Question about Konica Minolta magicolor 2400 Laser Printer
Magicolor 2400W print fades on right side of page
Yo, has anyone experienced this problem and know a fix for it. This occurred occasionly from the first page I printed. It happens more frequently if the page is full of text. Each line stats out looking good and then starts fading about 3/4 across the page. Toner is full and all the color works fine. Just the black is fading. Any ideas or suggestions??
I've taken the black cartridge from the drum and given it a light shaking thinking that maybe the toner was concentrated on one end of the cartridge but nada.. I've printed through one high capacity black cartridge and am 1/2 way through the first color cartridges. I refilled the black cartridge and installed a new chip. This problem occurred from the get go so the refilling isn't the source. I'm aggravated at this thing. :)
  • 2 more comments
  • abowen May 28, 2008
    My color and black work both on the left side of the page but the whole right 2 inches is faded.
  • Hybrid1 Jun 01, 2008
    Abowman, mine is also the right 2 inches or so but pretty much only occurs when I print extensive text on a page. If the printing is spaced out or is concentrated on the left 3/4 of the page there's not a problem... So far, I've gotten no response from Konica/Minolta. It's a shame, other than this problem, the printer is great. I'm seriously considering pitching it and buying another brand.
  • darinf Apr 03, 2009
    Mine is fading on the left side of the page.
  • Anonymous Apr 07, 2009
    My 2400w printer was fading on the left in black AND in color. The solution with the wiping of the lens with a soft cloth solved it immediately. --Thanks-- --A-- --LOT-- !!
Have you tried cleaning the leans at the bottom of the printer? Open the cover, pull out the drum. Under it is a long, narrow piece of glass. If it gets dusty or toner accumulates on it, it will cause streaks in the printing. If this is dirty, take a clean, soft cloth and very gently wipe it off.
Posted on Jun 01, 2008
Make sure both gray envelope levers are down (in the paper position)
Posted on Feb 17, 2009
Magicolor 2400w paper jam error at transfer roller
In correctly installed transfer belt. and or roller reseat both. do the internal l machine prints demo page etc. jam if not check the print properties and paper setting of the machine in the draws they must match one could be set to letterhead paper the other normal both have to match.
Feb 10, 2014 | Minolta magicolor 2400W Laser Printer
Text is printing too low on the page
I have a Magicolor 2400w and had the same problem... I hope I'm not to late because I almost put mine in the trash.
How I fixed the problem was I adjusted the solenoid behind the fan on the right side. I made a video and posted is on YouTube. Search YouTube for Magicolor 2400w paper size error. or follow the link.
http://www.youtube.com/watch?v=jlyuPJW6RjU
Hope this helps
Dec 29, 2012 | Konica Minolta magicolor 2400 Laser...
Remove lines in print from Minolta Magicolor 2400w
check the fusing unit the hot part where the paper comes out? is the line a certain color replace that image unit.
Sep 22, 2012 | Minolta magicolor 2400W Laser Printer
Magicolor 2400w prints page and then says jammed
It`s possible you`re using too heavy paper, same problem´s with thin sheet´s?
Oct 03, 2009 | Minolta magicolor 2400W Laser Printer
Printer won't print until I restart my computer.
After you have this problem again. Go to Control panel and look for administrative tools. Click on services and scroll down until you see the print spooler service.. Right click on this and select restart. Let me know if the printer then functions after this.
Jun 17, 2009 | Konica Minolta magicolor 2400 Laser...
Magicolor 2400W - Printing Problem
check the green levers at the top of the fuser unit that have envelope icons on them.  They reduce pressure on the fuser assembly for thick stock.  It is possible that one side is up the other down, causing uneven pressure across a page.
Jul 08, 2008 | Konica Minolta magicolor 2400 Laser...
Konica minolta magicolor 2400w printing proplem
pleas check transfer belt, and drum unit, probably these lines are caused by drum unit and you have to change it. also you can clean laser glass, what is under the drum unit. if both look fine you can also look at the fusing rollers.
May 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Prints only one page
please reinstall printer software,then you properly check printer properties
Jan 07, 2008 | Minolta magicolor 2400W Laser Printer
Konica Minolta magicolor 2400 Laser Printer Logo
527 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
