Question about Philips Magnavox 27MS343S 27" TV
I have a 32" Phillips Magnavox TV Model #MS3252S431 Chasis # L01-1UAC-7638. My problem is that it cuts off as soon as I put it on. A technician told me I needed a Horizontal Output Transformer or a Flyback Transformer. However, I do not have the Parts number for the Transformer. Also, is that why my TV is shutting off?
4 Suggested Answers
SOURCE: Magnavox MS3252S431
Replace:
Q7461 33725
Q7463 32725
C2455 47uF@50V
Posted on Jun 17, 2008
Replace:
Q7461 C33725
O7463 C32725
C2455 47uF@50V
walesarumi
  • 6993 Answers
SOURCE: Magnavox model MS3252S431 (chassis L01-1UAC-7638)
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck
Posted on Apr 05, 2011
I have a Magnavox Philips TV model no MS3252S431..I can't figure out how to turn off the closed caption. The remote CC button does nothing... Help
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Nov 30, 2014 | Televison & Video
Model number#55P8288A Phillips Magnavox(PVT910)We have no owners manual.And the picture is too orange.where can we get a manual to set it right
http://www.tvrepairkits.com/download-guides/tv-kit-001-002.pdf
www.scribd.com/.../Philips-DPTV400-TV-Projection-Training-Manual
www.scribd.com/.../Philips-Training-Manual-TV-Plasma-Display-Panel-Chasis-FTV1-9 -
Service & Repair manuals for your unit.
Sounds like your set has developed a "Color Mixing" problem, Please use the troubleshooting procedures and you will soon be able to find out what to do.
Apr 29, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips 27 inch TV - Model # 27PT543S37A - Keeps going off!
if you have back ground of tv repair, remove back cover but you need tools and tester, check heater line from crt ckt board going to horizontal section.
Apr 03, 2009 | Philips Magnavox TP3285C 32" TV
No sign of power on my Phillips Magnavox rear projection TV
try replacing the fuse. it should be behind the bottom panel near the power cord
Nov 17, 2008 | Televison & Video
Philips model ms3252s431 went out in elec storm fires up but shuts down in 4 seconds
philips model MS325S431 is not a projection set you have something wrong right off the bat chasis #lo1-1uac-738
Jul 16, 2008 | Televison & Video
Magnavox MS3252S431
Replace:
Q7461 C33725
O7463 C32725
C2455 47uF@50V
May 23, 2008 | Proton MM2701VT 27" TV
Magnavox MS3252S431
Replace:
Q7461 33725
Q7463 32725
C2455 47uF@50V
May 22, 2008 | Proton MM2701VT 27" TV
Magnavox mptv68a
any magnavox controler will work just put in some good batteries . lots retail wholesale stores like walmart carries magnavox tv remotes but make sure its a magnavox.
Apr 10, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox 32" tv ms3252s431 shutting off
Usually, the L01-1 chassis most common problem = weak
capacitors, such as C2455.Could be C2425......47mf/25v...
Check all caps around horiz drive xformer = an ESR meter
helps on this one + a skilled, experienced technician......T.
Nov 19, 2007 | Televison & Video
Philips Magnavox 27MS343S 27" TV Logo
102 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
