Question about Garmin GPSMAP 3210 GPS Receiver
Transducer cannot get transducer to turn on screen reads transducer disconnected, it appears all wires are connected what could be the problem>
I have the exact same problem. Were you able to solve your problem???
Posted on Oct 19, 2010
My humminbird 898c is stuck on the loading screen, won't turn off or anything, any ideas?
First steps (you may have done done) check all wiring connections ,transducer, power,ext. at both ends. Attempt power up again. No change. Call 1-800-633-1468 with model & serial #'s. OR Disconnect all cable connections from unit and with a strip of aluminum foil short out all the connections on the 898c.(not the cable). Attempt power up again. If unit will let you go to 'System Status' screen & record. Hope your unit works.
Apr 05, 2015 | Humminbird Boating
Transducer Error
You either have a fault in the head unit, connection to the transducer, broken wire in the transducer cable, or a faulty transducer.
Jul 20, 2013 | GPS
Garmin 4208 Marine Transducer Problem
You either have a faulty head unit, bad connection between the transducer and head unit, or a faulty transducer or transduced cable.
Jul 19, 2013 | Garmin GPS
Screen
is the unit on auto depth .... if out of water it will not read try to do a soft reboot on your unit if that don't work try new transducer your not getting bottom lock..units in limbo don't know what to do
Jul 14, 2013 | Boating
Need to check engine codes
Hi there:Code 12 - Memory standby power recently lost - Possible Causes
Battery or power line recently disconnected - This code is normal if the electrical system has been worked on or the battery has recently been disconnected. It will be removed after 15 ignition switch on/off cycles.
Low system voltage, bad battery or battery terminals - If the system recently had a power drop (due to a dead battery or bad alternator), this code will appear. If the battery terminals are bad and the engine was jumped, this code will appear. See the Diagnosing Your Charging System page for more information.
Bad connection or wiring - Check the wiring and connections between the battery, power module, and logic module (or SMEC). Check all fusible links and power connectors to the battery. Clean and regrease any corroded connectors with dielectric grease and repair any shorts.
Code 32 - Logic module did not see a change in air/fuel ratio when EGR circuit was activated - Possible CausesEGR valve stuck open or closed - If the vehicle fails emmisions, then the valve may be shut. If the enigne runs poorly at low rpm or at idle, the valve may be stuck open. It may be the valve or the transducer valve. Test the transducer valve vacuum output. At idle, the transducer valve vacuum should be mostly bled, and there should be very little, if any vacuum at the output. When the engine is revved, the vacuum should increase. If the transducer is functioning properly, replace the EGR valve.
Bad EGR solenoid or Canister purge/EGR solenoid - The solenoid is located in the right, front fender next to one to three other solenoids. See the Understanding Solenoids page for information about how to test and repair solenoids.
Bad connection or wiring - Check the wiring and connections between the solenoid and the logic module (or SMEC). Clean and regrease any corroded connectors with dielectric grease and repair any shorts.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 20, 2012 | 1990 Oldsmobile Silhouette
Engine codes 12 and 32
Aug 20, 2012 | Oldsmobile Silhouette Cars & Trucks
90 olds silhouette engine code 12 and 32
Hi there:
The GPS component of my Lowrance Elite-5 Gold is malfunctioning about 50% of the time.
Hey Les, Since you have replace both the unit and transducer, you have eliminated/diagnosed most of your problem.. Its in the wiring... sometime when I am in full GPS mode I get erroneous depth readings..?? Have you tried a different GPS module (the "puck")?
https://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5-7_HDI_OM_EN_988-10647-001_w.pdf
Apr 22, 2017 | Lowrance ELITE 5 GOLD COMBO
Lowrance lcx-111c hd, single beam transducer
Hey Tingo,
I have two 113's,, the problem sounds like the transducer is going bad,, Try this.. unplug all your connections,, replug them and see if it helps...
Don't get me started on $$$ updates....
May 15, 2017 | Lowrance Lcx 112c 10.4" Screen Color Gps...
Garmin GPSMAP 3210 GPS Receiver Logo
282 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
