Question about Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5
The motor seizes up every now and then, what is causing this ?
  • 27 Answers
Could be water/ rust from condensation getting inside the motor. This is not uncommon with compressors that do not have a bleed-off valve to let out air and water. Possibly an in-line water separator will work.
Frank
Posted on Feb 08, 2011
My kenmore 22 stitch sewing machine I bought in 1990; it doesn’t reverse anymore. How do I fix it
Those older machines do need regular cleaning and oiling. I suspect the oil has dried and caused the switch mechanism to seize. As time goes on, more parts may seize, so it's probably important to get it addressed soon. It could eventually damage the motor if the motor is trying to move seized parts. Well worth the expense if you value your machine.
Mar 19, 2018 | Kenmore Sewing Machines
Dewalt dcd996 20 V cordless hammer drill three speed combo stopped working what are probable causes and issues
hi
possible cause sticky or worn brushers faulty battery or connections seized cable from the battery holder to the motor or seized motor
Dec 31, 2017 | Dewalt Drills
Back wipers and washer keeps fusing
This is caused by either a broken wire or, more likely, a seized motor. When the motor is seized it has to draw a lot more current to try and work, this will blow the fuse. Check the motor and wiper arm are free to move easily.
Apr 29, 2013 | 2004 Rover 25 1.4
My spa will hum when turned on but will not push water. The motor then turns off.
The pump seized up or the motor bearings went bad and seized up...
Bottom line is that you will need to remove the pump and motor and take it apart to figure out what is causing the problem....
heatman101
Aug 29, 2011 | Whirlpool Home
Motor starts then stops i'm thinking bushings in motor
There could be two issues here there is whats called a soft start module in the motor that could be causing you problem, when the motor gets up to speed it shuts off, replacing the module will solve that proble. Or it could be the rear armature bearing has seized, usually they seize so tight they will stop the motor rotation.
Dec 28, 2010 | Bosch 4100 09 10" Worksite Table Saw...
Mine does not want to start. Uses up to much pwr and kicks off
http://www.ereplacementparts.com/
I can think of many problems that could cause what you are experiencing.
Are your using a long, small gauge extension cord? Too long and too small of a cord will starve a motor of the power it needs to run properly.
Check the oil level. If the oil is too low the piston can seize to the cylinder. Too much oil can cause excessive pressure in the cylinder, stopping the motor.
There could be a bad bearing. A seized bearing can cause enough resistance to stop the motor.
There are a couple of capacitors on the motor. At least one of them will be used to help start the motor. A motor shop can test them to see if they are both working properly.
Those are the most likely causes. You will need to do some testing to figure out which is causing your problem.
May 21, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Timer causes pool motor to seize up
I do not see any connection between the timer and the pump unless you are losing prime after the pump shuts off. Upon restart, your pump might not be primed to pump the water.
Jul 08, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
With the Kenmore series 80 Dryer plugged in, Pressing the start button causes the motor to hum as if the belt, pully or motor is frozen. The drum doesn't turn during the humming and is difficult to turn...
You'll need to remove the back panel and determine the cause. Look for:
Seized drum support rollers (3)
Seized drive and/or idler pulleys
Burned out or seized motor
Possible bad motor start capacitor (if equipped)
Drum alignment
Mar 29, 2009 | Dryers
Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5 Logo
88 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
