Question about Jackson 24 in. JPX-300H Built-in Dishwasher
After sitting unused for over 1 year but less than 2 I have put this machine back into service it is leaking from bottom of unit. would this be a seal or something more serious or common to this machine
  • Jackson Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
ljsdoiuhsga
Posted on Sep 29, 2010
Tip
Make your Lithium Laptop Battery last longer.
Hello folks,
Although I usually offer advice on backing up files or recovering them, I have been asked a lot lately how my 3 year old laptop still runs 1:45mins on a standard battery when many peoples 1-2 year old laptops can barely last an hour.
Simply put, most people do one of two things wrong. Both are common misconceptions and easy to remedy. First I've heard countless people tell me they pop the battery out of their laptop and toss it in the desk drawer until needed, often months. Second I have been told by more people than I can count that they leave their laptop plugged in 24/7 for most of the year.
Bottom line, although popping it out and leaving it in the drawer is less harmful to it's lifespan, both ideas are wrong.
The shelf life of most unused lithium batteries is shorter when unused than ones being used properly. The lifespan of a battery that is constantly being trickle charged is even shorter.
Most batteries in modern laptops are 4-6 cells, designed to give about 2 hours of charge and should last 3-5 years with charge life starting to degrade in the third year.
A "stored battery" has only 3 years of shelf life due to extended times sitting discharged and one that is trickle charged 24/7 may burn out in as little as a year.
Many laptop manufacturers have taken measures to improve this but ultimately the best thing for your battery is to use it. If you currently run you laptop plugged in 24/7, unplug it every night after you shut it off, then when you start it in the morning, let it run an hour before plugging it back in. This will give the battery both down time and exercise.
If your battery is in a drawer somewhere for safe keeping, put it back in the laptop, run it down then charge it over night and run it down then recharge it one more time. Store it back in the drawer charged and repeat the cycle at least once a month.
These tips will help drastically improve you batteries performance over time. My 3 year old laptop only ever got 2 hours of battery life and still gets 1:45 with no power saving measures, give it a try.
Crankstart
on Mar 20, 2010 | Computers & Internet
My Bosch WAE24367 washing machinet
check hose from the tub to the exit point you have a blockage
Jan 02, 2014 | Washing Machines
Leaking like crazy and only 2 1/2 years old. Where are the screws so I can take the bottom panel off?
Their are 3 screws holding the front lower panel onto this unit.If you can tip the machine back some and put a block underneath it will help you see and remove the screws ,I believe they are 1/4 inch or t15 torx... If the unit is leaking that bad before tearing apart carefully run your hand around the lower section of the door boot (rubber) and inspect for a tear or a hole Hope this helps you out GOOD LUCK
Sep 04, 2010 | Kenmore HE2 Plus Front Load Washer
Leak from bottom of window unit
The unit needs to be tilted outware. The outside (back) of the unit must be at least 1/4" per foot lower than the front. If you have 2' sticking out, the back must be at least 1/2" lower than where it sits on the window sill.
Aug 10, 2009 | Maytag NMPEB08F2A Air Conditioner
Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Apr 29, 2009 | Bunn 10 Cup Home Coffee Brewer
Fujitsu asu24cl blinking lights
This machine is a looser. Mine has same blink codes. Its been serviced every year since it was installed 3-4 years ago.. Since the elctric work was half the cost of installing it, maybe Ill put in a differnt brand!
Aug 11, 2008 | Fujitsu 24C1 Air Conditioner
I have a first generation Maytag Neptune washer and dryer front load. The washer is making a terrible noise in the rinse cycle like an airplane taking off, and some water leakage from underneath. My...
You won't get near the life of your old maytags out of any machine you buy now days (average life is about 5-7 years). Your description, likely sounds like a bad tub bearing. The easiest way to verify this is pull the washer forward and crawl back behind it. Remove the screws (1/4" or 5/16", I forget which) on the access panel located in the middle back of the unit. Once you take that off, you will see a large silver pulley. Severe bearing you will see orange discolloration from where water has been leaking. Of course if yours is noise only and the leak is coming from an un-related area, you can also test by putting the machine in a spin and listening by the back pulley. BE VERY CAREFUL, THIS IS SPINNING EXTREMELY FAST AND IS VERY DANGEROUS IF YOU GET TOO CLOSE. If I am correct and the back bearing is bad, it takes 2 trained techs about 1 1/2 - 2 hours to replace the tub (which the bearing is molded into) So cost wise you'd be looking typically from the 300-500 range for replacement. The part itself is usually 150-250 of the price depending on where it is purchased from. I'm sorry I know this isn't the answer you hoped to hear, and I do hope that I am off target, but this will save you a service call fee by doing a simple check. If I am right and you want to keep using your unit until you can afford a new one, there are plastic pans availible a local appliance parts stores and even some harware stores you can set the unit in to keep it from leaking on the floor. This is an inexpensive alternative while saving up and still getting your laundry done.
Jul 16, 2008 | Maytag Washing Machines
Water leaking
Leaking pump or drain connexion most likely you will have to get under to check it out. Put a several sheet to news paper under the machine and pull it out as it stands to see where the water is coming from front/back/sides Do a wash and repeat. But you will need the service of an engineer I guess unless you are good with a wrench.
Aug 05, 2007 | Kenmore 43142 Front Load Washer
LG WD-8016C Front Load Washer leaks from the bottom
Crawls, usually all leaks are visible. Im surprised the repairman did not actually get to the source of it. Your drain pump sits on the bottom and it possibly could be the filter cap, hoses to the pump or pump itself. Another area to check is the despensor. There are a number of hoses to this which could be leaking. The bellow itself could have a cut in it somewhere along the bottom. I would call the repairman back and have him at least get to the source of the leak...Catriver..post back.
Aug 14, 2006 | LG WD-16115FD Front Load Washer
Jackson 24 in. JPX-300H Built-in Dishwasher Logo
207 people viewed this question
Top Jackson Dishwashers Experts
jhnolson
Are you a Jackson Dishwasher Expert? Answer questions, earn points and help others
