Question about Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range
Have Maytag MGR5755QDB range and it will not light the oven. Changed oven igniter and turned it on and it glows and produces 3.2 amps. However it does not light. Can you help me with this problem?
3 Suggested Answers
  • 11 Answers
SOURCE: Model MGR4452BDB range top burners work but oven
The igiter is bad and needs replaced . The glow bar has a crack and is not getting hot enough to open the oven valve allowing it to ignite.
Posted on Nov 02, 2009
  • 54 Answers
SOURCE: Maytag oven will not ignite
If its a square glow bar it must pull 3.5 apms to open the gas valve. Round ones pull 2.5 apms. even though the glow bar is on it must be real bright. Has it been taken over 45 second to light the oven. You will need some way to check the amps. If its getting enough amps the safety valve is bad.
Posted on Apr 27, 2010
Apr 27, 2010 | Maytag MGR5750 Gas Kitchen Range
Oven does not heat but broiler does
First thing to suspect would be a weak igniter....see if the amp draw while the igniter is glowing matches the amp rating of the gas valve, the value will be on the side of the valve, if the amp draw of the igniter is lower than the rating of the valve you would need to replace the glow coil/igniter.
Mar 22, 2008 | Bosch HGS 255 Gas Kitchen Range
My stove does not ignite even when glow light is on model 3127wtv
Turn off the gas supply to the range. Remove the oven racks,oven base pan,flame spreader.
Place a clamp on amp meter on one wire of the ignitor and turn the oven on to BAKE. When the ignitor glows it should read more than 3 amps. If it reads 3 amps or less replace the ignitor.
Jan 03, 2010 | Magic Chef Ovens
Maytag gas range does not light. Hot surface ignitor glows but oven never lights.
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
thumbs up
Aug 17, 2009 | Maytag MGR5755QD CleanDesign Gas Kitchen...
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
The oven doesn't work ,the ignator doesn't light up. no gas coming
The technical jargon is,.....:
In order for your gas oven to work this is what has to happen: 1. when you turn on the oven, the range sends 120 volts to the glow bar igniter. 2. as the igniter heats up (and starts to glow) it starts using more electricity. 3. when the electric use reaches a set amount (say 3.2 amps) the range knows the glow bar igniter is hot enough to ignite the gas, so it then releases gas through the gas safety valve. 4. when the thermostat tells the oven controller that the temperature has been reached, the control cuts power to the igniter, cutting the amp draw down, causing the safety gas valve to close. 5. process repeats to hold oven temp until you turn off oven.
So,..........the solution is:
most likely your oven igniter burnt out. Find your model number, usually on the range frame just behind the lower drawer or broiler drawer (depending on if it is a self clean gas range or not) and order the correct igniter and replace it.
Nov 02, 2008 | Kitchen Ranges
Oven stop working
In many cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. The igniter has probably gone bad. ($50.00 to $90.00 for igniter)
May 21, 2008 | Maytag Ovens
Whirlpool SF365pegq
The way the ignition system in most of today's ovens work is like this:
1. Set the oven or broiler temperature.
2. The igniter begins to glow.
3. Once the igniter reaches a certain current potential, the gas safety valve opens.
4. Gas is introduced into the manifold and you have ignition.
5. NOTE: It can take roughly 30 - 90 seconds from the time you set your oven temp to the time it takes for the gas to ignite.
NOTE: This is a designed safety feature of the oven to prevent free flowing gas from accumulating in your home without ignition. That's why you typically don't hear any gas flowing when you have an igniter problem. You might think you have a gas problem when actually you have an ignition problem.
TWO BASIC IGNITER TYPES:
Carborundum (Cylindrical in shape) - needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) - needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
NOTE: There is a UNIVERSAL FLAT BAR igniter on the market as well, that can be used as a substitute if the igniter type that came with your range is not available.
An easy way to determine if you may have an igniter problem is to check BOTH your oven features. If the oven doesn't light, check the broiler and vice versa. Since both the BROIL manifold and BAKE manifold are fed from the same gas source, but have separate igniters, it's an easy assumption to make that the igniter may be bad, if one or the other doesn't light.
The igniter typically goes bad in one of two ways, the igniter either stops glowing completely, or becomes weak over time and doesn't produce enough current to open the gas safety valve (in this case the igniter will still glow but the oven still won't light). Longer ignition times can be another symptom of an igniter possibly going bad.
For this solution, however, we're going to assume you have a bad igniter and need to replace it. Follows these steps:
NOTE: The same method applies to both the broiler and bake manifold.
1. UNPLUG the range and turn the gas off if you have a local gas cut-out valve (it is recommended that you do).
2. Open oven door and remove (if possible). Refer to your owner's manual to see if there are instructions on how to remove the oven door. Some have spring-loaded locking hinges, while others just lift out. If you cannot figure out how to remove the oven door, use care not to lean on the door or put too much weight on it. A common complaint following any kind of oven maintenance is that the oven door doesn't shut correctly any longer. This is usually caused by bending the hinges or springs coming loose.
3. Remove the oven racks, and remove the oven pan. (There are usually two screws either in the back or front of the oven holding the pan in place).
4. Remove the Flame Spreader. This is a metal plate on top of the manifold.
5. The igniter will be mounted directly to the gas manifold. Follow the wires that lead to igniter. It will either be plugged into a connector, or be connected together with ceramic wire lugs. Your replacement igniter should come with extra ceramic wire lugs. In the event the plug does not match the one on your range, cut the wires and connect using the ceramic wire lugs. DO NOT use standard wire lugs, they are not heat resistant and will melt.
6. Unplug the old igniter and remove the mounting screw holding it to the gas manifold.
7. Install new igniter on gas manifold using care not to handle the element on the igniter with your hands. The oil from your hands can cause damage and/or premature failure. The igniter is also considered FRAGILE.
8. Reconnect the wires using the recommendations mentioned in Step 5.
9. Plug in the range, turn the gas valve back on and do a visual test by setting the oven temperature to the desired range. Allow 30 - 90 seconds for the igniter to light the gas. Turn oven off and allow sufficient time to cool. If the oven has only been lit for a minute or so, the cool down period will be brief.
10. Reinstall the flame spreader, oven pan, and racks. Reinstall door if necessary.
Most igniters cost around $50. Prices will vary with models.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 22, 2008 | Whirlpool SF369 Gas Kitchen Range
Oven burner delays too much to light
Zanes, Your oven igniter is getting weak. The glowing bar next to the manifold must draw between 2.7 and 3.3 amps before the safety valve will acknowledge that it's actually hot enough to ignite gas and open up. Your igniter is most likely right at ~2.5 amps and the valve is "wanting" to open, but won't without some persuasion (hammer anyone?). The part number for your igniter is 9753108 and is available. Your local appliance parts house may not carry it, but there is a substitute that they WILL carry. Its' part number is WB2x9998. It's a universal flat igniter. Unplug the oven before repairing it, OK?
Aug 01, 2007 | KitchenAid KGRT607 Gas Kitchen Range
Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range Logo
163 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
