Question about Samsung Healthy Living Bsp 4007 Premium Deluxe Thinline See Thru Flat Screen Blood Pressure Monitor With Irregular Heartbeat Detector
When attaching the end connector to the cuff hose, it was done incorrectly. to correct it made the hose about an inch shorter. Does this change the accuracy of the readings?
    Scholar:
  • 192 Answers
No..... The machine is operated based on pressure, no matter how it is there, so short or long, you just have to make sure the cuff is big enough and you are fine..... Guy
Posted on Sep 06, 2010
How do I add knit band to pajama pant on McCalls pattern 7975. I have lost the directions.
Usually the cuff ribbing is cut double the required length plus doubled seam allowances (ie 3" x 2 = 6; add two 5/8" for seams = 1.25"'; equals 7.25" long). It is doubled so when it is folded in half and stitched to the leg, there will be no seams showing outside). The width of the ribbing is probably an inch or so shorter than the leg bottom--it should be large enough for the foot to fit through but tight enough that it hugs (not squeezes) the leg.
Sew the cuff together lengthwise to make a circle. Fold it in half with the stitched seam inside. Then fold the circle widthwise with the seamline at one end. Mark the halfway point opposite the seamline. Then fold in half again with the seamline and the first pin matching together. Mark the other two ends. You've divided it into equal fourths. Repeat the same procedure marking the pajama leg in fourths. Then match the seamline of the ribbing to the seamline of the leg (right sides together). Match the other three marks on the cuff to the three marks on the pajama leg bottom. You'll have the stretch the ribbing because it should be a bit smaller in circumference than the leg bottom. Stretch the ribbing to match the leg bottom and stitch the ribbing and leg bottoms together. Turn right side out.
How to Attach Knit Cuffs to Sleeve Shirt Sleeves
sewing with knit fabric how to sew sleeve cuff with knit fabric
Jan 02, 2016 | Sewing Machines
Step by step instructions to change thermostat
Since u gave no specific car info, generally the thermostat is at the end of the top radiator hose where it attaches to the engine block. Remove top hose at engine. Remove the two bolts that hold hose connector to engine block. The thermostat is between connector and block. Lift out. Replace. Put everything back together. Fill radiator back up. Ur done.
Mar 26, 2015 | Cars & Trucks
Error 3 is showing on my monitor ... What does it mean ?
On other blood pressure monitors from Life Source, the error 3 means that the blood pressure cuff isn't inflating properly. The cuff could be incorrectly fastened or the air connector is backwards or not connected to the cuff or the monitor. Check this on your monitor.
I hope this helps.
Jul 08, 2014 | Health & Beauty
I have a new dc17 not happy with the stair attachment. The connection to the arm does not seem very secure and the power isn't as strong as the unit is. I find your manual of very little help. Please...
I'm sorry to hear you're having difficulties with your DC17. The dusting tools supplied with the cleaner attach either to the end of the wand, for high- and low-reach cleaning, or directly to the hose cuff for tighter spaces. They simply use a friction fitting to attach securely onto the end of the wand, or into the hose cuff, depending on your requirements.
For further advice, you might find it helpful to refer to our online support guide:
http://www.dyson.com/support/help.asp?article=977&product=DC17-ANIMAL
Alternatively, if you'd rather speak to someone in person, you can get in touch with us directly by calling free on 1866MYDYSON.
Kind regards,
Jack
Dyson Online Customer Support
Sep 10, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
It keep giving me a ee reading every time i try to use it
Hi. One of the most common error symbol that appears on this display panel is a EE with a down arrow and two numerals. The reason for the EE Error Indicator is usually caused because the cuff has been wrapped too loose. The cuff was under-inflated during the measurement. This error will also display if the cuff is worn and needs to be replaced. The EE symbol with a down arrow indicates the cuff is over-inflated. In most instances the cuff has been wrapped too tight or you are using the incorrect cuff size. Turn the monitor off. Read the instructions to correctly apply the cuff. Wait five to ten minutes then take another measurement. This should correct the issue.
Aug 19, 2010 | Omron Model HEM 432C Manual Inflation...
Cuff won't inflate
It probably has a leak. Examine the hose and cuff for cracks by flexing it , especially at the fitting where the hose attaches to the monitor. Also check where the hose attaches to the cuff. Try replacing the cuff.
Hope it helps. Please let me know.
Thanks
Apr 22, 2010 | Mabis Automatic Digital Blood Pressure...
Washing machine drain hose too short
add extension with hose clamps will be fine
May 26, 2009 | Washing Machines
Remove connectors off hose
Are you talking about the hose cuffs? If so, put the cuff in a vise and squeeze it until you see the locking tabs and using flat blades, pry the hose out from the cuff.
Apr 07, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore cannister vacuum tube - reattaching connectors
Make sure that the two prongs that go over the hose are going in the correct slot in the cuff. If in the wrong one, the cuff won't snap into place. I have had to slam the end of the hose on the work bench while holding the cuff to push it all of the way on. Some I have heard warm up the cuff in hot water or a hair dryer to make it more pliable.
Mar 27, 2008 | Kenmore 22822 Canister Vacuum
Hose Problem
Looks like you can just get the hose, part #38479-4, It should just screw into the adapter or it may be glued in.
Nov 14, 2007 | Eureka Sanitaire SC4570 Bagged Upright...
Samsung Healthy Living Bsp 4007 Premium Deluxe Thinline See Thru Flat Screen Blood Pressure Monitor With Irregular Heartbeat Detector Logo
185 people viewed this question
Top Samsung Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
Joe Ball
Joe Ball
Are you a Samsung Health and Beauty Expert? Answer questions, earn points and help others
