Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
I am trying to change the print cartridges for my father without a user guide and the head will not come into the middle. Can you tell what buttons to press.
    Problem Solver:
  • 5 Answers
Go to your printer on your computer , select the ink supply levels and your program should instruct the printer to bring the cartridges to the centre
Posted on Sep 05, 2010
Error 5200 - How to reset canon pixma MP970
1- Unplug it
2- Open the top and bring the ink cartridge holder to the middle
3- Raise the gray bar and remove the print head assembly with the cartridges in it
4- Lower the gray bar with the head missing and close the top with the head out
5- Restore the power,wait til the printer wakes up
6- It will tell you to put in the cartridges
7- Restore the print head, close the top and the printer should resume working.....
Aug 06, 2014 | Canon PIXMA MP970 InkJet Printer
How to remove epsom NX400 print head
The print head on the NX400 printer is integrated into the ink cartridge and therefore when you remove the cartridge you are removing the print head. . . If you want to clean the print heads / nozzles then see the procedure in the NX400 User Guide in the section for Adjust Print Quality. . . .The User Guide can be found at http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=106004&prodoid=63075469
Sep 19, 2011 | Epson Stylus NX400 InkJet Printer
Error Number : 5200 A printer error has occurred. Turn the printer off and then on again. If this doesn't clear the error, see the user's guide for more detail. I have tried turning it off and...
Hello and Welcome to FixYa!
Error number 5200 is a
service error. To solve this error follow the given steps:-
  1. First of all unplug the printer
  2. Open the top and bring the ink cartridge holder to the middle
  3. Raise the gray bar and remove the print head assembly with the cartridges in it
  4. Lower the gray bar with the head missing and close the top with the head out
  5. Restore the power,wait till the printer starts
  6. It will tell you to put in the cartridges, Put in the cartridge
  7. Restore the print head, close the top and the printer will resume working
Error will be removed.
If you have already tried all of the above and still you have error then it is probably that your Canon printer is in need of servicing by a service professional.
Any more confusion, queries or for further assistance, I am here to help.
I hope this solution helps you
Thank you for using FixYa!
Jun 07, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Pls let mr know Error number 5200 for printer Canon Ip 2700
I have found a solution for your problem. (1) With the printer turned on, unplug it (2)Open the top and bring the ink cartridge holder to the middle (3)Raise the gray bar and remove the print head assembly with the cartridges in it (4) Lower the gray bar with the head missing and close the top with the head out (5) Restore the power,wait til the printer wakes up (6) It will tell you to put in the cartridges (7) Restore the print head, close the top and the printer should resume working..... ;)
bhupi
May 03, 2011 | Canon Office Equipment & Supplies
Have not used my Epson R1800 for almost 6 months. When I turn on the power the printer head, with the cartridges, stayed at the very right end, not moving. The paper and ink lights flash and the head just...
Your User's Guide is available here:
http://files.support.epson.com/pdf/r1800_/r1800_ug.pdf
After leaving the printer inactive for a extended period you should expect the ink cartridges to be dried up and the print head 'gummed' in place.
You will need to refer to page 82 of the pdf, Cleaning the Printer.
As part of cleaning remove the existing ink cartridges and while the cartridges are removed try and clean the print head of any ink residue. Note that if the red light is on or flashing above an ink cartridge the printer sees it as empty (dried up).
The print head will not move if ink cartridges need replacement; replace ink cartridges according to the red lights, likely all. Press the ink button to see if the printer will begin the charging cycle. If all is well the green power light will stay on and the red ink light will go out.
If you do not get this desired outcome try Cleaning the Print Head, page 73 of the User Guide. Hold down the ink button when the red light is off for 3 seconds. Run a nozzle check pattern; if nozzels are not printing a clean pattern, repeat this process up to 3 or 4 times.
Feb 03, 2011 | Epson Stylus Photo R1800 InkJet Printer
How do I install my new black cartridge? I mean, where does it go? jessicah@ripnet.com
Perhaps the Lexmark X1200 Series User's Guide will be able to help you. Download using this link: http://bit.ly/d2qaOa. Scroll to page 13 for instructions on how to replace the print cartridges.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source. Thanks.
Sep 29, 2010 | Lexmark X1240 All-In-One InkJet Printer
Color cartridge missing
You may want to remove the power brick at the back of your printer, wait a few seconds and reinsert back. Then try the steps listed in the user guide to install new carts, page 42.
http://www.lexmark.com/publications/pdfs/x5150/eng/ug.pdf
Jun 01, 2009 | Lexmark X5150 All-In-One InkJet Printer
How do I make the cartridge move to change position on Epson C44 Plus
To replace an ink cartridge using the maintenance button, follow these steps. Turn the printer on, the power light should be on and not flashing.
Open the printer cover. Press the maintenance button (ink-drop symbol). The print head moves to the black ink cartridge replacement position first. Press the maintenance button again to switch to the color cartridge replacement position.
The on-line user guide can be found here:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=FGQ8MBMpKlvPPGPcU002FJ8CcV1DwZfroADi&tc=5
Please take a moment to rate this solution, thanks.
Apr 17, 2009 | Office Equipment & Supplies
Correctly fitting ink cartridge/pring head relign?
Here is a link for the user's manual. It will tell you how to correctly insert the cartridges and do a print head alignment.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13368
Just look on the page for the user guide. If this is what you were looking for please rate a big 4 fix ya. Thanks. Need more help? Just post a comment and I'll be back to help you out.
Mar 25, 2008 | Canon PIXMA MP160 All-In-One Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
24 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
