Question about MagLite - Mag Charger System 110v (M) Model - RX1019
Can I keep my maglite flashlight connected to the charger continuously while not in use?
    President:
  • 1,514 Answers
It would be a bad idea. The battery would soon not be able to hold a charge. It's best to charge it up fully and then take it off the charger.
Posted on Sep 04, 2010
When I shake it it goes off
The switch is bad, contact Maglite at www.maglite.com and they will repair it under Warranty.
Apr 20, 2010 | MagLite 3 Cell D Blue Flashlight S3D116
How to disassemble mag charger rechargeable flashlight? I need it to make mod.
http://www.google.ru/search?ie=UTF-8&hl=ru&q=how%20to%20disassemble%20magcharger&redir_esc=y&ei=Pj5hS7nAHYHFsgachrnPCw
Jan 28, 2010 | MagLite - Mag Charger System 110v (M)...
How to remove the light bulb from a Maglite flashlight
Unscrew the head (the same way, as regulating throw, but much more rotations), then unscrew the nut, holding the bulb. Assemble the same way - nut then head
Nov 07, 2009 | MagLite - Mag Charger System 110v (M)...
What way do i put the battries into a maglite
Place the batteries positive (+) end first into the flashlight tube and continue putting other batteries, again positive first. Good luck!!
Oct 11, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
Charger is putting out 13.7 volts but battery does not take a charge
If its the right charger, and connected correctly, then it is probably just time to replace the battery. Try checking out http://www.batteryinternational.com/flashlight-batteries-streamlite---maglite.html for a replacement flashlight battery. Also, I'm not sure exactly what you mean by saying the charger is putting out 13.7 volts, but make sure you aren't using a charger that is too powerful, that can destroy the battery. Check out http://www.batteryinternational.com/battery-chargers-6-volt-battery-chargers.html. You shouldn't use a charger any larger than that. Hope that helps
Jul 10, 2009 | Vector 3 Million Candlepower Rechargeable...
Won't light
Hi bballover64, I've got similar problems, but with two of them. I found some how to's that may answer your problem, Mines is the switch.
Take a look at the following link: http://www.maglite.com/pdf/CustServ/AA_AAA_switch_repair_8_0410212004735472.pdf
Nov 16, 2008 | MagLite Charger System for
Rechargeable mag light not working .
when you dropped it you probably knocked the contacts inside out of place. or you broke a soldered connection. if you can take it apart you can most likely fix this yourself. when you remove the front lens assembly there is a retaining clip that you need to remove so you can take the guts out.....please rate this
Sep 02, 2008 | MagLite - Mag Charger System 110v (M)...
Maglite charger
Hold the maglite after 30 min charge if warm means charging , if cold no charging , test the light when so bright means very good.
Dec 25, 2007 | MagLite - Mag Charger System 110v (M)...
MAGLITE
Well, first off, you could keep the batteries out of it until you wish to use it. Secondly a model of the flashlight would be nice. Also check this http://rivergum.net/page/48 it has a disassembly instruction howto for a more common model, but I don't know exactly what kind you are using.
There is also this http://www.students.niu.edu/~z115902/MagLiteDisassembled/Fully%20Built.html
Nov 22, 2007 | MagLite - Mag Charger System 110v (M)...
MagLite - Mag Charger System 110v (M) Model - RX1019 Logo
160 people viewed this question
Top MagLite Camping, Backpacking & Hiking Experts
John Egan
John Egan
David Black
David Black
Level 1 Expert
 steve
steve
Are you a MagLite Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
