Question about Family Care HM1555 Humidifier
Is there anyway I can get Emancipated at the age of 15?
  • 6,784 Answers
No. You can only exercise that option at age 16 and not 15. You have one more year to go. Check your state law literature to inquire about special situation procedures if needed.
Posted on Sep 04, 2010
Water panel not getting wet
Is there 24 volts at the solenoid valve when blower motor is running? If there is water at the inlet side of valve then either the solenoid is bad or it is not receiving 24 volts.
Jan 25, 2013 | Aprilaire Humidifiers
I have a aprilaire 700 I just installed on return plenum. Have a problem with the wiring, the instruction say to connect the R&C wires from humidistat to the same on furnace power strip. Is the C
Depending on the age of your furnace you may have an aux terminal for a humidifier. If not, you should use the white wire (heat) coming from the homes thermostat to power up the humidistat and ultimately bring on the humidifier. This way it will only run when in heating mode.
Nov 16, 2012 | Aprilaire 700 Humidifier
Aprillaire 760 leaks from the bottom left of the case. panel is new, drain is clear, all vents open in the house, the panel cage is free from excessive scale. Any ideas?
Here is a link to your humidifier http://www.iaqsource.com/article.php/my-aprilaire-humidifier-is-leaking-what-to-do-about-it./?id=35
Oct 19, 2011 | Aprilaire 700 Humidifier
The light is blinking to change water panel. should i wait til the beginning of winter or do it now beginning of summer?
Hello, i would wait untill fall when thebheatingnseason will begin. Most likey you will be using your ac soon anyway.
May 18, 2011 | Aprilaire 600 Humidifier
How do i use this humidifer i lost the instructions please help
go to http://download.gracobaby.com/ProductInstructionManuals/ISPD022AB.pd then you have your own
Mar 05, 2011 | Graco 15 15 Gallon Humidifier
Need parts for Aprilaire Model 224?
See this link:
http://www.schills-humidifier.com/aprilaire_224.htm
It appears that parts may be limited due to the age of the unit.
Mar 16, 2010 | Aprilaire Humidifiers
FROM A CONDO IN FL WITH HEAT PUMP---I HAVE A WHITE-ROGERS THERMOSTAT (2 STAGE HEAT-1 COOL) AND WANT TO WIRE IN A HONEYWELL H46C HUMIDISTAT FOR HUMIDITY CONTROL. THERMOSTAT HAS THE FOLLOWING WIRE POSTS E O...
It's a little unusual to add a humidifier in Florida. The ambient humidity is usually high enough.
But anyway, if you want to do this and assuming you have central air with forced air heating, you could install the humdifier in a standard configuration, then use a sail switch or differential pressure switch in the supply air duct to turn the humidifier off or on when you are in the heating mode only. The sail or differential switch will ensure that the unit can't run unless air is moving and you can tie the humidistat in to the first heat stage.
Mar 05, 2010 | Honeywell Power Humidifier: Furnace...
Have a Honeywell House Humidifer - Control Malfunction?
get a humidity gauge from radio shack for about 20 bucks. thats the only way to tell. or pay a service compant tocome out for probaby a 100 bucks to tell you what the humidity level is in your home. id get the $20 one a the shack
Dec 02, 2009 | Honeywell Power Humidifier: Furnace...
Water only runs with humidistat in test/reset mode. Aprilaire 600 with an Aprilaire 56 Automatic Humidistat, both about 5 years old. Water line is clear, and test mode runs fine for the 1 minute interval....
you need to make sure your humidity level in the house isnt higher then what your humidifier will provide at any givin outdoor temp. this chart is in the owners manual. you cant remove the wires going to the ODS or it will give an error unless you have a resistor to put in its place. Anyway if the humidifier works in test mode according to AA it works so you may have higher humidity than you think, the highest your gonna get is 45% as the temp outside drops it will allow less humidity so it doesnt cause window condinsation (property damage) here is a copy of the chart. the #s on the left are the dial setting
TABLE 2 – % Relative Humidity Guide
Outdoor Temperature (°F)
-10°F 0°F 10°F 20°F 30°F 40°F
10% 10% 10% 15% 20% 25%
2 10% 10% 15% 20% 25% 30%
3 10% 15% 20% 25% 30% 35%
4 15% 20% 25% 30% 35% 40%
5 20% 25% 30% 35% 40% 45%
6 25% 30% 35% 40% 45% 45%
7 30% 35% 40% 45% 45% 45%
Nov 28, 2009 | Aprilaire 600 Humidifier
Humidifier not working
Depending on the age, transformers do go bad. It will have a odor to it if it is burned out, I just checked and the doorbell transformer at home depot is sufficient to run the humidifer. Dont worry that it is 20VA instead of 10VA. The VA is just the load it can handle, the higher the number, the higher the load. The transformer at home depot is around $15 dollars. You will use the 2 outer of the 3 screw terminals for the low voltage. I hope the helps. Steve
Dec 11, 2008 | Honeywell HE220A1019 Whole House...
Family Care HM1555 Humidifier Logo
Top Family Care Humidifiers Experts
Mack Baxter
Dennis
Are you a Family Care Humidifier Expert? Answer questions, earn points and help others
