Question about Northstar Pressure Washer 3000 PSI
Husky HU80722 model Water flows thru the washer. Have disconnected all hoses, checked filter screen it is clear. Reconnected hoses, Engine runs fine home water pressure fows through washer. Still not producing any pressure.
SOURCE: pressure washer not working
OK here is the solution. There are six plastic vaules inside the pump if you have any mechanical skills you can fix this.
These plastic valves melt when you leave your pressure washer running for a short period when you are not pressure washing. once this happens the pump becomes cloged and does not function. I spent alot of time and research on finding the parts for replacement. I called the main company of this washer pump and here is the toll free number
800-999-2245 and the web sight www.pressureparts.com but to save time just call and talk to the service tech tell him you model number and he will give you the part number.
I only paid $13.75 plus shipping around $5.50 I do not work or have any intrest in this comapny but I tell you after all the frustration and run around I had trying to fix this Home depot power washer I deesided to help eveyone else out
I can be reached at atidavid@aol.com if you have any other questions
Posted on Oct 02, 2009
  • 384 Answers
SOURCE: it seems as though there is a vapor lock in the
The wand is dirty!! Clean out the Nozzle with a small diameter wire.
Posted on Jul 29, 2009
  • 41 Answers
SOURCE: the water supply to my pump was disconnected while
Yes the impeller is probably shot. If you can find the parts it should be easy enough.
Posted on Aug 02, 2009
  • 109 Answers
SOURCE: I have a Husky pressure washer with a Honda
check the quick disconnect to the wand these are spring operated and can get stuck
Posted on Aug 23, 2009
  • 68 Answers
SOURCE: Water does not come out of the lance when I squeeze the trigger
HI it sounds like you may just have a blocked jet on the end of your lance. Please remove and clean.
Posted on Jun 10, 2010
No pressure on my husky power washer 1650
Basic Issues As an electric-powered washer, a circuit overload may cause your Husky 1600 to shut down or prevent it from starting. In this case, check your home's electrical service panel for a tripped breaker or a blown fuse -- the 1600 requires a dedicated circuit rated at a minimum of 15 amps. To prevent a blown fuse, avoid using other large devices on the same circuit as your washer. If you use an extension cord, it must be rated at 15 amps as well. Before moving on to more complex troubleshooting measures, check the gun safety trigger and release the lock if your 1600's trigger will not move. Water Woes Releasing air from the pump serves as a simple fix for low-pressure water output; remove the wand and allow the washer to run as you depress the gun's trigger until the water output normalizes. If your water output seems to lack detergent, ensure that the clear tube is securely connected to the detergent nozzle. Likewise, check the connected water supply and make sure the faucet is fully open and that there are no kinks in the hose to ensure optimal pressure. Using a shorter garden hose makes for stronger pressure, as well -- Husky recommends a hose with a maximum length of 50 feet for a city water supply. Clearing Clogs If your Husky 1600's pressure seems lacking or its water flow is obstructed, clean the nozzle by removing the wand from the gun, clearing the nozzle hole of obstructions with a stiff wire and flushing the nozzle with clean water. Similarly, clean the washer's inner water screen, located behind the garden hose connector, by removing the screen and flushing it with water. This also corrects low or irregular pressure and may remedy a unit that does not stop releasing water when the trigger is released. Model HD1600 features a chemical solution reservoir with a similar screen; clean this screen in the same fashion if you experience chemical intake issues. More to Consider If your power washer issues go beyond troubleshooting basics, contact Husky's customer service department at 800-381-0999. Husky recommends contacting customer service when your 1600 has problems with its pump, bypass valve, discharge valve or manifold assembly, for instance. Because this series of powerwashers was originally offered around 2001 through 2008, Husky's one-year limited warranty no longer covers the cost of replacement parts or repairs.
Sponsored Links
Sep 29, 2016 | Garden
Tip
LG Washing machine IE error code Solutions
An IE error code will appear if the washer has not filled with water in approximately 8 minutes.
Are the water valves opened completely?
If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
Are the inlet hose filters clogged?
There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly.
Are the inlet hoses attached properly?
