Question about Cub Cadet Riding Lawn Garden Tractor 25hp Kohler 50"
Are there any inline fuses in the electrical system on a cub cadet 1046vt?
  • 130 Answers
SOURCE: electric pto won't stay engaged on LT 1045
you have a shortage or your clutch is going bad
Posted on Jul 18, 2009
  • 323 Answers
SOURCE: install belt on cub cadet mower
First, make sure you have the model number and serial number (located under the seat) and then go to www.cubcadet.com to get a belt diagram so you know which way the belt snakes through the pulleys.
You will have to remove the two pulley covers on either side of the deck.
Fit the belt around the right side of the deck pulleys when you are on the left. There is an arm attached to the springed pulley on the left side. It will have a hole the size of a 3/8" driver/ratchet. Set the ratchet on unscrew (to the left) and push the arm in toward the center of the mower. You will see the pulley moving too, creating enough slack to slip the belt over the edge of the rim of the pulley with a little elbow grease. If it is too tight, get someone to push in with the ratchet while you slip it on. Once again, you are the grass cutter king!
Posted on Jul 25, 2009
SOURCE: electric pto clutch will not engage garden tractor -cub cadet gt1
the electric clutch jhondeere won,t engage
Posted on Apr 30, 2010
  • 146 Answers
SOURCE: cub cadet Z54 769-00436 electrical diagram
This site has parts diagrams for the Z54, including one for the electrical system. It's not a schematic, but it may give you the info you need. Or describe the specific problem you're having and maybe someone can help.
Posted on Jul 10, 2010
  • 1015 Answers
SOURCE: Fuse blows when you turn the key .Cub cadet zero
One thing I would try is to remove positive cable from the solenoid and the positive cable from solenoid to starter.Then I would temporarly hook positive cable from battery and see what it does. If it goes right ahead and blows th e fuse then you probably going to need to replace the starter.Thank you
Posted on Jun 13, 2011
Cub cadet gtx 1054 cutting grass and the tractor stop running. Will not start
check wires and connectors--check the inline fuse --seat switch -battery look over the wiring possible wire damaged or disconnected
Aug 14, 2016 | Cub Cadet GTX1054 54 in. 27 HP Kohler...
I have a cub cadet ltx 1046vt attractor and I can't get the oil filter off with every thing I tried
If all else fails,drive a large screw driver into it and it will unscrew. Someone over torqued it.
Aug 07, 2015 | Cub Cadet Garden
Where is the fuse on a 1046 Cub cadet?
behind the dash right side try to jump starter if catch then try then go to starter silinoid jump it will try to start if doesnst replace it if dose work go to switch relay beehind dash near fuse let me no what happen
Sep 01, 2014 | Cub Cadet Garden
Cub cadet trouble shooting
I'm guessing that you already checked all the belts. You might try checking if the pulleys are turning. I have seen where the key has worn off on the inside of the main pulley.
Jul 09, 2014 | Garden
Keeps blowing fuse
There are several things that can cause the fuse to blow. PTO stands for Power Take Off and most likely this will not be the problem unless it blows the fuse when it is turned on. What you are saying is the fuse is blowing by just turning on the switch will be a short which can be anything from a pinched wire, shorted diode, short in the stator. bad voltage regulator.etc
Apr 17, 2014 | Cub Cadet Lawn Mower Electric PTO Clutch...
1806 cub cadet PTO blows fuse when engaged
check the pto switch..un hook it if thats it then replace
Nov 19, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Cub cadet will not start
The click you normally hear is the fuel shut off solinoid in the bottom of the carb, if there is no power here and no click you have either no power in the battary, the battary terminals are loose, or there is an inline fuse gone.
Jun 18, 2012 | Cub Cadet Garden
Wheres the fuse on 1500 Cub Cadet lawn tractor
Raise the hood look back by the battery at the top you will see the fuses.
May 16, 2012 | Cub Cadet Garden
Cub Cadet Riding Lawn Garden Tractor 25hp Kohler 50" Logo
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
