SOURCE: how to change a ge refrigerator light bulb
It snaps in place by lifting the plastic cover. Then when you replace push it in then down. It has two tabs one on each end.
SOURCE: Dispenser Light broken
you can just unplug the refrig and use a pair of needle noase pliers to remove the base then install a new bulb it can not be over 10watt a night lite one works great (7watt) this will be a better solution that dissably. the panel
SOURCE: light bulb in FAB28 Fridge
Just squeeze the light cover and it should pop off forwards (ie. away from the fridge side.
SOURCE: LG refrigerator GR-B258jvc - replacing light bulb
There are usually 3 or 4 locking tabs on the cover that just need to be pressed INDIVIDUALLY toward the bulb to release them and then carefully remove the cover. The ones with 3 tabs usually have and upper and lower tab then the thrid tab is on the side. Removed the upper and lower tabs by pressing inward to the bulb and then the cover will pivot out on the 3rd SIDE tab.
Thanks for using FixYa.
Kelly
