Alert system battery voltage low (Beep Beep)
Battery was removed,taken to store,tested,found to be very dead,replaced with new one that was tested to make shure it was good.System still gives the same screen,same notice,same two short beeps on boot up,and now when i flip the switch on my surge protector the tower starts up without pressing ON button.What do you think?
  • 2 more comments
  • chuckosaurs May 15, 2008
    thank you will do all you said and get back to you.the new one was tested before install,it was 5x5.(good)
  • chuckosaurs May 19, 2008
    took batt. out,checked install, ( not upside down )checked batt. for power (good),raised up the little contacts at bottom of holder, replaced batt. booted up to find the same screen.(not miller time YET).
  • chuckosaurs May 21, 2008
    thanks, will try, how do i acc.the BIOS,please keep it simple, not expert (old guy) lol. But willing to try,thanks again.
  • chuckosaurs May 23, 2008
    ok will do and get back to you. THANKS; have a good one!
Just replace the old battery with new one and then go to setup and press alt+f and click on save changes and restart your pc ....all done....!
Posted on Jun 12, 2010
    Sergeant:
    Champion:
  • 326 Answers
Three possible:
1 does new battery test good?
2 is battery inserted properly (backwards)?
3 do U clean the battery holder with a pencil eraser?
Posted on May 12, 2008
  • Rory Biggs
    Rory Biggs May 19, 2008
    Older pc used the battery to retain bios information, but modern ps use the battery only for system date and time as the bios is written in e2prom. It sounds like there is a problem with U'r MB. As a last effort, go to the Bios and select default settings. Without repowering, reboot. Still problem or changed? The date & time should not change if not repowering. If time/date is troublesome repair shop may be able to repair MB.
  • Rory Biggs
    Rory Biggs May 21, 2008
    when U boot up there is a message on the black screen. normally it's F1 or F2 or ESC key to press. This will take U into BIOS. Some where on the title menu will be selections to preset for performance or default... select default.
    Scholar:
  • 143 Answers
Bigbiggs is correct. Also, most newer BIOS have an option that states to Start up (BOOT) or Not Start up (NOT BOOT) on power failure. Because the battery is not keeping BIOS settings, this may be reverted back to Start up when power is applied. Check BIOS settings when you get tha battery situation sorted out.
Posted on May 13, 2008
  • Eric Smale
    Eric Smale May 21, 2008
    Also, on a lot of BIOS, the DEL key will get you in. Just in case F1, F2 or ESC do not work for you.
I have a 2007 Honda Odyssey that has recently developed a battery problem. Old battery would be dead over night. Had the system tested at local parts house and found starter to be bad. Replaced with a...
You need to remove your positive connection at the battery first. Now you connect one end of test light to battery clamp, and the other to battery. Make sure they have good contact. Test light will light up anytime there is a draw. The brighter the light, the more draw there is. Start by removing one fuse at a time and watch for light to go out, or at least dim quite a bit, and leave it out & record which one it was. The ideal way to do it is to remove all fuses, making sure light is out completely, then start re-installing them and watch for one that light comes on bright. That will tell you which circuit is causing the excess draw. If you think that will get you in trouble, or confused, just pull one at a time and if no difference in light, put it back in. Just leave those that make light dimmer, out, making sure you note where they go. That way if you have 2 or 3 with slight draw, (like radio, clock etc.,) but 1 with big draw, then you can zero in on that circuit as the culprit. Take's a little time, but it works.
Mar 16, 2014 | Honda Odyssey Cars & Trucks
2006 Chevrolet Montana battery is dead almost every morning.
check for boot /glove box light not left on
check interior light no on
Dec 10, 2017 | Chevrolet Cars & Trucks
Dead battery, replaced battery and alternator but still no charge!
if its not charging while running at14.5 volts or so you have a charging problem mabey no power to the alternator if its charging at 14.5 or so and the batery load tests good and its going dead over night you have a draw from some component in the system.
Dec 19, 2011 | 1994 Oldsmobile Cutlass Ciera
2004 alero turn key car clicks but wont start
Dead battery. Try jump starting it. Then stop by any good parts store (Advance, Autozone, etc) and have them to a FREE charging system test and a FREE battery load test. I suspect your battery has left this planet...
