When I push the start button, more and more often I get a clicking sound. After about 6 clicks, the warning sounds. Sometimes I can fix this by wiggling wires under the machine, but I can't figure out which one is working. Sometimes it just solves itself. Most annoying!
Problem is most likely the control bd remove the top cover ..3 screws along back edge..try wiggling the connectors along front of control usualy the pink connectors there is a connection problem on the board itself new control will fix problem ..have tried to shim connectors in position but doesn't hold very long
My delay in thanking you for this solution is due to the vexing nature of the problem, intermittent. Your solution worked worked! That was, after I found the correct socket and driver, etc. Thanks so much! I love this washer, but it has its little annoying features.
