What is the difference between glass fibre reinforced concrete and ordinary reinforced concrete?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 88 Answers
Rats can chew through glass fibre, don't know if thats the major difference but I do kno that is true.
Posted on Sep 04, 2010
What is the advantage of adding glass fiber in concrete?
Fibers are usually used in concrete to control cracking due to plastic shrinkage and to drying shrinkage. They also reduce the permeability of concrete and thus reduce bleeding of water. Some types of fibers produce greater impact-, abrasion-, and shatter-resistance in concrete. Generally fibers do not increase the flexural strength of concrete, and so cannot replace moment-resisting or structural steel reinforcement. Indeed, some fibers actually reduce the strength of concrete.
Dec 07, 2016 | Cars & Trucks
What type of plants is there in the forest
Surya Aranya trees, made of a metal pipe structure and a cluster of 14 panels, with the trunk and leaves represented by fibre-reinforced plastic,this is a mystical place,not real.
Mar 11, 2015 | Surya Forest
NEED INSTRUCTIONS FOR EPOXY REPAIR KIT
If repairing a fibre glass bath you have to understand that the main bath is fibreglass and resin with a top coat . grind back to fiberglass top and bottom of repair , to reinforce place fibreglass patch mixed with resin under bath = top is jel coat . after repair cut back with wet and dry emery cloth .and polish= easy yes.
Mar 30, 2014 | Maax Home
Scanner glass
I use warm water with a tiny bit of washing up liquid. I use a micro fibre cloth dip it in the water, wring out until vertually dry and clean the glass. Use a dry micro fibre cloth to dry. Do not use glass cleaner.
Jul 10, 2012 | Epson Stylus Photo RX700 All-In-One InkJet...
What is the best way of repairing cracks on plastic fairing
If it's a crack from fatigue you'll need to stop it spreading, you can drilla hole at the end of the crack to do this, apply a glass fibre sheet or two to the back (over lay the area by about 2ins all round) to reinforce the fairing, on the outer side fill with plastic filler and sand before paint.
Aug 07, 2010 | kawasaki GPZ 500 S - GPX 500 R Motorcycles
What is post tension slab
It is a slab of usually Concrete that has Tension introduced upon it's Reinforcing rods/cables, AFTER it has been Poured, dried/set as opposed to a Pre-tension slab whereas the Tension is put on the reinforcing rod/cables inside the concrete and are Tensioned BEFORE or While it drys/sets
Mar 05, 2010 | Mathsoft Civil Engineering Library (46505)...
Glass reinforced concrete composite stone table broken
Believe it or not Gorilla Glue holds that sort of thing quite well. You may have a visible line, but not too bad providing you keep the pieces held together tightly for an hour or so (it foams and expands -- scrape off the excess after it dries.) I would also get some epoxy (the thin stuff, not the putty stuff) and some fiberglass mesh and reinforce the bottom. Something else -- some contractors who do foundation repair have an epoxy and carbon fiber mesh that would do that and be indestructible -- see if you can find one in your area. I could give you someone in my area, but that probably wouldn't help you. You'll have to call around. If you can't find it, the fiberglass mesh is used in boat, RV, and tractor trailer repair so one of those shops should be able to sell you some.
Nov 02, 2009 | Welding Tools
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