If the inlet hoses are not attached to the machine correctly, it will prevent proper water flow to the washer. Turn off the hot and cold water supply then disconnect and reconnect the inlet hoses. Ensure that they are threaded properly. After the hoses have been reconnected, open the water taps completely, check for leaks, and unplug the washer for 10 seconds and retry the wash cycle.
NOTE: The inlet filters are inside the hose connections on the back of the washer. Because of their small size, take care when removing and cleaning the inlet filters so that they do not break.
on Jun 02, 2011 | Washing Machines
My whirlpool duet washing machine is making s strange hum and appears that the water is entering slower. I've checked the water taps and don't see anything different than before. Any suggestions?
In addation to checking the actual taps,also check where the hoses connect to at the rear of the washer for sediment build up in the filter screens...also while hoses are disconnected from the washer while checking the screens also place hoses in bucket and turn on taps and see if good water flow is coming from the hoses/taps. If screens are clear and water flow through hoses is good the water inlet valve the hoses attach to would need to be replaced.
GENE
Sep 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
THE SCREEN SHOWS IE
Hello there and thank you for choosing fixya
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
And finely if all of this does not work then the inlet valve on the machine needs to be replaced ok?
Hope this all helps
Aug 05, 2011 | LG WM1814CW Front Load Washer
Cold water tricles in . no normal flow does the washer valve need to be replaced
There are debri screens in many styles of washer fill hoses that can block up. And the end that connects to the back of your machine also has a reachable screen filter up inside the water valve inlet that can also block up.
Disconnect the water fill hose at the machine and check screens ... clean or replace if needed.
The screen are usually attached to the hose washer and will pop out manually with a small screwdriver or knife. Then turn the water valve on with the free end of the hose aimed into your washer tub to make sure you have free water flow from the faucet to the water valve. If all screens are clean and clear but still no water pressure going into the washer after reconnecting your hoses then you can suspect the water valve inlet assembly.
Dec 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Husky ran great for couple of hours. Now no pressure at all. Water comes thru for suds, but no near enough. Engine runs fine but will not build pressure. Checked for trash blockage-all clear. Thanks,...
Same old problem... water admitance valve sticking.
Remove the valve spool and clean the bore with crocus cloth on a dowel rod.
Replace O rings and lube lightly with plumber's grease. Reassemble... good as new!
The valve senses pressure and blocks further input water. It sticks in the high pressure position blocking water flow.
Aug 05, 2010 | Honda Pressure Washer PSI 3000
Washer will not spin or take in water
Behind your washer on the upper left or right is the water inlet hose. Close the valve on the wall and disconnect from the washer. Use a bucket or something to see if water flows thru, by opening the valve. Clean the filter at the washer inlet with old tooth brush. The water flow should be good from the inlet hose; reconnect.
Check below front to locate filter, refer to manual. It may be clogged to prevent flow of water during spin. See if you can drain water from the drain hose you see when the front is opened, before you tackle the filter.
You can type Whirlpool with the model number above in the "Help me with " column to find several solutions.
Feb 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Husky power washer no presure?
Found an easy solution to my problem. Was dumping pressure out the bottom when I pushed the trigger. Turned out the line my hose reeler that my hose was running off of was kinked. Only partial pressure was going from the house hose to the pressure washer. I attached my house directly into the house, bypassing the hose reeler, and it worked fine. Apparently, you need a certain amount of pressure going into the washer for it to work.
Mar 20, 2009 | Garden
LG WM2016CW front load washer
Check to make sure that the filters in the water valves are not clogged up.  Go behind the machine, turn off the water supply and disconnect the hoses on the machine side.  Look inside the water valves and check the filter screens to make sure they're clean.  Get a large bucket and open the water valve to clear out the hoses and make sure you have good water flow coming out of the hoses.  If both of those situations are cleared up, your machine should work properly.
Aug 07, 2008 | LG WM-2077C Front Load Washer
Northstar Pressure Washer 3000 PSI Logo
478 people viewed this question
Top Northstar Garden Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Northstar Garden Expert? Answer questions, earn points and help others
