Airtech aircon gives an E4 code and then goes off = what causes this and how do I remedy it
Two days ago we had an Air tech Airconditioner installed and it is showing an error FE what is this pls?
Posted on Jun 06, 2012
2 Suggested Answers
  • 4736 Answers
SOURCE: my carrier aircon model WCARG019EE is not cold
According to the Owners Manual, E4 is a fault code that requires service by an authorized Carrier Serviceman. No other explanation for it was given.
Sorry I could be of more help.
Posted on Apr 29, 2011
How can we make our Airtech Elite portable aircon's wind cooler? It's cool, but not cold!!
the temperature should be close to 20 degrees difference between the return and supply air of the aircon. Proper maintenance includes free airflow on the outdoor unit, hose the radiator down with water, clean it.
Oct 09, 2015 | Heating & Cooling
My aircon gives me a E4 error. what does that mean? I need a manual urgently
Estelle, Estelle. Learn to use Google or some other search engine. That is what they are for. Lets try "aircon manual" but you probably need the model number, right?
So, using the information you gave, I got this:
Product documentation and of course it lists several models.
Don't EVER submit a question without Make and Model included, unless you want non-helpful answers.
Dec 24, 2014 | Office Equipment & Supplies
What is E4 error code o. Yonan airconditioner?
My yo nan midwall split aircon is displaying an E8 error code. What is the fault?
Aug 12, 2013 | Heating & Cooling
Mitsubishi VCR Model HS-821V Ejects Video Cassette & gives an error code E4
Sometimes things like that are caused by the mode switch which will either need to be cleaned or replaced. It's worth looking inside for damage inside the unit. Pay close attention to plastic parts.
Nov 26, 2012 | Televison & Video
Can you please help with airtech elite pc09-mr3 portable aircon instuctions
Hello
I got a portable Airtech Elite PC9-3MR by our nabour. I have no idea how it works and it's blowing cold and then 5 min later it's blowing hot air out. Can someone help me please
Oct 27, 2011 | Heating & Cooling
What is code E4
E4 means the overflow sensor has activated.
Under the washer is a pan - with a sensor. If it gets any sort of water - it activates.
You can remedy this issue by pulling out the dishwasher, and tilting it up to about a 45 degree angle to empty the catch pan.
This should solve your problem.
Thanks for using FixYa!!
Aug 03, 2011 | Dishwashers
I have e4 showing
E4 error indicate an abnormal water level which means too much inlet water (E5 also is refer at this fault).
I quote other comments/solution about this same error:
I had the e4 error code and i took the outer panel off and inside behind the power button is a grey reservoir tank which measures the water that goes inside the dishwasher which actually got bunged up with **** and grease causing the floaty thing to get jammed and cause the e4 code to come on which means abnormal water level the top to the reservoir just unclips on both sides then just clean all the gooey stuff out and put it back together it worked for me.
Good luck.
May 31, 2011 | Kenwood Dishwashers
My carrier aircon model WCARG019EE is not cold & theres E4 code what does it mean?
Apr 29, 2011 | Carrier XCB123D Air Conditioner
The aircon starts up okay. set the mode at auto. set the required temp at 22 degrees. starts to cool down then flashes E4. Can't find any reference to what E4 signals.
try to check your thermistor it is connected to your pcb board or shut of the main breaker after aseveral minutes shutt it to on to reset the alarm then observe the unit.
Feb 20, 2011 | Heating & Cooling
Highlander KYD-25/c Error E4 displayed
You want to look up Guangdong Chigo who are the manufacturers of this unit. They have a list of error codes/service manuals etc on their site.... From the PDF:
"1、Check whether the operation current and power of the unit is abnormal. 2、Check whether the speed and wind quantity of the fan is normal, otherwise replace the outdoor fan or capacitance 3、 Check whether the surface of the condenser is too dirty, and it should be cleaned when it is too dirty. 4、Check whether the unit is short of the refrigerant, add the refrigerant after leakage detection and repair welding. 5、 Check whether the sensor and electric control board is normal, otherwise replace the board."
Jan 22, 2010 | Heating & Cooling
Heating & Cooling Logo
403 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
