Question about Samsung PCJ522R 52" Rear Projection Television
Samsung pcj522r shuts off randomly
I have a samsung pcj522r crt rear projection tv that shuts off randomly. It may not do it for days, then one day it may do it many times. Once it turns off you can turn it right back on and everything is fine again. Anyone with any suggestions would be greatly appreciated.
I had the same problem, and when I added a small 4" external fan the set ran until I shut it off. Direct the fan to the bulb area in the rear of the set. The problem was the original fan not being beefy enough. When it lost even the slightest bit of performance, the set heats up and shuts down.
Hope this helps.
Posted on Nov 28, 2008
    Scholar:
  • 131 Answers
Samsungs have convergence ic that heat up and cause tv to shut off but most of the time the colors will be off. Alsp solder connections could cause this on voltage regulators.my guess would be convergence ics cost for repair is 250.00
thanks doctor video
Posted on May 12, 2008
I have a 47" rear
This is usually due to a leaking CRT. Or picture tube oxidation in the cooling liquid. Definatly not a job to be performed in the home. The cooling liquid needs to be changed in all three picture tubes. Cleaned inside the jugs and replacement gaskets. Gennerally about 60 to 85 dollars each.
often, the fluid leaks onto the power supply or sweep module and causes other problems.
Jan 17, 2011 | Samsung PCJ522R 52" Rear Projection...
Apacitor
Hi Steve,
Sorry...I got out of television repair before ever working on projection screen sets, so I have no idea.
I know there should be three tubes, one for each primary color, but I don't know if there is some way to discharge all at one time, or individually.
If Fixya has me listed as a projection tv expert, then I apologise, I am going to check that now.
Good Luck!
Mar 18, 2008 | Samsung PCJ522R 52" Rear Projection...
Samsung rear Projetion Tv Model No. PCJ522R
I Have A
Samsung rear Projetion Tv Model No. PCJ522R i was cleaninthe inside when i spilled oil on half of the board power supply,when the tv is connected power button is light up but wont turn on,what can i do?
SAMSUNG PCJ522R 52IN Rear Projection TELEVISION WILL NOT P OWER ON
1)Check PC boards for CRT coolant leak.Look closely at the
signal board and the main/power PCB.
2)Check any/all fuse devices in power supply
3)Let me know your findings....T.
Oct 23, 2007 | Samsung HCN4727W 47" Rear Projection...
Samsung PC J5225 shuts down after 3 - 5 seconds
It sounds like the tv power supply has problems. you probably should call a service center about a repair.
there are "safety" features built in to any tv with a "crt" type of screen that will not allow the tv to run when there is a problem.
Oct 20, 2007 | Samsung PCJ522R 52" Rear Projection...
Samsung pcj522r
Oct 15, 2007 | Samsung PCJ522R 52" Rear Projection...
No picture
you are into really technical problems. There is HIGH VOLTAGE in any tv using crt's. please be careful!!
you should contact a qualified service center and them do the repair.
Sep 21, 2007 | Samsung PCJ522R 52" Rear Projection...
Samsung PCJ-522R
hey john if you look into the blue crt it will be very foggy..the coolant in the crt needs changing. you may want to contact a local tv repair person for more advice and coolant changing procedures....john
Sep 01, 2007 | Samsung PCJ522R 52" Rear Projection...
SAMSUNG PCJ522R
part numbers AA91-00607A and BP96-00645A the Bp part number is the bag hoses and ends for all three CRT's sold in a kit form and has all you need
Aug 30, 2007 | Samsung PCJ522R 52" Rear Projection...
Samsung PCJ522R 52" Rear Projection Television Logo
140 people viewed this question
Jerry Greenberg
Jerry Greenberg
