Question about ASUS P4P8X-SE Motherboard
Usb port I just put this motherboard in a new case and I have heard that some of the asus models require that you hook up your usb pins backwards from the standard way. How do you hook up the usb ports 5, 6, 7, and 8 on this board?
    Problem Solver:
  • 4 Answers
If you having a problem just buy a new one and thats it!!!!!!
Posted on May 12, 2008
Good day i have mother board asus p5800-mx the usb port cannot work theirs no 5 volts in the port, pleas help me to resolve my problem thanks.
Ashley,
A) There are two USB headers on the motherboard.
They are rectangular in shape, and Blue in color.
One is to the immediate Right of the 3 white PCI slots.
Has 4 pins across the Top row, and 5 pins across the Bottom row.
May have USB56 printed on the motherboard next to it.
The second one is at the Bottom of the motherboard, below the Intel 82801EB southbridge chip; which is to the left of the CMOS battery.
May have USB78 printed next to it
http://www.ebay.com/itm/Asus-P5P800-MX-Socket-775-MotherBoard-NEW-865GV-/221041609289?pt=UK_Computing_LaptopMotherboards_CPUs_CA&hash=item33771b4a49
(Turn motherboard photo 90 degrees to the Left, to be as it sits in your computer case)
EACH USB header supports TWO USB ports.
A Card Reader uses ONE USB header, with it's two cables.
Point?
Front Panel USB ports, are connected to one of those blue USB headers.
This USB header you know to be bad.
If the other USB header is not being used, connect to it.
The front of your computer is the Front Panel.
The USB ports in the Front Panel, should be connected by one common cable, and it ends in a plug on connector.
No? Not feasible?
Then suggest using a USB adapter card, in an open white PCI slot,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606148&CatId=511
Product details indicate it has two internal USB headers.
This way you can connect the Front Panel USB ports to it.
http://usa.asus.com/Motherboards/Intel_Socket_775/P5P800MX/#download
Choose ANY O/S, and then download the manual.
Or, here is the direct link to the motherboard manual (PDF file),
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5P800-MX/e2005_P5P800-MX_V2.pdf
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 03, 2013 | ASUS P5V800-MX Motherboard
Dear sir, i have just purchased an asus m4n68-tm mother board with amd athlon ii x2 3.0ghz processor. im facing an strange problem. i have an external 320gb western digital hard disk. the problem is the...
Hi there, It sounds like your problem is that you haven't hooked up your front USB ports to your motherboard. If you open up your computer case, you should notice some cables coming down from the front USB ports. Those cables need to be attached to USB headers on your motherboard. You should check out your motherboards manual to see where the pins for the USB headers are, and then hook up the cable. My guess would be that no USB device works via the front panel, but after hooking up these cables all devices, including your external hard drive, will. If you need more help/clarification, let me know please! Alex
Jun 03, 2011 | ASUS M4N68TM Motherboard
I want to get a usb 3.0 hub and plug it to the asus p8p67 pro on the middle of the mother board. What kind of connection is it?
The header bus above is for the USB Front Panel interface:
This is included in many of the various flavors of the MoBo. If you're looking to use the MoBo connector to supply something other than this Front Panel interface, you're going to need to obtain the pinout of the jack on the motherboard and compare it to the signals required by your USB 3.0 device. The one from Asus is simply gathers the wires and forms them in a single shell - then keys the shell to prevent reverse insertion.
Think of what you have to do as the way USB 2.0 headers are provided on MoBo and the way PC cases have USB jacks built in. The USB header isn't standard; some have 9 pins - some even have 10! They can't seem to get on the same page as to how many pins are needed. The location of the signals on the header are probably different from brand to brand, too. So, the case manufacturers break up all the individual wires and label the signal so that YOU can check the MoBo manual and plug each one in to the correct pin.
May 06, 2011 | ASUS P8P67 PRO - ATX - INTEL P67 - SOCKET...
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI/e2024_a8n-sli.pdf
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
Apr 19, 2011 | ASUS A8N-SLI Deluxe Motherboard
USB56 Front USB hook-up to case
there is no chance to join differport to join in computer asmbaling. we should look port and size and conneting corner shape. we can asambling any port reading in bords smallptints and casing wire there is aprint in casing wire /reset/ p.led/hddled/ usb u can get front usb print in mother bord,
Oct 30, 2009 | ASUS P4S8X-X Motherboard
Case connector problem
we would need to know the motherboard you have. most i've worked on have a 7 or 8 pin connector near the bottom of the motherboard.... next to the pci slots. if that front devices uses a modular plug it usually has a blank pin slot so you cannot hook it up to say a usb port.
Get out your magnafying glass and a light... the connectors are often labeled right on the board.
Robert
Please rate this solution.. thanks
Sep 08, 2008 | ASUS A8V Motherboard
Pluging in extra usb ports/Mic and headphone jacks from the tower
Answer me this. You're case is an Antec tower? The motherboard is the Asus P4P800 SE ? Is this correct?
If you have you're manual you can see what goes where on the board for front panel connector page. 2-31. (This diagram shows you how to connect the front mic & speaker).
To connect the Antec's front USB ports plug the case USB front connectors onto USB56 & USB78 shown on page. 2-30. Most case wires are already set within their USB connectors & the Antec's front USB connector should fit right on the mother board's pin's. If you need you're user manual, download from Asus by clicking on this link. http://support.asus.com/download/download.aspx?modelname=P4P800%20SE&SLanguage=en-us
Good Luck!
Mike
May 19, 2008 | ASUS P4P800SE Motherboard
USB ports setting
Do you have them setup according to your motherboard diagram?
Apr 30, 2008 | ASUS P4S800D-X Motherboard
Trying to set up front usb ports on asus p4p800se
Find usb pin in the boad " USB1 & USB 2" You can see five pins in the board composed of two lines. connect the cable in the line composed of four pins. from left. VCC, Data-2 , Data+2, grnd2. After connecting try a Usb mouse if the USB mouse function well then connection is correct.
Jan 06, 2008 | ASUS Intel 815E Chipset TUSL2 (TUSL2 SWA)...
ASUS P4P8X-SE Motherboard Logo
90 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
