loud, then you could have a bad motor(part #60775-4).
Feb 14, 2008 | Eureka 5197AT Upright Vacuum
Removing obstruction from vacuum motor
Most Eureka's, there are 2 or 3 screws on the top to remove, then the top cover will come off. If no screws on top. then they are on the bottom. After the top is off, the belt and brush are right there in the open. To get to the motor, that off the 2 screws on the clamp on wach side of the motor, screws that are around the motor housing and then the motor cover should pull off. If the smell is electrical, if could be a bad motor, which sells for around $75 to $90. If the smell is more like rubber, then look at the belt and brush roll. If you need more info, get the model # off of the tag.
Feb 12, 2008 | Kenmore Progressive Bagless Upright with...
Burning smell and smoke
When you turn it on....is the belt turning the brushes? Something may be caught causing the brushes to stick and the belt to just grind the brush assembly.
Jan 03, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
133 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
