Question about Philips Magnavox 27MS343S 27" TV
No menu button on my old philips tv cant get all the channels,it only has the sleep button,the captions button,channel up and down,volume up and down and the power button,cant get the channels to auto programme,even the universal remote i have doesn't pull up the menu.
ThaMp3Doctor
  • 8596 Answers
SOURCE: magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Posted on Jun 14, 2008
  • 111 Answers
SOURCE: Auto Search Function won't work...."can't set auto search"
Make sure that you have the cable option set correctly before you do the auto search. If this is set to "AIR", you'll only be searching for an analog signal. Hope this helps.
Posted on May 24, 2009
  • 188 Answers
SOURCE: philips 21rf vardan tv
Check option code's.
Posted on Jul 29, 2009
  • 10 Answers
SOURCE: Philips Magnavox 2783 c101 - will not auto program tv channels
Ya what you got to do is Grab your tv, and throw it out your window. Garbage tv with built in problems made to be fixed. I had the same tv and i had many problems with it before. Just buy a new one boss.
Posted on Feb 17, 2010
SOURCE: Philips PC7225 hotel TV - can't access the menu to reprogram it.
The code 0621 isn't working for the PC7225 TV on my philips RC19335027 remote. Is there any other code I can try.
Also I purchased an RCA - RCR311BT remote and programmed for the tv and the code 0621 isn't getting me to the setup menu.  Is there any other code I can try or special way to enter the code in to get to that setup menu?
The ultimate goal is to change the default startup station from channel 53 to channel 3. Thanks.
Posted on May 06, 2010
I lost the remote. how can I open the caption on philips 20PT6245/37
you can buy a universal remote or on some tvs you can access the menu by either hitting the volume up and down buttons at the same time or it might be the channel buttons so i would try both.GOOD LUCK!!!!!!!
Dec 24, 2010 | Philips 20PT6245 TV
Phillips TV with no on screen menu, only Caption, Text and Sleep. bought TV's from factory auction. PA5032-C102. or 32R505-00BB.
The OSD (on screen menu) is locked. Those two serials (not models) are for two completely different tv's: the first is for an very old standard 32 inch CRT and the second for an old plasma.
To unlock it in the first tv you need to just press the menu button for 10 seconds. For the second tv you must start the tv and immediately press both the menu and channel up buttons for 5 seconds.
Dec 15, 2010 | Philips Televison & Video
My TV seem to be on wide screen and it shows half the picture, how do I set it up on full screen? No other material is connected to the TV
Hello
If your TV displays a black box type shade on the screen means that your TV may be set to "Text" mode. To clear the screen, select "Caption Off mode".
To do this, press "MENU" button to display menu functions on the screen. Press "channel up or channel down" button to select the function "CAPTION". Press "Volume Up or Volume Down " button to select the mode you wish. There are five modes that you can select; Caption-Off; Caption-C1; Caption-C2; Caption-T1 and Caption-T2. As no other matereial is connected to your TV, you just select "CAPTION-OFF". When done press the Menu button again to exit menu display. Ok.
Oct 22, 2010 | Durabrand DWT1304 13" TV
I have a philips I got from a hotel but i cant program the channel to 3 to hook up a dvd player even with a universal remote what do i do?
Channel 3 is probably locked out... here is how to fix it....
1) Press the Menu button on the remote or press both Volume buttons on the front of the TV to access the TV's internal menu's
2) Scroll to highlight INSTALL using down arrow on the remote or Channel - on the front of the TV.
3) Press the Right Arrow on the remote or Volume + on the front of the TV to access the INSTALL menu.
4) Scroll to highlight Channel Edit using down arrow on the remote or Channel - on the front of the TV.
5) Press the Right Arrow on the remote or Volume + on the front of the TV to access the Channel Edit menu.
6) Use the Left or Right Arrow on the remote or Volume + / - on the front of the TV until you get to Channel 3.
7) Use the Down Arrow on the remote or Channel - button on the front of the TV to select SKIPPED.
8) Press the Right Arrow on the remote or Volume + on the front of the TV to select OFF.
9) When finished press Exit on the remote or press the power button on the TV and then power the TV back on.
You should now be able to use channel 3.
Good Luck....
Jan 15, 2010 | Philips 20PT6441 20" TV
I have problem with our Magnavox TR2510C101. My toddler press everything and now it turns out there is black screen (square) cover the image. Do you know how to fix it? thanks!
You have accidentally gotten the Closed Caption turned on....
Here is how to turn it off....
1) Press the MENU button either on the front of the TV or on the original TV remote.
2) Use the Volume + or Volume - to highlight "SET"
3) Use Channel - or Channel + to highlight "CLOSED CAPTION"
4) Press Volume + to access the CLOSED CAPTION menu.
5) Press Channel - or Channel + until OFF is highlighted.
6) Press Volume + or Volume - to confirm selection.
7) Press the TV/AV/EXIT button on the remote to exit or the MENU button on the front of the TV.
GOOD LUCK and please rate this solution...
Jan 14, 2010 | Philips Magnavox 27MS343S 27" TV
Can't get closed caption off of television
If you have the original remote use the closed caption button to turn it off. Without the remote, hold down both volume buttons on the front of the tv to bring up the menu. Use the the channel and volume buttons to navigate in the menu. Select the center icon at the top of the screen. Go down to closed caption. Select OFF. Wait for menu to go away.
Mar 05, 2009 | Sansui DTV3200 32" TV
Remote and caption problems
have you programmed the remote? or you can go into the menu button on the front of the tv, use the up down (either the volume or channel may move the selection) to locate the caption on/off control and turn it off that way. if you need the manual try here
http://tv.manualsonline.com/manuals/mfg/philips/19_inch_color_tv_cover_l9_pr1903c1.html
Dec 02, 2008 | Philips Magnavox Learning Universal Remote
Cannot get 27" magnavox closed caption
I called the Magnavox tech support - put the TV on channel 2,
hit the cc button repeatedly and problem solved.
thanks for contacting me.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
Multiple issues with tv
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Feb 21, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Philips Magnavox 27MS343S 27" TV Logo
433 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
