Question about Sharp 32L-S400 32" TV
SHARP 32L-S400B SHEARED OFF CABLE CONNECTOR FROM INSIDE TV TO CABLE .CAN IT BE REPAIRED INEXPENSIVELY?
I have the same problem. Do not have any idea on how to fix it without probable major expense. I have to connect cable box to RCA inputs which require the dvd player to connect with the front inputs...very inconvenient! Hope someone has an answer to this problem.
Posted on Oct 17, 2010
Were the cable screws in it is broke i have a sharp 36l s400b
They sell the jacks at radioshack...just make sure the unit is unplugged first. Now undo all of the rear case screws and locate the jack. Unscrew it from the rear case and cut the wires that go to it. Put the new one into the case, splice the wires together and put it back together. Make sure you note which wire went where when taking it apart. have fun!
Jun 24, 2012 | Sharp 36L-S400 36" TV
Sharp TV Model 32L-S400B - Reprogram Channels
Download the user manual to your Sharp TV by this link. It will ahve all details. OK?
May 21, 2012 | Sharp 32L-S400 32" TV
My sharp 32L-s400b will shut off after it warms up and will not come back on until unplugged for a short while to cool down
What I can think of is either the main filter capacitor is dried up, I had a set that would stay powered on til it warmed up then shut off and the main filter cap was the problem. Or the tv could have a thermally induced shut down, or the circuit protection kicks in due to excessive voltage. A component is defective and excess voltage is happening and the tv shuts down to prevent excessive X-ray emissions or damage to other components. You should open up the tv, be very careful and if you don't feel comfortable, have someone with more experiance or a shop look at it. Look for any blown or burnt components. Also listen for any weird or funny noises inside the set.
Mar 12, 2010 | Sharp 32L-S400 32" TV
I have a Sharp 32L-S500. It is several years old. Lately the tv screen will go gray and have horizontl lines running through it while I am watching a tv show. It is happening more frequently lately. On...
Sounds like a video problem. You could have bad solder joints in the video circuit. Try knocking on the side of the tv set when the problem occurs it might confirm the diagnostic. Otherwise you have some intermittent components that need to be replaced. If you feel handy with a soldering iron you can go inside and knock around the circuit board to pinpoint the source of the problem. Otherwise you might need the help of a local repairman. Hope this help Good luck
Dec 02, 2009 | Sharp 32L-S500 TV
TV TURNS OFF BY ITSELF
Sounds like the Startup Relay is dropping out, you will need to replace it.
Mar 28, 2009 | Sharp 32L-S400 32" TV
TV Turns Off
You may also have a capacitor that is going bad or is on the verge of going poof. Anyhow, check for any leakage on the PCB and if you have a capacitor checker check all the caps. Visual inspection may find it as well...Good luck technician. GURU JAY
Feb 18, 2008 | Televison & Video
TV Turns Off
Good day.
Yuor TV has an issue particularly in the power supply section with regards to the loose components. This issue can be best addressed by having your units' circuitry be resoldered before it could damage some parts.
Response is higly appreciated.
chris
Jan 11, 2008 | Sharp 32L-S400 32" TV
Sharp 32l
hi hope u didnt touch enything in there 30,000V is what you get.... after 3 days it will dissolves anyway you can replace it but you'll need your solder experience in hand you need to buy a new unit a good soldering iron and make them small round and neat good luck
Mar 27, 2006 | Sharp 32L-S400 32" TV
Sharp 32L-S400 32" TV Logo
158 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
