Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Clean light Our diswasher runs fine and the clean light comes on, but will not go back off after the door is opened and closed. No buttons will work and the clean light will not go back off.
    President:
  • Frigidaire Master
  • 2,651 Answers
You have an issue with the door latch assy, something inside it snapped, and its not recognizing you opening the door.. it still thinks the door is shut and is waitin g for you to open it, a swtich must of gone bad, the console will reove with a few screws inside the door panel anbd give you acess toi the door latch/switch assy
Posted on May 12, 2008
Bosch Dishwasher wont run full cycle. Stops/Beeps and says CLEAN.
Hello there,
Could you please supply the full model # off your appliance?
Mar 12, 2014 | Bosch SHX4AP05UC Dishwasher
Door locked
Your door lock mechanism failed. Needs to be replaced
Apr 11, 2013 | Thermador RDFS30 Dual Fuel (Electric and...
The clean light is blinking diswasher won't start
Push these buttons in this order High temp wash > Heated dry>High temp wash >Heated dry all the lights will come on and this will reset the board and run it through a short test cycle but more than likely it will come up again,It's a failure in the heating cycle either the heater itself or the turbidity sensor which sits mounted up into the tub right behind the drain pump...hope this helps
Sep 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light flashing diswasher will not reset
press two option button in a sequence- high temp-heated dry-high temp-heated dry.all lights should come and unit will go into diagnostics mode.let it complete the diagnostics mode it will take abt 3-5 min.open the door and u should be able to start the unit.it is a heating err code.if comes back gaing the heating elemnt needs to be chkd.
Aug 17, 2009 | Dishwashers
X5 - Overhead light not turning off and all doors are closed.
Check and adjust or clean the switch on the back passenger door.
May 26, 2009 | 2002 BMW 5 Series
''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Apr 01, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Clean light flashing and unit wont run
you can open the lowe racess panel of d/w and you find a techsheet/ trouble shooter, in ther they will explain how to reset a clean light blinkin 7 times.. you can try pushing the "sani-rinse"---"heated dry"--- "sani-rinse" --- "heated dry"... toggling these buttons will triggor a test mode, youl know your in it for all the lights will light, close the door and wait 30 secs or so, the reopen door and cancel cycle, after it runs for 2min it will be ready fro you to start using again.. of the clean light issue returns, id recommned calling for service
Jan 24, 2009 | Whirlpool Dishwashers
2005 toyota sienna le - back doors won't open in cold weather
iv had a few people come in with that complaint I clean inside of door and spray seal with good 100% silicone spray and spray latches with penetrating oil
Jan 13, 2009 | 2004 Toyota Sienna
Oven door won't unlock
I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
Feb 16, 2008 | Kitchen Ranges
Kitchenaid dw clean light still blinking/ machine won't run...
I tried the following sequence, as recommended on a similar blog and it worked!
Open door
Quickly press :
Hi Temp Scrub
Energy Saver Dri or Heat Dri
Hi Temp Scrub
Energy Saver Dri or Heat Dry
Close door
All lights should come on
then clear and revert to cycle.
Feb 28, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
127 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
