Question about Dryers
Press the on/off switch will not work - Dryers
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 04, 2010
I did try: change fuse as first it was without any lights. Then checked sockets. It started again by itself. Then I reprogram it-switch off-turn on 90'C-press start button- switch on- keep pressing f
Try this reset, it may work:
-Turn Off power switch
-Select 90 degree washing
-Press and hold Start
-Turn ON power switch and keep pressed Start button 10 sec
-Depress Start button
-Turn Off power switch and turn On again and thats it...
Credit to original poster :)
Oct 19, 2012 | Washing Machines
My 1997 blazer all three brake lights wont work ,checked the fuses all good .parking lights and turn singnals work fine .when i push the brake pedal you hear a noise comeing down from the pedal. please...
There is a switch on the back side of the brake pedal that turns on the brake lights (it looks like a button) when you press the pedal, I would start by finding that switch, pressing it by hand and seeing if anything happens. If that doesnt work then the switch probably needs to be replaced.
If you have a multimeter you can remove the switch and test it to see if its working.
With the switch not pressed, check the resistance between the two leads, it should read infinity.
When you press the switch the resistance should drop to zero.
Anything else suggests a faulty switch, which you should be able to get at your local auto parts store.
Jun 07, 2011 | Chevrolet Blazer Cars & Trucks
Can you help i have the asda rch7h10 smart price remote controls and have lost the insrutions i changed the battries and now they need re programing
Switch the TV on.
Press the Set and TV buttons together and the red LED should light continuously. Then press the power button and then press it every time the LED flashes (about once a second).
When the TV switches off, press the TV button on the remote. Switch the TV on with the remote and check that the other buttons work as expected. If not, repeat the process...
I had the same problem: worked it out by trial and error ;-) Hope it helps...
Oct 28, 2010 | Televison & Video
On my remote the unlock is the only thing that works. my lock and remote start doesnt work. everything used to work before i got my transmission fixed and when i got it back nothing worked and i have been...
You could try reprogramming the remote: ignition on, press and release programming switch 3 times, you will hear one chirp( channel 1),press the lock button, press and release the switch 1 time ( two chirps, channel 2), press the unlock button, press and release switch 1 time ( three chirps) press green remote start button,press and release switch 1 time ( 4 chirps) press option button. Turn ignition off. test. If this doesn't work, try disconnecting the unit's power for about ten seconds, then reconnect and test.
Sep 30, 2010 | Car APS997A Two-Way Remote Start and...
Horh does not work.the fuse (10amper) is o.k
if your fuse is ok it could be the horn itself or swtich you need to get to the horn connection and see if u have live when u press the horn if u do then it will be the horn if not then u need to look at switch connection 9 times out of 10 it's the horn good luck get back to me soon
Jul 01, 2009 | 2007 Toyota Yaris
The blower on my spa will not turn on
If you've made no changes to the wiring from when it worked correctly, then it can only be the switch. Get a new one, switch off the breakers, and wire it in according to the instruction that come with it.
Apr 30, 2009 | Intermatic PART - AIR SWITCH 4 FUNCTION...
Stations all gone bar rte1 on eurovox tx in carlow.any solutions
Greetings,
Try this,
Press menu on remote,
Scroll down to 'System info.'
Press 1959 on your remote,
This brings up secret menu,
Provider ID: 5E01
00 - CE 19 2E 87 80 61 74 90
01 -AA 26 9E F2 E9 14 D1 AE
Press 'OK' to save,
Press 'OK' again to be sure,
Press 'Exit'
Press 'Exit'
Hoe this works,
Apr 02, 2009 | StarTech.com StarView SV211K 2-port KVM...
Want to know hot key combination to switch ports from keyboard.
Press and release CTRL-ALT-SHIFT
Press and release Machine # (1 - 4)
Press and release ENTER
or
Press and release 9 (This puts you into Prev/Next Mode)
Prev = Left Shift - Next = Right Shift
Press and release space bar to exit Prev/Next Mode.
Aug 15, 2008 | Protec Microsystems Bytelan KVM/4 KVM...
NEED CODE
HAI, TRY ANY WILL ONE WORK.
1.PRESS TOGETHER SLEEP AND MENU SWITCH IN REMOTE,AFTER PRESS SLEEP SWITCH AGAIN.
2.PRESS MUTE SWITCH ONE TIMEAND RESS ONE TIME AGAIN.WHEN MUTE SWITCH IS KEPT PRESSED THEN AT THAT TIME PRESS MENU SWITCH IN TV FRONT .
Jul 05, 2008 | Televison & Video
Mitsubish mr Slim air contioner heat & cooling control panel
HOW TO WORK THE HEATING AND COOLING CONTROL PANEL
- PRESS THE SWITCH ONCE IT OPERATES "COOL"
- PRESS THE SWITCH AGAIN IT OPERATES "HEAT"
- PRESS THE SWITCH ONCE AGAIN IT STOPS.
Mar 05, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Dryers Logo
29 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
