Question about Dell XPS M1330 13.3" Tuxedo Black Laptop Computer. Sleek, Sophicated, and Truly Portable Laptop. Int... PC Notebook
Sir i was working on xps m1330 and suddenly it turs off .i tried to boot again but no responce no led light no video and when i plug the ac adapter its led light turns off
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 146 Answers
It seems to be a power section problem. You need to visit the service centre.
Posted on Sep 04, 2010
Dell Xps M1330 New motherboard failure.
When you removed or put in the CPU and the Heat Sink did you put a fresh coat of Thermal Paste on them? If not that is like metal touching metal and it will short out when you try to boot up.
The other problem might be that either one of your memory chips is bad or one of the slots on the board that holds the memory is bad.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
May 31, 2012 | Dell XPS M1330 Notebook
New motherboard still no power
Remove the main battery and try again, next sub out the ram one at a time and test, I would sub out the power supply to be sure it is basically the only thing left.
May 07, 2012 | Dell XPS M1330 Notebook
My Dell xps m1330 won't power on , the light on the power supply is on until I plug it into the laptop an try to turn it on, then the power supply light goes out.
try removing the battery, plug the ac adapter, check if it turns on. if not it may be the ac adapter/motherboard might be bad.
Feb 14, 2010 | Dell XPS M1330 Notebook
XPS M1330 is dead, no lights and complete silence.
can you put a volt meter across the ends of the power - where it plugs into the laptop
should have 18-22 volts same as written on the PSU
I think the pSU has blowen
Nov 11, 2009 | Dell XPS M1330 Notebook
Dell XPS M1330 doesn't recognize original power cord after 2 yrs
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 09, 2009 | Dell XPS M1330 Notebook
My dell m1330 laptop says that no batterey can be detected when a batterey i attached at the back of the laptop . anyone know a solution??
You either have a bad battery or the connector on the motherboard is bad. Have you tried another battery? Try doing a power drain.
Remove the battery and the AC connector, hold down the power button for 10 sec. Plug the AC connector back in and boot up your machine. Once it's fully booted then shut it down and plug the battery back in and try that out.
Aug 03, 2009 | Dell XPS M1330 Notebook
Xps m1330 doesnt work?
Remove the battery, and unplug to turn it completely off. then plug everything back in and restart if you still have a black screen it could be your LCD going out. which is a very expensive replacement part.
Feb 16, 2009 | Dell XPS M1330 Notebook
Dell XPS M1330 13.3" Tuxedo Black Laptop Computer. Sleek, Sophicated, and Truly Portable Laptop. Int... PC Notebook Logo
153 people viewed this question
Alun Cox
