Question about Dell Inspiron 1720 PC Notebook
If the power switch does not work do I have to replace the keyboard, all other functions work
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 146 Answers
Sorry , but dell system have power button embedded with keyboard.
Posted on Sep 04, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 88 Answers
I have never come across a laptop with the power switch attached to the keyboard so in my opinion no.
Changed keyboard on my hp g61 now it wont start
Were you able to change back to the old keyboard, does it work with that one? The new one could be defective. Try powering off, unplug and plug the new keyboard back in.
Mar 20, 2015 | HP Computers & Internet
Keyboard problem & it doesn't work prefect
If the keyboard has a round purple connector, power down the computer then unplug and then plug in the keyboard. Power on the computer. If it works your done if it doesn't replace the keyboard. If this is a USB keyboard, with the computer on, unplug and plug in the keyboard if it works great, if it still isn't working replace the keyboard. NOTE if this is a multi functional keyboard (special keys at the top) make sure you install the driver and any software associated with the keyboard.
Jun 11, 2012 | Computers & Internet
When i push the e,b,t,a,n ,or r button on my keyboard i get e3 ,bt5,a1, r is shif and nyt
I have often deal damage keyboard, and type of damage keyboard so much. For damage your experience, a variety of ways have been tried, but the result always failed. The best solution is replace keyboard.
Based on experience, three times I fix keyboard, without having to replace with a new keyboard.
First type of damage
All keyboard keys are not functioning, or functioning left side, right side not working
Solution
Remove the keyboard, and cut keyboard cable.
Second type of damage
When laptop is powered on, the sound (tiiiiiiiiiiit) so hard. When we press a button, suddenly appeared equal. example;
I press "y", y appears =======================
I press enter, appear =======================
Solution
Press and release button ~ ` , do it
repeatedly, when turning on laptop until laptop access the operating system.
The result is
1. When laptop turned on, there was no sound. Laptop turns normal.
2. When I press buttons, does not appear equal to. So all buttons normal function
3. There are three buttons that do not function [ { , ] } , \ '
Third type of damage
When laptop is powered, it looks normal. After entering the desktop, buttons z, x, a, s, q, w, e, does not work. If another buttons is pressed, appear equal. example;
I press p, appear p=======================
Solution
Do not turn on laptop (about 3 weeks)
This solution does not make sense, there is no technical explanation, and this solution so strange.
The fact that I experienced
This case occurred on the Acer Aspire 4736z, OS Win XP Prof.
After laptop not turned on, more than 3 weeks, keyboard returns to normal. All buttons are functioning normally. I can not explain technically, but this case never happened.
Solutions for you
I hope this information useful.
Dec 04, 2011 | Toshiba Computers & Internet
When i turn off and switch on again just get blinking screen with no data or function at all cant turn keyboards power off or on ?
If you are using battery power, replace them... if an adapter, chaeck the adapter is the right one and is making good contact. More than this you will need to have it serviced.
Feb 12, 2011 | Casio CTK710 - Pianos & Keyboards
Brought a CS62US and Mircosoft KB with mouse. When USB combo plugged on the left USB, only KB is worked together with switching function. When USB combo plugged on the rigth USB, both KB & Mouse worked...
Unfortunately, this switch has a dedicated port for keyboard that listens for the keyboard keystroke. You MUST plug the keyboard into the dedicated keyboard port on the KVM switch for the hotkeys to work. I recommend putting the mouse that comes with your keyboard to the side, and using another mouse, plugged into the dedicated mouse USB port on the switch. Not the prettiest solution, but some of those mouse/keyboard combos have some funky hardware!
Feb 17, 2010 | Altusen Aten CS62U-2 Port USB KVM Switch
4-port usb kvw switch #GCS634U
The GCS634U is designed and tested to work only with a standard USB keyboard and mouse. However, most wireless keyboards and mice work with it, but they cannot guarantee any specific model or brand that would work correctly.
