Question about Canon PIXMA MP830 All-In-One InkJet Printer
Scan and fax fail when feeding originals using auto document feeder. Message says: document in feeder, remove document and press OK. But the document feeder system is clear of any documents. Manual says: contact Canon if this happens. Cannot get through to Canon. What do I do?
  • arts990 Sep 05, 2010
    Thanks much. I'm just out of hospital with a broken leg following surgery on a broken back in April so it will be a few weeks before I get to carry out your fix. I managed to scan 5 pages, one at a time on the flat glass and noticed some strange noises and the lamp began its traverse. May be connected or not. Will contact you again.
  • Canon Master
  • 4,737 Answers
Have you tried cleaning the adf passage and other passages?
Before you start with the instructions below, remove all the cartridges, turn off the machine, remove papers, unplug the power cord and the usb cable (if any).
First of all, lift up the (auto document feeder) adf towards outside (as shown below):
Check for any foreign particles like broken pieces of paper, etc.. If possible, clean the gears and other components.
Also, open lift-up the scanning unit, clean the passage as shown below:
Also pull out the Feeder (not the Auto Document Feeder/ADF) and clean everything properly.
Now reconnect or reinstall all the remove components, push in a paper (thicker paper like chart paper or photo paper) through the feeder passages, both ADF and front. Do this forcefully and now power on the Machine.
If there's no internal mechanism faulty or damaged components, this will definitely help you fix your issue.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Sep 05, 2010
  • 4,323 Answers
Hi
This error appears when a paper is jammed in the ADF or due to paper bits stuck behind/near the rollers. Remove the two screws at the back of the rollers. The side plastic/top pieces rotate up and can be removed. Four screws hold the ADF device in the lift-up top. I removed these 4 screws. With the power disconnected, I unplugged a wire assembly and unscrewed an electrical wire. This allowed me to remove the entire ADF assembly from the lid. At the end with the rollers, there is a metal plate with 6 screws, remove them. Beneath this metal plate are two springs, three rollers and a metal bar set in place into slots. You can look directly into the space hidden behind the rollers. Reconnect back everything in the same way.
After doing this if issue is not resolved then you’ll need to check for a broken gear/part. The rear of the ADF has a silver-grey plastic piece which covers the feed motor and gears. You gain access by removing the one Phillips screw, opening the lid, and carefully prying the retaining lip at the right end of the silver-grey piece until it lifts up. The piece is then removed by sliding the retaining "leg" free at the right end of the piece.
Inside, you will see some white plastic gears. One gear is mounted on a floating idler arm. This gear controls feed and reject (I think). The feeder fails when this idler does not flip freely from one position to the other. Carefully place a SMALL amount of very light (low viscosity) oil on the idler arm and verify that if easily moves back and forth. Test the unit before replacing the silver gray cover piece. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Sep 04, 2010
  • Daniel Scott
    Daniel Scott Sep 05, 2010
    Hi
    After doing this if issue is not resolved then you?ll need to check for a broken gear/part. The rear of the ADF has a silver-grey plastic piece which covers the feed motor and gears. You gain access by removing the one Phillips screw, opening the lid, and carefully prying the retaining lip at the right end of the silver-grey piece until it lifts up. The piece is then removed by sliding the retaining "leg" free at the right end of the piece.
    Daniel
    Hope you found my above solution helpful... Once you are fine then please try it and post back in case issue is not resolved. Don't forget to rate the solution once issue is resolved.
    Thanks
    Daniel
Auto doc feed does not activate
two possible problems :
- check the connection of the document feeder
- check the sensor on the document feeder that triggers the pickup
- check the clutch of pickup roller
Jul 27, 2012 | Canon PC-795 Copier
Trying to fax, scan or copy and anytime I try the erro message Document in ADF press OK to discharge document
Hi sdrnjen977,
Here's what you can do to address the issue and clear error message: Document in ADF.
If you press the Stop button during scanning, Document in ADF. Redo operation after checking document in ADF and pressing OK. appears on the LCD. Press OK button so that the remaining document is automatically fed out.
