Question about Cameras
We have a Canon Power Shot A570 IS, purchased October 30, 2007. We have purchased new AA-size NiMH batteries for it but the problem remains. Whenever you turn it on it shows "Batteries Low" and shuts itself off. You might be able to take 1 or 2 pictures before the batteries low light comes on. I understand that lithium batteries will not work in this camera. Please advise. Thanks, Eileen
  • 10,319 Answers
Alkaline are the only batteries to use in digital cameras such as yours. If you still get the same results with either or batteries the capacitor is giving out in the circuitry. The cost to repair this camera outweighs the cost of a new camera
Posted on Sep 04, 2010
My canon a400 power shuts down and cannot power on steady
Seems like battery charge is insufficient to operate the camera. Replace both batteries at the same time with new AA-size alkaline batteries or fully recharged NiMH batteries.
Take into account that normal AA-size batteries (non alkaline) will not work, they can not give as much current as it needs the camera.
Feb 23, 2015 | Canon Cameras
Camera keeps saying to replace batteries even though new ones that have been checked with a meter and are OK are installed.
Are they the correct type of batteries? Use only AA-size Alkaline or Canon AA-size NiMH batteries.
Dec 15, 2010 | Canon PowerShot A540 Digital Camera
My Canon power shot S2 IS does not detect the batteries
There is a battery charge level sensor in the DC/DC internal converter board.
It seems that just started to fail such board.
You can try with other brand or type of AA batteries.
If still you have the same problem, you will need to have replaced the DC/DC converter board on your camera. This means a Camera repair shop service on it.
Best regards,
Nov 26, 2008 | Canon PowerShot A540 Digital Camera
Canon PowerShot A85
I decided to send you this from the Canon website to see if this helps:
Issue: What are the specifications for batteries that I can use in my camera?
Solution: Recommended AA batteries for your camera.
What types of AA batteries can I use? Canon rechargeable (NiMH) batteries For the best results, we recommend using Canon rechargeable (NiMH) batteries. Rechargeable batteries provide the best performance and are the most economical choice.
battery_charger_kit_cbk4_300.jpgThe Canon Battery & Charger Kit includes a battery charger and four rechargeable AA-size NiMH (nickel metal hydride) batteries. The battery kit can be purchase from the Canon eStore.
AA alkaline batteries AA alkaline batteries such as those from Energizer or Duracell will provide the best performance for non-rechargeable batteries.
  • ALL AA-based PowerShot digital cameras (including A Series and S5 IS / SX100 IS-type):"Never use manganese (non-alkaline) batteries."
  • Since the performance of alkaline batteries may differ according to brand, the operating time of the batteries you purchase may not be as long as the batteries that came with the camera.
Precautions:
  • Camera operating time may shorten at low temperatures when alkaline batteries are used. Also due to their specifications, alkaline batteries may expire faster than NiMH batteries. If you are using the camera in cold areas or for a long time, we recommend using Canon AA-size NiMH Battery Kit (a four piece set).
  • While it is possible to use AA-size nickel-cadmium rechargeable batteries, performance is unreliable and their use is not recommended.
  • Never mix unused and partially used batteries. Always load two or four (depending on camera model) fresh (or fully recharged) batteries at the same time.
  • Be careful to load the batteries with their positive (+) and negative (-) ends in the right direction.
  • Never mix batteries of different types or from different manufacturers. All batteries should be identical.
  • Before inserting the batteries, wipe the battery terminals well with a dry cloth. Oil from ones skin or other dirt may cause a considerable reduction in the number of recordable images or reduced usage time.
  • Battery performance deteriorates at low temperatures (especially with alkaline batteries). If you are using the camera in cold areas and batteries are running down faster than they should, you may be able to restore performance by placing batteries in an inner pocket to warm them up prior to use. But be careful that you don't put the batteries into a pocket together with a metal key chain or other metallic objects, as these objects may cause batteries to short-circuit.
  • If you do not plan to use the camera for a long time, remove the batteries from the camera and store them in a safe place. Batteries may leak and damage the camera if left installed during prolonged periods of non-use.
WARNING
Never use damaged batteries or batteries whose outer seal is completely or partially missing or peeled off, as there is risk that such batteries may leak, overheat, or burst. Always check the seals on store-bought batteries before loading them, as some batteries may come with defective seals. Do not use batteries with defective seals.
Oct 26, 2008 | Canon PowerShot A85 Digital Camera
My PowerShot A570 stop adding the date/time stamp on each shot. Followed the directions and the selected menu won't let me enable it. It used to work. Does the internal battery (not the AA batteries)...
According to page 33 of the manual, the date/time stamp can only be embedded in the image in the Postcard mode. Set the image size (L, M1, M2, M3, S, Postcard) to Postcard.
May 14, 2008 | Canon Cameras
Choosing batteries
Your camera requires four AA size batteries.There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means many more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the LCD display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may also vary based on the Alkaline batteries selected. To significantly increase battery life, be sure to turn off the LCD when it is not in use. The LCD consumes the most amount of battery power. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Sep 15, 2005 | Toshiba PDR-M11 Digital Camera
Choosing batteries
Sep 15, 2005 | Toshiba PDR-M21 Digital Camera
Choosing batteries
Sep 15, 2005 | Toshiba PDR-M71 Digital Camera
Choosing batteries
Sep 15, 2005 | Toshiba PDR-M81 Digital Camera
Choosing batteries
Your camera requires four AA size batteries. There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the Display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may vary based on the Alkaline batteries selected. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Sep 11, 2005 | Toshiba Sora PDR-T10 Digital Camera
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
