Question about Technics SL-1200MK2 Turntable
Turntable skips during playback
I have 2 Technics Mk1200 M3d turntables. They're about 8 years old. I just got new Ortofon Concorde DJ cartridges and some pretty sick new vinyl... I've never had any problems with my gear up until the past few days... Almost every record I play, the needle skips half way through the record repeatedly.. Like I said...brand new needles and records.. have adjusted and re-adjusted the counter balance to no avail... I'm hoping I don't have to replace my tonearm.....I have a gig in a couple of weeks and need to practice...Please advise!
  • darren brugh May 20, 2008
    I am only having trouble with one of the turntables...the other is fine...tonearm and cartridges are properly balanced...I have tried switching out the cartridges just to find out that they aren't flawed...
  • 515 Answers
The only thing I can say is to make sure you set up your cartridges correctly - click HERE FOR INSTRUCTIONS on BALANCING YOUR TONEARM properly.
If, you've balanced your tonearm, and set up your cartridges correctly, then you should not have any problems. Unless, your tonearms are damaged. But this is highly unlikely. I just think you need to balance properly.
Another note, Ortofon Concorde have a design flaw, in that they don't connect very well to the Technics tonearm. The Concorde's, have short and stubby connections on the rear, making for poor connections to the tonearm. Ortofon has addressed this issue by releasing the Ortofon OM series cartridges, and mount them to standard Technics Headshell.
If you still can't figure this out, feel free to give our techs a call 24/7 @ 1.866.668.1596 ext 1 - they can walk you through setting up, and properly testing your tonearm to see if it's damaged or not.
- DJ PRO LAB
www.DJPROLAB.com
Posted on May 13, 2008
  • TERMiNAL OPTiC
    TERMiNAL OPTiC May 21, 2008
    Well, if all that is ok, then it can only be your tonearm. Nothing else will affect skipping. So, you'll probably have to have it replaced or looked at by a qualified professional.
    - DJ PRO LAB
    www.DJPROLAB.com
Having trouble with adjusting tracking weight for concorde pro s
The manual for the SL1200 (same machine but silver, acccording to an online reviewer) says:
"An auxiliary weight may be necessary between the
cartridge and headshell, mostly in a DJ application.
Many new cartridges and new turntables come with
these weights. If you cannot achieve the recommended
tracking force, then this weight is what will be needed."
Mar 01, 2010 | Ortofon Concorde Pro Spherical Cartridge...
I just put new needles on my turntables (Technics MK1200) and on one of them the records skip at certain points. I think the problem may be the arm, because even if I put the weight all the way up it still...
Compare both needles under a magnifying glass and look for diffs between the good one and bad one.
You might just have a bad cantilever on the not-so-good needle
Rate my help if this helps
Thanks
Jan 16, 2010 | Panasonic Technics SL-1200MK2 Turntable
Concorde Ortofon Electro Stylus not getting a stereo signal
Soak a q-tip with rubbing alcohol and stick it into the contact area of your tonearms. Rub the contacts thoroughly. The contacts themselves are spring loaded, so make sure all four are all the way out for full contact. Clean the stylus connections with alcohol as well, and you should be good to go. I also use Ortofon Concorde stylii on my 1200s and have never had a problem.
Dec 19, 2009 | Ortofon Concorde DJ Cartridge/Stylus 1 -...
Skipping
That is correct, your tonearm needs to be replaced.
By adjusting that top screw on the tonearm, you only made the problem worse. It's very hard to realign that screw, as those are machine calibrated, and once tampered with, almost impossible to get back to exact factory settings. We recommend replacement of the entire Technics tonearm.
- OPTiC
Master Tech, 1200s.com
Technics Parts : DJ Gear Repairs
Jun 09, 2009 | Technics SL-1210MK5 Turntable
Pioneer pl-200 turntable one channel is dull and muffled
I think we need to do more diagnosis. Did you try swapping the channel cables Left-to-Right so you're sure it is in the TT and not in your Phono preamp?
If it's still in the TT and always on the same channel with two different cartridges you probably have a wire problem in the tonearm/shell or interface between them.
May 01, 2009 | Technics SL-1210 Turntable
Technic 1210 deck
Make sure your 2nd turntable is connected to the PHONO input of your DJ Mixer or Receiver. If you have it connected to LINE IN or AUX IN, the turntable will be very low, as this model requires a phono pre-amp to amplify it's signal.
If this is set up correctly, then you might want to check your cartridge. Can you swap the cartridges out to see if the problem remains on the same turntable, or if it switches to the other turntable. If it switches, then you know the problem is with the cartridges.
If that checks out ok, you might have an issue with the RCA cables or Tonearm or both. At this stage, I would suggest taking it to a service center for assistance.
- OPTiC
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Apr 17, 2009 | Technics SL-1210 Turntable
Needle for Technics mk5
Ok, the needle is just a small portion of everything required to get up and running. Here is a diagram of what your going to need:
The stylus, also known as the Needle, is what you are asking for. As you can see it's only 1 of 3 items you need:
1) Headshell
2) Cartridge
3) Stylus / Needle
If you already have 1 and 2, and you need to replace #3, then we would need to know what model #2 is?
You'll need what's called a STANDARD Mount cartridge, (aka Half-inch). In addition, that cartridge will need to be mounted to a Standard Mount Headshell.
Here is a collection of Standard Mount Cartridges that will fit this model.
Try to stay away from those all-in-one configurations that look like the Concorde airplane. Over time they will damage your tonearm due to a poor design flaw. Stick with a set up similar to the image posted. You can't go wrong, and you'll have more options.
- OPTiC
The ORIGINAL 1200 TECHNICIAN.
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Feb 15, 2009 | Technics SL-1210MK5 Turntable
Frequent sound
Please re-check all your other equipment, as its highly unlikely to be the 2 turntables at fault, let me know how you got on.
Regards.
http://www.audiovisualservices.info/
Dec 05, 2008 | Technics SL-1210MK5 Turntable
I have only one side of the signal coming through from the deck
More than likely either your RCA cables need to be replaced, or the tonearm is damaged. Do you use Ortofon Concorde cartridges by any chance? If so, the tonearm could be faulty, or the connection from your cartridge to your tonearm might be loose. Just tighten the nut a little bit more.
If you use different cartridges, then the issue is probably your RCA cables and need to be replaced.
IN either case, professional assistance is highly recommended.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
A DJ PRO AUDIO Co.
Nov 23, 2008 | Technics SL-1210 Turntable
Technics sl 1210 turntable
What sort of problem are you having with the cords?
Sep 04, 2007 | Technics SL-1210 Turntable
Technics SL-1200MK2 Turntable Logo
506 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
