Question about RTO PasLode 900420 Impulse Framing Nailer
The last time i cleaned my impulse framer i put in the battery when done cleaning it, and the fan runs continuously, and it wont fire. Any hot tips? The nailer is about 10 years old, but i've never had this issue after cleaning it. Thanks, Nate.
  • RTO Master
  • 43,501 Answers
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Posted on Mar 06, 2011
Paslode impulse framing nailer , iv cleaned gun and oiled , the fan works etc . seems to only fire if i have fully charged battery ,once used for about five minutes it stops firing . only way to get it...
When it stops firing is the little light on the side of the handle green or red? If it is red then the battery is draining down too quickly. Either the fan switch has malfunctioned causing the fan to run all the time (I have seen this before) or you got either a faulty battery or charger.
Mar 05, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Paslode framing nailer fan runs battery charged new fuel .fires a few time than nothing charged batter again couple more shots than nothing?
heatman101
Mar 04, 2011 | RTO PasLode 900420 Impulse Framing Nailer
I have a PASLOAD 325 IMPULSE Framing Nailer. I have cleaned, replaced gas, charged battery, and oiled. Fan runs fine. spark has been tested with firing head removed. Solid spark every time. When assembled...
checkk the safety to make sure it fully depresses. Also check the gas for the expiration date that is on eht bottom and lastly did you replace the O ring in the fan area if it is an older unit. What I do is leave the top cover with the filter off and pull the pusher spring all the way back and then WITHOUT gas OR ATTERY in tool push down to make sure the safety fully depresses. Also did you remember to reinstall the push rods. also look at the gas stem.
Sep 21, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode Impulse Framing Nailer won't operate
heatman101
May 10, 2010 | Omega Paslode 901000 Impulse Cordless...
My paslode wont shoot i cleaned the gun recently and oiled also the light is green and i compress the tip to shoot and it wont but the fan still comes on to vent the gas i also put a brand new gas in
strip it down again and put the battery in and whilst holding the nipple down pull the trigger (just mind your fingers as the fan will start) and as you squeeze the trigger see if sparks each time
Mar 05, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Cleaned impulse framer 900420 put in new fule
If this is a framer there isn't a lockout for it. you would need to pull the front assembly to remove a jammed nail or look for problem.
Oct 20, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 350 wont fire
Probably needs cleaning. You`ll need two new o`rings.
Aug 19, 2009 | RTO PasLode 900420 Impulse Framing Nailer
IM250 Paslode straight brad nailer, fan wont shut off
My paselode was doing the same thing, and I followed all of the cleaning instructions, but the problem continued.
If it was left alone for a minute, it would fire again, so I removed the cover over the trigger assy, and checked the spark plug wire connection. The trigger came out, and during reassembly, I noticed that the electrical switch was hanging, and slowly pushing back out.
I cleaned and lightly spray/oiled the switch pin, and voila.........works like a charm.
Jul 26, 2009 | RTO PasLode 900420 Impulse Framing Nailer
I shot six mails and the frame nailer gun stopped working (could no longer dispense nails) I have a frame impulse cordless; the fan engages upon tip compression, I pull the trigger, the framer does not...
First, make sure you gas is not expired, it has a date on it. Take off the back cover with the allen wrench and two phillips head screws on the sides. Pull it out, being very careful and make sure when you put it back the wires are tucked in there place again. There is an o-ring under the fan that may need replacing causing the vacuum to not work.Also, make sure the little spark plug is clean of all carbon residue. Clean with some WD40 or ether. Worst case scenario fan motor or spark plug. You can find parts for these things. Lemme know. Please rate me
Jun 13, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode cordless framer wont fire. new gas , charged battery,
K, this could be a couple problems. How far down did you take it to clean? Are you comfortable with removing the combustion chamber/housing from unit. There are 4 screws in the top cover and 2 down where the work contact is. Remove them leaving just the fan assembly and handle housing. Next locate the roller arm next to the fan assembly, put a fresh battery in tool and push the arm (KEEPING HANDS AWAY FROM FAN) the fan should come on, if not you probably have an electronic assembly that is bad, if it does come on it should stop in a few seconds. Next depress the trigger and again the fan should come on. Now to diagnose the firing unit. Depress the lever on the roller arm and hold in while pulling trigger, you should see a spark and also hear it where the plug is. If not then you either have a spark unit that is bad or a wiring problem. At this point I would take in for repair. The spark unit is around 90-100 dollars When you put back together did you also replace the orings or clean the ring grooves? Let me know if you have any questions
Jan 10, 2009 | RTO PasLode 900420 Impulse Framing Nailer
RTO PasLode 900420 Impulse Framing Nailer  Logo
575 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
