Question about Fisher and Paykel DD605BK Dishwasher
F2 ERROR CODE - Fisher and Paykel DD605BK Dishwasher
  • 77 Answers
F2 means that your rotor is bad and needs to be replaced. You can download the video in the link below to see how to replace the rotor and you can order the part in the link below if you wanted.
Appliance Repair Video
Appliance Parts
Posted on Mar 16, 2011
  • 205 Answers
HI- Probably the Motor Rotor is bad or there is some glass in the rotor. Remove the large screen in the bottom of the drawer (turn lock-nut counter clockwise) and remove the motor rotor (turn outermost plastic part counter clockwise). Look at the bottom of the rotor, you will see the impellers, these are often chewed-up and rough. If so you'll need to replace the part. Also look the the well you removed it from and check for any glass pieces or debris. You should be able to order this part directly from F/P. Motor Rotor. Hope this helps.
Posted on Sep 24, 2010
No fonctions
  • F2 with sub code 00 - Toner Sensor problem, ID pattern reading error;
  • F2 with sub code 02 - Toner Motor problem, check toner dispenser motor;
  • F2 with sub code 31 - Image Density error, Check the light level or the drum surface reflectivity;
  • F2 with sub code 32 - Drum Mark sensor, missing/dislocated mark or sensor faulty. Sensor cannot scan mark properly;
  • F2 with sub code 33 - grid voltage wrong, either too high or too low;
  • F2 with sub code 35 - grid voltage correction will not work during simulation;
  • F2 with sub code 37 - drum mark sensor adjustment required.
Feb 24, 2014 | Sharp SF-2025/2030 Copier Toner Black...
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
F2 error
Well F2 error codeis on a variety of Sharp copiers, the F2 error code would normally be accompanied by a sub code that indicates the fault, You may please check out the following -
You may post further comments for more help or information......
Good Luck!!
Thanks for using FixYa!!
Sep 10, 2010 | Sharp AR-5316 Advanced Digital Imager...
F2-04 Error code - How do I clear?
Improper cartridge (destination error,life cycle error)
Dec 02, 2009 | Sharp Office Equipment & Supplies
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
F2 ERROR CODE
WHEN F2 FLASHES JUST PRESS START KEY U WILL RECEIVE A SUB CODE.IF SUB CODE IS 02 THIS IS TONER SUPPLY PROBLEM IF 04 THIS IS DATA PROBLEM LIKE AS IDENTIFICATION PROBLEM MODEL ERROR TYPE ERROR.BYMIAN AKHLAQ
Oct 22, 2008 | Sharp AR-C160 Color Copier
Kebc207 oven error code E1 F2
This is information from the Tech Sheet.
Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
Jul 15, 2008 | KitchenAid KEBC207 Electric Double Oven
Fisher and Paykel DD605BK Dishwasher Logo
161 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
