Question about Jura Capresso Impressa E8 Espresso/Coffee Maker
Dual Frother Plus
The Dual Frother Plus on my Impressa S7 does not stay connected during steaming/frothing. I already know about the small holes that need to be cleaned. I'm thinking an O-ring needs to be replaced. Any suggestions? Thanks!
  • 41 Answers
Contact Jura, this is a recall issue and they will replace it for free. Beats getting burned from the steam. The new part has fewer pieces and is easier to clean.
Posted on Jun 08, 2008
Hi, the steam from the wand is not frothing the milk like it used to, hardly any froth at all.
If the frother is warming the milk, but is not frothing, then you want to make sure the panarello is clean.
Slide the cover off the frother and check the pin hold on the top edge of the cover. If this hole is blocked the milk will not froth. Rinza is great clean to help prevent these issues.
Also recommend frothing water instead of milk to clean the frother well.
For more information visit:
Jun 07, 2011 | Gaggia Brera Coffee Maker
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
Water Leaks from the head gasket while heating up to use steam
This is a result of the water temperature in the boiler increasing, thereby expelling water that may remain in the lines out of their respective exit points. A solution may be to place a container under the group head to catch the water, or opening the steam valve partially to allow the water to exit through the steam wand (again placing a vessel/cup/pitcher there to catch the water). This is a problem that even higher end (dual-boiler) models have, due to the necessary purging of water that accumulates in the steam wand during down-time.
Don't look at it as a problem, but simply as a quirk that single-boiler machines have. If you are still irked by the issue, consider buying an inexpensive manual frother (Bodum makes these) to froth and heat your milk (in the microwave after frothing) separately. An added plus is that you can do this while you make your espresso, so if you make primarily milk-based drinks (latte, capps etc.) you'll save on time.
Dec 21, 2009 | Saeco Starbucks Sirena Espresso Machine
The frother tube has started to leak during brewing.
The steam-frother valve have scale or dirt. You have to clean and descale the valve inside the machine.
Dec 13, 2009 | Jura Capresso Impressa F7 Espresso Machine
Frother builds up too much pressure and explodes off the machine
I had the same problem. All you need to do is take the steam nozzle apart and clean it. I tip can be cleand with a neadle. Just make sure you unblock the little side holes and make sure to thoroughly clean the little hole in the front. Over time the milk builds up in the nozzle, clogging up the "steam holes", so the preassure gets too big and the rubber attachments can't hold it any longer. Hope that helps.
Jun 05, 2009 | Jura Capresso F8 Espresso Machine
I have my Incanto Deluxe for about 1 year. I have never had any problem making a good quality froth, but recently the frother is producing too much air and milk is becoming bubbly. I am religesly clean my...
I think you have a chrome steam wand end.
To froth properly, there is a very small hole on the side of the chrome steam wand that injects small bubbles into the milk, the hole is located aprox 1/4" down from top of the chrome wand, if this hole blocks up you can only heat the milk, not froth. I commonly use a stripped tin tie wire or a sewing needle to clear the hole . Clean the hole,do not enlargen the hole.
Mar 02, 2009 | Saeco INCANTO DELUXE Espresso Machine
Frother doesn't froth
Does not seem normal! You should get plenty of steam for the frothing. Since the unit is new you should take it back and get a replacement. The unit needs to increase the temperature for steam, route the steam away from the espresso group to the steam unit and the pump needs to activate to create the high pressure. Any failure in this areas will create your condition. It also possible that your steamer is blocked but this is a new machine so this is unlikely but you should make sure that it is not blocked.
Sep 12, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Steam and froth malfunction
The milk can not be room temperature.  It needs to be cool, does not have to be fridge temperature but can not be warmer than room temperature
Feb 18, 2008 | Jura Capresso Impressa Z5 Espresso/Coffee...
Steam wand used to make great foam until just a week ago
The stainless steel cover has a very small hole near the top. The hole allows a venturi action - meaning air molecules are entrained with the steam flow to increase the affect. Milk will clog the hole, but warm water and a guitar string, cheese wire, even a staple - something thin - will work to clean it out.
After frothing either clean the entire stainless steel piece or at least occlude the end at the same time as shooting through some steam. I usually use a kitchen sponge with the abrasive pad attached. The pad helps insulate the heat and provides the necessary resistance to force any milk out the small hole.
Yes, I hate living with this also. In fact I am considering machining a different steam tube assembly.
Oct 05, 2007 | Saeco Incanto Rondo Fully Automatic Coffee...
Jura Capresso Impressa E8 Espresso/Coffee Maker Logo
450 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
