Question about Cameras
Need wiring diagram for Keystone 100G projector
  • 3,083 Answers
Have you tried this pdf? It looks to be what you need. I can't view it, as my Adobe Reader is acting up, but hopefully it will be what you're looking for:
[PDF]
SERVICE MANUAL File Format: PDF/Adobe Acrobat
STANDARD CIRCUIT DIAGRAM ... 100g (includes dry cell battery). Accessories ..... The projector a horizontal (vertical line) “keystone (trapezoid ...
www.jvcdig.com/.../pa016%20SX-21%20Service%20Manual%20RevBmods%206%2016%202003.pdf Good luck, thanks for using FixYa, and hope this helps.
Posted on Sep 05, 2010
Need a wiring diagram for a 2004 keystone montana rv
For a wiring diagram, contact Keystone directly.
Aug 01, 2017 | RVs
I have problem with christie projector roadster x9
If your's is the "s" model there is no keystone adjustment provided. Otherwise the keystone adjustment is found under MENU then 1, Size and Position and under MENU 2, Image Settings. Also, refer to this excerpt from the manual:
NOTE: This function is not available in "S" models.
Adjust the keystone control if images appears non-rectangular or keystoned in shape-that is, smaller at either the top or bottom edge. The effect of keystone adjustment is similar to
physically tilting the projector forward or backward in relation to the screen, and it affects all sources.
NOTES: 1) Keystone is enabled for a source only if Size is 1000 and Size x Vertical Stretch is 1,000,000.
2) Keystone adjustment is not available in "S"
models. 3) Avoid using Keystone with Blanking.
Nov 19, 2014 | Office Equipment & Supplies
Wiring diagram keystone laredo 296rl
RV manufactures do not publish wiring diagrams. Are you trying to install a ceiling fan or trying to determine the circuit that it is located on?
Jun 09, 2014 | Keystone 2013 Laredo Super Lite 296RL
Keystone adjustment not working
Are you projecting an image at the time? Often times you can not keystone the blue background.
Mitsubishi xd250u DLP projector Disassembly and Lens Cleaning Here is a video of the internal cleaning of this machine.
Mar 13, 2014 | Mitsubishi XD250U-ST DLP Projector
Keystone not working
Manual: http://www.mitsubishi-presentations.com/wp-content/files_mf/mitsubishi_manual_xd250ust.pdf
Installation>Wall Screen>Keystone
The automatic keystone adjustment may not be carried out correctly
because of the ambient temperature and the installation
conditions of the projector and the screen. In such cases, correct
the keystone manually.
• When the projector is projecting images where acceleration is
present, such as in a vehicle and aircraft, the automatic keystone
adjustment may not function correctly. In such a case, set AUTO
KEYSTONE in the INSTALLATION menu to OFF and correct the
keystone manually.
• You can correct the vertical keystones. However, their adjustment
ranges are limited in such correction.
When the keystone adjustment is carried out, the adjustment
value is indicated. Note that this value doesn't mean a projection
angle.
• The allowable range of the adjustment value in the keystone
adjustment varies depending on the installation conditions.
• When the keystone adjustment takes effect, the resolution
decreases. In addition, stripes may appear or straight lines may
bend in images with complicated patterns. They are not due to
product malfunctions.
• Noise may appear on the screen during the keystone adjustment
because of the type of the video signal being projected and the
setting values of the keystone adjustment. In such cases, set the
keystone adjustment values in the range where the image is displayed
without noise.
• When the keystone adjustment is carried out, the image may not
be displayed correctly because of the type of input signal.
How do you change the lamp in a mod # 980Z keystone projector
There is a black and silver knob under the keystone label( right above the automatic label ) on the side of your projector. turn this knob counterclockwise to loosen the covering over the housing unit for the lamb. once the knob is loosened lift the housing unit off of the side of the projector. You wlll see the enclosure where the lamp fits into beneath it.
Make sure the power is off for your projector while doing so. Screw the lamb into the enclosure , then replace the covering and screw the black knob in clockwise until it tightens.
Sep 21, 2012 | Office Equipment & Supplies
The whole projection is not square when projected onto the screen. How do we square it up?
if it looks like a trapezoid, you need to keystone it. you can either use the keystone buttons on the top panel or go into the menu under the image adjustments and select the keystone feature.
Jan 13, 2010 | InFocus LP640 Multimedia Projector
The projector comes on.but there is no picture.lens not opening
Press and hold the two Keystone buttons on the top of the projector. Turn the projector ON and continue to hold down the two Keystone buttons for 15 seconds.
Release the Keystone buttons.
Turn OFF projector.
Turn ON projector, lamp should strike.
Sep 23, 2009 | InFocus ScreenPlay 4805 Multimedia...
No light projects.
Try resetting the projector by pressing and hold the two Keystone buttons, then turn ON projector. Hold down the two Keystone buttons for 15 seconds, then turn OFF projector.
Turn ON projector, the new lamp should strike.
Mar 11, 2009 | InFocus ScreenPlay 4805 Multimedia...
Keystone 8mm movie projector
Re Keystone 68 projectors:
I join the growing throngs of folks who wish to view their family archives in 8 mm before submitting the reels to the digitals for conversion. Doesn't anyone have an answer for us? I continue to search, if I find, I'll post.
Fauvette
Jul 12, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
Open Questions:
Cameras Logo
81 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