Feb 27, 2011 | 2004 Oldsmobile Alero
Car makes a clicking sound when I try to start it. Battery has been changed, but not new. Will start when boosted. Have left the car running for an hour, turned it off and re-started it without problem,...
Have the battery tested or better yet get a new one.
Make sure the cable terminals are clean and free of any corrosion, that causes high resistance and could keep a good battery from starting your engine.
If the new battery goes dead in a day have the vehicle tested for a parasitic drain on the electrical system.
Oct 06, 2009 | 2000 Pontiac Grand Am GT
Battery keeps loosing charge- kymco cruiser 125, 2005
I had this exact same problem on a hipster 125, it was a faulty regulator module ( mounted under the seat) I also found a short circuit (somewhere) in the wiring loom between the regulator output and the chassis (probably what killed the regulator in the first place!) I cut and replaced the entire wire to save removing most of the loom and after testing reg to ensure it was dead i fitted a new one (about £60) bike charges and runs like a dream now even with fully lights approx 80% of the time. good luck
Jul 14, 2009 | 2005 Kymco Hipster 125
1994 Toyota Tercel Starter Problems
sounds to me that you have an igniton problem not a starter problem and or if you have or had an alarm system could be cause if u do give me feedback and i will explain but seems that your starter is fine from what u say but if you think in terms of the elemts to start a vehicle batery gives pwoer to ignition which sends to starter which gives spark etc i would check you ignition system something is causeing a short and not alowing starter to function
Feb 10, 2009 | 1995 Toyota Tercel
2 new batteries and something in my 98 skylark seems to drain
how is your alternator working. have this tested for free at you local part store, they will even take it off for you in some places and put it back on. Also most good autopart stores have the computer to test your system and give you a free diagnostic report so they can sell you the parts. good luck
tepfy
Feb 01, 2009 | 1998 Buick Skylark
Shure Wireless Mike no Output
Check the battery with a volt meter. If the battery measures lower than 8 volts on a volt meter, replace the battery. I have seen entire cases of brand new batteries that are defective. Make certain to check it with a volt meter. If the battery tests fine, then send the bodypack to Shure for repairs. www.shure.com/service
Dec 18, 2008 | Shure ULX1 Body-Pack Transmitter...
Something is draining my battery overnight already tested battery starter altenator cellinoid
This response contains troubleshooting procedures designed to locate the cause of an overnight power drain resulting in a dead battery, It assumes the charging system is working.
The first (and easiest) test I run is on the battery.
When you are done using it for the evening, pull the Negative battery cable.
In the morning, re-connect it. If it's dead again, the battery need replacement. This does not necessarily mean you found the problem.
If it starts, the battery is ok. It's time to look for the power drain.
With the ignition off, ensure the systems that should be off actually are off. For example: does the radio still come on? Wipers? Etc.?
In the same vein, has anything new been installed lately?
The next test is a lot more tedious. You will need a test light, needle nose pliers (to pull fuses) and the proper tools to remove the negative battery terminal (again).
  • Ignition off
  • Remove the cable from the Negative battery terminal
  • Hook one end of your test light to the Negative battery post
  • Attach the other end to the cable you just removed
  • Again, double check connections to recent installations (radio, GPS, etc)
  • If it lights up very faintly, this is likely the normal drain of the clock. The brighter the light, the bigger the drain.
  • Find your fuse box
  • While keeping an eye on the test light, pull the fuses one by one. Replace the one just pulled before going to the next.
  • When the light goes out (or dims), you will have narrowed the the problem to a specific system. Check the legend on the fuse box for the offending fuse.
At this point there are too many 'What if's'. Which system has the drain will determine the next steps to be taken.
This procedure will allow you to focus in on the problem area. Let me know what you find out.
Hope this helps
Mike
If you found this helpful, please take a sec and rate this response. Thanks.
Jul 24, 2008 | 2002 Ford SVT Focus
Computers & Internet Logo
758 people viewed this question
David Payne
David Payne