As you can see, this KVM switch is a bus powered device (meaning it only gets power from the USB ports of the computers). If the computer cannot provide enough power for the KVM switch to function correctly, then the wireless keyboard will be affected.
You may try using the IOGEAR GKM541RA. It's tested to work with the GCS634U. Or you may also try using a self-powered USB hub (meaning, it has it's own power adapter) and connect it in between the KVM switch and the computer. That self-powered USB hub will be the one that will add up power to the KVM switch and help it to function properly.
Jan 12, 2009 | IOGear GCS634U KVM Switch
Dead
    1. Check your Keyboard-Video-Mouse (KVM) switch. If the system is connected to a monitor, mouse, and keyboard through a Keyboard-Video-Mouse (KVM) switch, or console selector switch, then disconnect the switch and connect monitor, mouse, and keyboard directly to the system. If this solves the issue, please contact your switch manufacturer for support and compatibility on the switch. Some switches can have a firmware update applied to resolve common problems.
      Note: BladeCenter Telco chassis - The KVM module contains keyboard port, mouse port, Power LED, Location LED, Critical Telco Alarm LED, Major Telco Alarm LED, Minor Telco Alarm LED and a video port. The PS2 keyboard and mouse connectors are standard 6-pin Mini Din. The Telco alarms mirror the Telco alarms located on the front panel of the media tray because they use the same signal lines. The KVM module allows the connection of a VGA monitor for system maintenance and control. The video connector is a standard 15-pin VGA. The KVM module is hot-swappable. It is docked into an edge card connector located on the backplane:
    2. If you have your system daisy chained for KVM capabilities using the C2T port (e.g. xSeries 330),
      then you must flash the C2T firmware after flashing the system BIOS, in order for the mouse and keyboard to work. Otherwise, after a BIOS flash, you will lose keyboard/mouse capabilities unless you walk up to each machine and push the select button.
    • If you are using NetBAY Advanced Connectivity Technology (ACT) CAT5 cabling in your rack server, instead of KVM cabling, click here for ACT information.
    1. Check for POST/startup errors. If you are getting a POST/startup error on the keyboard and/or mouse:
    2. Verify that all items are firmly connected to the correct ports, and that the cables are undamaged with no bent pins. The PS/2 style mouse and keyboard ports look identical, but are not interchangeable. The mouse and keyboard must be attached to the correct ports in order to be recognized by the system and to function correctly.
    3. Swap each item for known good units. If a new item works where the original did not, then the original component must be faulty.
    4. If the keyboard works during the POST/BIOS screens, but not in the operating system, check software logs for device driver errors. Contact your software vendor for more support in configuring the I/O devices.
    5. Check the F1 Setup error logs for system component failures or errors. These are found under Event/Error Logs. Troubleshoot suspect components further to determine if the hardware is faulty. If an IBM component is determined to be faulty, please contact your local IBM Support Center for warranty replacement of the part(s). Please have the Field Replacement Unit (FRU) / Customer Replacement Unit (CRU) part number and Machine Type, model and serial number ready.
    1. Run hardware diagnostics. Replace any parts found defective.
    Download the latest diagnostics for your system
    1. If you can down the system, check the keyboard cable connector on the system unit for proper voltage.
    2. Power off the system.
    3. Disconect the keyboard cable form the system unit.
    4. Power on the system and check the keyboard cable connector on the system unit for the voltages shown:
      PIN Voltage (Vdc) 1 +5.0 2 Not used 3 Ground 4 +5.0 5 +5.0 6 Not used
    5. If the voltages are not correct, replace the system board. Otherwise, replace the keyboard.
    6. If these steps have not solved your problem:
    7. musekye318@yahoo.com
    Jun 30, 2008 | IBM NetVista PC Desktop
    Dell Inspiron 1720  PC Notebook Logo
    55 people viewed this question
    Alun Cox
