Question about Coleman 10' X 10' Sundome Tent 9160K101
Coleman bayport camper electrical problems - will not light - bulbs fine and wiring looks good, however, it has been sitting outside for 9 years!
    Problem Solver:
  • 13 Answers
You would be better obtaining a cheap multimeter and test the continuity of the wiring. Or check the contacts were the bulbs sits. you can use a finger emery board to clean the contacts, hope this is of use.
Posted on Jan 16, 2011
Coleman Mach 48000 series roof top A/C in my camper & recently it's been dripping heavily inside the camper. We looked at the top & inside for a clogged line & can't find anything, suggestions?
I had the same problem but it wasn't a clogged drain line, it was the gasket between the roof of the camper and the AC unit. The gasket had shrunk and pulled apart allowing rain water in. To make sure you don't have a clogged drain line when using the AC do you notice water dripping off the camper anywhere besides inside? You should have some drips somewhere on the outside.
Jul 18, 2017 | RVs
My neighbor was helping me unhook my pop up camper (colemen bayport) but forgot to unhook the light harness from vehicle. The adapter tore apart. the trailer side is a 6 wire square plug and the vehicle...
Get a 12 volt tester (looks like an ice pick, but has a bulb in it) and someone to help you.Attach the ground wire of the tester (it only has one wire).Have your helper do the following, one at a time,while you touch the broken wires on the vehicle. Turn the lights on, step on the brakes, activate your signal flashers, reverse. When the tester illuminates from each wire, match that particular wire with that particular function. Example; When the brake is pressed, the wire for brakes will come on. Don't leave your headlights on for long (kill your battery). Remember to turn your ignition on while checking for flashers and reverse Good luck!
Aug 23, 2013 | Dometic Rooftop RV Air Conditioner
Brake lights quit working. turn signals fine.has fiberglass camper shell. camper brake light works. tried new fuses and bulbs ,no help
please explain more fully exactly the problem as iam unsure here ,camper body ??? tried the earth wires ?? if i knew what i was dealing with i might have a better idea
May 21, 2011 | GMC Sonoma Cars & Trucks
Do pop up campers have batteries for their electrical system?
YES MOST DO TO RUN LIGHTS. YOU NEED TO SNOOP AROUND YOUR CAMPER TO SEE IF IT HAS A PLACE FOR A BATTERY. SHOULD BE ON THE OUTSIDE OF THE CAMPER.. NOT GOOD TO HAVE IT INSIDE OF CAMPER UNLESS IT A SEALED BATTERY, BATTERY'S LIKE A CAR BATTER GIVE OF HYDROGEN GAS AND CAN EXPLODE VIOLENTLY SO IF YOU ARE THINKING ABOUT ADDNG A BATTERY PUT IT ON THE FRONT HITCH ASSEMBLY AND USE A FUSE THAT MATCH THE SIZE WIRE AND LOAD.. YOUR LOCAL AUTO PARTS STORE CAN HELP YOU WITH ALL THE THINGS NEEDED RIGHT DOWN TO THE 12V FLOAT CHARGER OR MAYBE EVEN SOLAR ! GOOD LUCK AND I'FN I WAS ANY HELP PRAISE IS APPRECIATED .. SO VOTE JAY MOTORWIZJ
May 27, 2010 | Electronics - Others
Coleman 6250 ,no power generated
check your AVR card...if the brushes are fine...
Aug 16, 2009 | Coleman Powermate Premium Plus 6250W...
Pop-up camper lights all turn on when tow-vehicle lights are on
FIRST, make sure white wire of camper is grounded to the frame of tow-vehicle. Temporarily use a jumper-cable frame-to-frame. Then apply 12volts individually to each of the three circuits to the camper. Assuming a 4-wire flat connector -- brown wire is for marker lamps; yellow is left brake/turn; green is right brake/turn
May 21, 2009 | Sport & Outdoor - Others
Camper electrical wiring and propane lines dont work
you need to find the propane lines and where ever you have a joint you need to put "snoop" on it. which is basicly soap and water sorry my spelling sucks. anyway you do this with the propane on and whereever you have bubbles you have troubles. you can even check your lines with it. Now yoiur electrical woes can be fixed by tracing your wiring and finding out where you have a short this is when two wires are either touching eachother both of these problems take time and they take some experience. If you mess this up you could blow yourself up. Let me know what you are going to do. I'm worried for you
Apr 30, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Coleman Powermate 8750 will not generate electricity.
I had a similar situation with a friends generator. After sitting around unused for a few years it would not generate because the residual magnitism was weak. I plugged a light into it and by using the throttle arm I breifly ran up the RPM and the light came on. DO NOT MAINTAIN THE HIGH RPM FOR MORE THAN A FEW SECONDS.
Feb 25, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
2007 Tacoma Tail light problem.
Check the taillamp fuse on the truck. If it is blown, you either have a short in the wiring of the camper, or the 7 pin inverter box on the camper.
Oct 27, 2008 | 2007 Toyota Tacoma
No power
Since this generator quit working suddenly it's likley that something is wrong with the field circuit inside. The metal surfaces you cleaned off sound like the slip rings of the rotor, there should have been 2 graphite square rods mounted on the plastic bit you took off that ride on these slip rings, they could be worn down or broken.
You'll need a good DMM to measure the resistance between the 2 slip rings (should be about 15 ohms), also measure each of the stator coils (black and white wires in the molex plug) look for an open.
Because the generator has been sitting for a couple of years it probably also hsa lost its residual magnetism, you'll need to flash the field to get it working again once all the parts are confirmed to be OK.
Oct 07, 2008 | Coleman Powermate Powermate 5000W...
Coleman 10' X 10' Sundome Tent 9160K101 Logo
132 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
