Question about LG Televison & Video
My LG LD450 television will not go on. the red standby light goes slowly on and off. No picture on the screen. TV is 6 weeks old. Is it out of order?
  • 5 Answers
SOURCE: LG LCD 37'' standby problem
if you want i will buy the tv from you
Posted on Feb 23, 2009
  • 8457 Answers
SOURCE: Thomson 32WZ610s television stays in standby
It the power inverter supply board 90% of the times.Very comon with LCD tv's design flaws in power inverter boards.Many,not all use the
same designs.
Posted on Aug 24, 2009
SOURCE: lg 50pq3000-za plasma tv will not switch on from
power problem possible fried power capacitors
possible cause power surge could occur if unplug while tv on
must change 6 power capacitors
these original capacitors are on the low end minimal ratings
1-2 hours in house labor, cost est $200 plus minus
Posted on Jul 09, 2010
toolkits
  • 1099 Answers
SOURCE: sharp lc32d44ebk stuck on standby
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck and hope this helpout....
Posted on Aug 03, 2010
  • 3 Answers
SOURCE: Hello, My LG suddenly stopped turning
Change capacitors. The 1000mf, 680mf, 470mf ones (your monitor should have totally 5 or six of them. When you open the case you'll see the bad capacitors ready to burst on the top. Change with same capacity. No problem if you replace 16V with 25V capacitors -> "Equal capacity in mf, equal or bigger voltage"
Posted on Mar 01, 2011
LG 32LC56
that problem is usually cause of faulty T-con board..
Aug 25, 2012 | LG Televison & Video
LG 32LC56 back light on no picture
hello..
That problem is usually cause of bad t-con board..
just replace it to fix the issue..
Aug 25, 2012 | Vizio L32 32 in. LCD HDTV
I have a new LG 32 LD450 TV. When the set is on, there is a green light in lower right. when set is off there is a red light in lower right. should this red light be there all the time, even when set if...
The red light means it's on standby mode but if you wish to turn off the red light you can just go to menu >option>power then choose standby light off.
Jan 08, 2011 | LG 42LH40 LCD TV
Lg 50pq3000-za plasma tv will not switch on from main button on the bottom of the tv and from standby it clicks and the red light comes and goes and nothing happens its only a few weeks old..
Jun 06, 2010 | LG 50PQ30 50 in. Plasma HDTV
Color was bad couldn't adjust it better , then last week red curvy lines showed up on the bottom om screen . opened the back and found 6 adjustment knobs slowly turned one and screen went dark. repowered...
sorry but those adjustment are not the right one , to correct the color problem u have frist , u need to hire a tv tech , tv would has to adjust the screen and focus back to normal after that , need to replace the oil on green and blue picture tube
Apr 12, 2010 | Philips Magnavox 9P6034C 60" Rear...
Power/standby led beeps red light 6 times
crazyford359
Your Thermal fuse is out. I just replaced mine, the part is only $4.85 on Sonyparts.com. Ordered (2)
Feb 16, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
LG 19 LH 2000 no picture or sound
i have exactly the same problem and my tv is just 2 weeks old !!
any soloutions?
Nov 21, 2009 | LG 19LH20 19 in. LCD HDTV
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Televison & Video Logo
120 people viewed this question
Computer Repairing
Computer Repairing