Removing the jammed document from the Document Tray:
1. If printing is in progress, press the Stop button.
2. Turn off the machine.
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF, then open the Document Feeder Cover.
4. Raise the Paper Release Lever, then remove the jammed page from under the roller to the Document Feeder Cver side.
5. Pull out the jammed document from the ADF.
6. Press down the Paper Release Lever, close the Document Feeder Cover, then turn on the machine.
Removing the jammed document from the inner side of the Document Cover:
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF.
4. Open the Document Output Slot.
5.Open the Document Cover.
6. Insert your hand into the Document Output Slot, then while pushing up the paper output rollers inside the Document Output Slot with your fingers, pull out the document from the inner side of the Document Cover.
7.Close the Document Cover.
8. Close the Document Output Slot, then turn on the machine.
Hope this helps.
Thank you for using FixYa.
Jun 30, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
We have a black line down the center of all copies...
If the problem only happens on copies or sent faxes then no it is not your drum. There is something on your scan glass. My guess is you are getting the line on your copies when you run the original through the document feeder. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on
May 20, 2010 | Office Equipment & Supplies
I got the manual for my J3680 all in one printer, BUT
Hello
It sounds like the scanner/fax is not seeing the original document that you want to scan or fax.
Per Page 20 of the User Manual, the original needs to be placed face down in the document feeder. (The document feeder is on the top of the printer, behind the display.)
When you insert the original, make sure the leading edge is sliding into the top of the printer (towards the front of the printer).
Per the user manual, you should hear a beep and/or see a message on the display stating the loaded pages were detected.
If you are not hearing the beep or seeing the message, your original is not loaded correctly - try sliding it further into the printer.
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Apr 30, 2010 | HP J3680 Officejet All In One Printer
How to fax
Load an original in the automatic document feeder (ADF)
You can copy, scan, or fax a single or multiple-page A4, letter, or legal-size document by
placing it in the document feeder tray.
The document feeder tray holds a maximum of 20 sheets of letter or A4-size paper or 15
sheets of legal-size paper.
To send a basic fax from the control panel
1.
Load your originals. For additional information, see Load originals.
2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed
dial button to select a speed dial, or press Redial/Pause to redial the last number
dialed.
TIP: To add a pause in the fax number you are entering, press Redial/Pause,
or press the Symbols (*) button repeatedly, until a dash (-) appears on the display.
3. Press START FAX Black.
If the device detects an original loaded in the automatic document feeder, it
sends the document to the number you entered.
TIP: If the recipient reports issues with the quality of the fax you sent, you can
try changing the resolution or contrast of your fax.
for further refernce check out the online manual
Mar 29, 2010 | HP Officejet J3680 Multifunction Printer...
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
Original jammed in fax feeder of Brother Intellifax 2800
lift document feeder cover and look for paper. if no paper is present there are one or two switch levers that are on the bottom of feeder cover. make sure they can move freely and are not stuck.
May 27, 2009 | Brother IntelliFAX 2800 Laser Fax
HP Office Jet 7310
chances are the feeder isnt feeding the paper at all, thats why you cant scan a single paper, try opening up the ADF and clean the feed rollers first, turn off the machine and gently rub the rollers again and again until you have a clean shot or surface, try this from thop to bottom rollers, please make sure though to insert uncreased paper and paper without eardogs on its leading edge, this could cause some delay upon feeding process
sometimes because it is exposed to dust, there is a tendency for the rolllers to slip, or you could be having a broken part that drives the feed rollers from your ADF.
Jun 30, 2008 | HP OfficeJet 7310 All-In-One InkJet...
WON'T SEND FAX FROM FEEDER.
u can try the following steps >
unplug the power cord from the back of the unit [without turning off the unit ] > press and hold ok and cancel key together > while holding these keys down plug in the power cord back into the unit . do not release the keys > wait for a few seconds it will make certain noises an wud turn off automatically .
turn on the printer again it will go into allignment phase > let it finish.
after its done > try to make a copy from the feeder .
Note - In case [ok and cancel key ] combination doesnot work < u can try # and 6 key combo as well with the same procedure.
THANKS
Mac
Mar 27, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
69 people viewed this question
old marine
old marine
