Question about SanDisk Sansa Clip MP3 Player
Clip not reconizd
Tried the hold center button bizness no luck... installd pak from microsft no luck.. my device manager has yellow !!!!! marks and i no thats the prob but dnt no what to do next?
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 28, 2008
Error code c1144
I have 5 biz hub 654s. There is no "utility" hardware button. Instead, open the front cover (marked "biz hub 654") - switch off the main power - white switch in an orange rectangle. Wait 30 secs. Flip back on- then QUICKLY close the door while holding down the yellow RESET button. "Trouble reset" appears - tap it - OK appears below it. Use main power to power down. Wait 30 seconds. Power back up. Works every time.
Nov 01, 2012 | Konica Minolta Office Equipment & Supplies
DVD will not eject on my toshiba laptop
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
if there is a small hole on the panel of your dvd drive push a staightened paper clip inside until you feel it press down this will open up the drive
hope this helps
Jun 08, 2012 | Toshiba Satellite A100, A105, A110, A130...
WEBCAM NOT DETECTED
1st You download Webcam Driver.
WEBCAM NOT DETECTED
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Apr 29, 2012 | Logitech Webcam
Tried to download music to phone and mp4,pc says connect device but it`s already connected.pc windows vista
go to device manager ..hit delete the USB controllers and Root Hubs ....BIOS update ....ms-config ..hide all microsft services put a check mark ..restart
In XP and Vista Try to create a new user account if this does not work
Mar 21, 2010 | Computers & Internet
Mp3 player malfunction
1. Try updating the drivers-
- Right click "My Computer", choose properties
- Click the hardware tab and choose Device Manager
- See if you find the name of the device there - if yes, Right click on it and choose "Update Driver"
2. Try changing the mode to MTP
3. If nothing works, unplug the USB cable, Lock the device, Push the round button in the middile of the Sansa player, continue holding it and plug in the USB cable.
4. One more option you could try -
  • turn off your mp3
  • press the hold(lock)button down to activate it.
  • press the center button and keep it pressed ..
  • connect the USB cable supplied with the device always pressing the center button,
  • connect the other end of the cable to a USB jack on your PC.
  • From there it should work properly.
Dec 14, 2009 | SanDisk Sansa Clip MP3 Player
LOST INSTALLATION DRIVER
http://download.cnet.com/Microsoft-LifeCam-VX-3000/3000-18489_4-99162.html
dowload from here
hope helpful
May 30, 2009 | Microsoft LifeCam VX-3000 Web Camera
Trying to hook up internet
Hello
Please check whether the Wireles s button is on and there are any yellow marks in the device manager.
Click start and select Run. In the Run box type devgmgmt.msc and press enter. This will open device manager. Then click on + sign next to network adapters and check whether the wireless adapter listed and any yellow marks beside it.
If there is no yellow marks beside the wireless adapter and it is listed in the device manager. Then try to install Wireless drivers and reconfigure wireless network.
Thanks
Regards.
Jun 21, 2008 | HP Compaq Presario V2000 Notebook
Windows xp will not detect creative zen vision w
There are many possible reasons:
1) USB port is not 2.0 - previous usb ports are too weak for anything but charging - go into hardware device manager and see if their is a yellow exclamation by the USB port
2) You have not downloaded the installation CD with key drivers - download the cd
3) windows is missing drivers - -go into the hardware device manager and see if there is a yellow exclamation mark by the mp3 player icon
Creative's website has an FAQ addressing the exact question you have asked
If all else fails,
-Tha mp3 Doctor
Jun 18, 2008 | Audio Players & Recorders
Sansa clip mp3 player
To help you with that, I need to know what operating system your using (XP, Vista, ect...) and what other devices you have plugged into the computer. There are a few things you can try. When you plug it in, does it say it's connected? Does the "Found new hardware" wizard come up? Let me know, I'll see what I can do to help
Dec 31, 2007 | SanDisk Sansa Clip MP3 Player
Audio
Hi, Confirm that there is an audio device installed in your PC > right click on My Computer, Properties, Hardware tab, Device Manager button, expand Sound, video and game controllers, It's got to be there, with no yellow or red marks. Also in Start, Control Panel, Sounds and Audio Devices, Audio tab, you should have something in Default device. If none likewise in Device Manager or a yellow or red mark, you have to re-install your drivers by right clicking on the mark and click Update drivers. If they're there with no marks, ensure that they are enabled. Perhaps further assistance maybe made available if you can post brand/model of your PC and/or motherboard. Good luck and kind regards.
Aug 23, 2007 | Microsoft Windows XP Professional With...
SanDisk Sansa Clip MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
