At high spin speeds my whirlpool duet washer is developing an imbalance. How can I fix this.
    President:
  • Washing Mach... Master
  • 2,651 Answers
You can remove thelower acess panel and check the 4 shocl absorbers holding hte tub up, possible that 1 or more has snapped or simply popped off,, if needed they simply twist in/out easy enough to replace if needed
Posted on May 12, 2008
My whirlpool duet washer stops towards the end of the cycle and flashes 6 then F. The door stays locked and the washer beeps. It has happened before, the machine is about 6 years old, how can I fix
F/06
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Feb 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
We have a Whirlpool Duet WFW9400SW02 that is making loud noise during the high speed spin cycles. It is only 13 mos old. Whirlpool will not even stand behind the parts. The repair person estimates over...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: i have a code it is f06 and then washer stops spin...
Drive Motor Tachometer Error. The control is unable to properly detect motor speed and the washer will shut down.If a failure occurs during high-speed spin the door will be unlocked after 3 minuts. Check wireharness connections between the drive motor/Techometer and the motor control unit also check between the motor control unit and the central control unit. Check the drive motor, the motor control unit, and wire harness.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Monthly Cleaning Protocol
  1. Hello. here it is: Use only the proper amount of HE (high-efficiency) detergent in your Duet. Whirlpool has stated that using too much detergent or fabric softener in the Duet can ruin a high-speed spin bearing responsible for spinning the basket. The replacement part is approximately $600. Whirlpool also claims that using too much detergent or softener can cause fungus growth.
  2. If you have mold and mildew problems with your Duet, check the filter trap. Unplug the washer and remove the three screws in the seam between the door and the bottom panel to remove the bottom panel. The Duet drain pump has a design flaw that leaves about a cup of water in the filter trap under the tub. Clean out that filter with bleach every month or two to eliminate mold problems.
  3. Put small items in a mesh bag before washing. There is a good chance they will get lodged in the Duet's filter trap, if you don't. Check the filter trap mentioned in Step 2 monthly to make sure there aren't any small items blocking the filter.
  4. Remove your detergent dispenser every month and wash with warm water and bleach to prevent mold buildup. Remove the fungus smell from your washer with Affresh washer cleaner. Always keep the washer door open when not in use.
Apr 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer is knocking in front left when is starts spin cycle. The unit used to stop and re-align but not longer does. The knocking gets louder at slow speed and somewhat improves at a faster speed. What...
The unit is self aligned when all the load springs connecting from the tube to the bottom chassis are intact. When one of them some how gets out of its position or broken, it causes the tube imbalance so it knocks during the spinning. There are about 8 springs distributed evenly from front, sides, and the rear. Need to check these out.
Jan 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Imbalance
all front load washers must be very close to level because of the high spin speed
May 31, 2009 | GE WSXH208A Front Load Washer
WHIRLPOOL GHW9150PW4 DUET WASHER DOESN'T SPIN AFTER START
F/06 Drive Motor Tachometer Error
  • Check the MCU
Mar 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Rattling noise during high speed spin
sounds as if you might have a bad rear bearing, real obnoxious almost painful to listen too kinda sounds. big job, but might have some part warrentee depending on age of unit
Oct 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet washer has started to make much more noise in the high speed spin mode, is this normal or is it a service issue?
A loud, roaring noise in high spin speed usually indicates the tub bearing is failing. A large job best left to the professionals.
Jul 04, 2008 | Whirlpool Washing Machines
Duet Washing Machine spin cycle is spinning slow
make sure u are not under loading the washer with just one or two items and that the load is fairly balanced or else the machine will not go into high speed spin as to not go completely off balance and walk across your floor if that doesnt fix it you might need a new ccu or motor control board probably the second one and make sure u are using HE detergent and not too much because suds will lock the pump up which will not spin with water in the unit
Mar 19, 2007 | Whirlpool GHW9100L Front Load Washer
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
