Question about Harman Kardon CDR2 2-Disc CD Recorder
Have broken headphone plug left in headphone jack. Need to remove but can access the plug. Faceplate won't come off and disc drive screws have been removed but won't come out. Something holding it. What to do?
  • 158 Answers
I usually use a dental poking type tool and go in from behind in a gap in the middle and push it straight out--the tool must be thin yet strong
Posted on Sep 04, 2010
Yamaha CP 300 broken headphone jack
Some keyboards use the amp output sockets for headphone use.
You might need some adapters for your headphones.
If it fell in, you would see an empty hole. This would be unlikely because it is held on by two screws. If all fails, buy an amp with a headphone jack input. Plug the keyboard into the amp and use the amps jack.
Dec 15, 2011 | Yamaha CP300 Stage Digital Piano...
My left earpiece in my sentry headphones have no sound. How do I fix this?
Check the plug - it might have a broken wire, by wiggling it in the jack. It could be the jack as well - try another headphone in the jack.
Nov 08, 2010 | Sentry HO900 Headphones
Want to remove my hard disc... but.. I can get to and remove the 2 screws on the "inside" of the drive.. but.. the two screws next to the case are so close to the case I can't get to them. Am I missing...
The hard drive is secured to the frame and this frame needs to be removed to get access to all the screws holding the hard drive to the frame. The frame may have screws holding it to the case or accessed from the front of the computer after you remove the front faceplate panel.
Sep 25, 2010 | Gateway 510 X PC Desktop
Beringer xenyx 1204 repair
OFTEN the broken part CAN BE RETREIVED without removing the faceplate. There are MANY knobs and screws to remove to get at the jack AND then, the jack is mostly sealed and one cannot get into the innards of the jack.
I want you to try a few things before tearing into the unit. Here are ideas to try, not necessarily in prefered order as I can't see your unit and the broken part.
1. Take a very thin sheet metal screw and try to drive it GENTLY into the broken adapter. OFTEN you can snag the thing and drag it out.
2. Take a sewing machine needle and STAB the plastic insulator of the broken part and attempt to drag it out.
3. Attempt to epoxy glue a small dowel to the broken part. Use minimual glue so it doesn't squish out to the sides of the jack.
4. If the broken part is iron, try using a small rare earth magnet to **** the thing out.
5. If enough of the broken part is near the surface, attempt to solder a wire to it to use to extract the broken part.
6. Using a sewing machine needle and a soldering iron, melt the needle into the plastic insulator of the broken part.
I am sure one of these suggestions will work. The jacks themselves are sealed all the way around and you would have to unsolder the jack from the board. You would either replace the jack, or drill a hole in the bottom of some of them to be able to push out the broken part. All of this internal type work has risk to the unit if you are not equiped to do the work. If you can snag the thing with the above suggestions it will be quicker and safer.
Nov 28, 2009 | Behringer Music
Plays only thru one speaker or one headphone one side just wont play
Sounds like your headphone jack is messed up you can get replacement parts and a repair guide for this at ifixit.com. the website is www.ifixit.com ... they do show you step by step the process of removing the faceplate and where all the screws are at on the ipod. I took mine apart to replace the hard drive ... It was very helpful. the replacement parts are more reasonable than you would think ... hope this helps
Oct 18, 2009 | Apple iPod classic MP3 Player
Jack plug broken off
Buy a $4.00 1/8" jack replacement from Radio Shack - part # 274-0869, which has small screw connectors that don't need soldering.
Strip about 1" of the braided insulation at the old jack end, which will expose 4 very small wires: Blue, Green, Red, Copper.
Attach the Green & Copper wires to the tallest pin on the replacement jack.
Attach the Red to the shortest pin, and the Blue to the medium pin.
Remember to slide the jack cover onto the headphone cord before attaching any wires!
This works great, I just did it.
May 14, 2009 | Skull Candy Lowrider Headphones
2 discs stuck in console
WOW!!! I am so sorry that this happened. Nintendo products are really hard to open. If you cant wedge the game out with a small screwdriver, dont worry about the game, here are the directions on opening it. Just copy and paste to word so you can see the whole thing easily.
How to open your Wii Console Step by Step Instructions
To disassemble:
  1. Flip the device upside down and remove the small silver Phillips screw. Once out, remove the battery tray from the console.
  2. Next remove the rubber foot directly above this battery tray. Also remove the three square white stickers from the bottom of the Wii. The rubber foot and the sticker are covering hidden screws. Figure 3 provides a shot of where these screws are located. NOTE
    Hiding screws under stickers and rubber pads is a common method used by electronics manufactures to help increase the aesthetics of their devices, as well as prevent people from easily locating screws and taking apart their products.
  3. Unscrew the two Triwing screws and three Phillips screws from the bottom of the Wii.
Figure 3 - Bottom Screws
  1. Flip the Wii over onto its right side. Locate and remove the two rear rubber feet and the two rectangle stickers near the faceplate.
  2. Remove the two silver Triwing screws in the holes and remove the two black Triwing screws on the faceplate (Figure 4).
Figure 4 - Left side screw locations
  1. Flip the Wii upright and carefully remove the two socket covers. They come right out with a little wiggling.
  2. Remove the three black Phillips screws from the black plate (Figure 5). Note the one closest to the faceplate is the longest and will need to go back into that hole when putting the Wii back together.
Figure 5 - Top black plate screw locations
  1. With the screws removed, carefully pull off the faceplate of the front of the Wii. You will need to disconnect the red/black wire plug from the Wii to remove the faceplate completely. Figure 6 shows what is hiding under the faceplate.
wiifig06.jpg Figure 6 - Under the Wii faceplate
  1. Remove black plate from memory/controller socket area.
Remove two silver Phillips and two silver Triwing screws from memory/controller socket area (Figure 7). wiifig07.jpg Figure 7 - Topside screw locations
Lay the Wii on left side (with the ATI and Nintendo logo facing you) and slowly work the right side cover of the console off the device.
This will take a little bit of force. If something appears to be stuck, double check to ensure you removed all the screws.
Locate and remove four screws holding DVD reader in place. Two are located in plain site in the middle of the unit. Two are located near the front of the Wii inside the DVD unit (Figure 8). wiifig08.jpg Figure 8 - The insides of the Wii
Slowly tilt the DVD player upward toward top of Wii. There are two wires that need to be disconnected before you can safely remove the DVD unit. One is a plug type of connector that only requires a little tug. The other is a circuit strip connector that requires you to lift the brown catch, which will release the pressure holding the strip in place (Figure 9). Do not break this!
May 11, 2009 | Nintendo Wii Console
Amilo Pro V2035 - Broken Headphone Jack Stuck inside Headphone socket
Also remove the battery and any other removeable plates below the notebook to check for additional screws. Check if there are any rubberized "feet" or plugs covering access to still more screws. Keep screws and their locations organized in case they are different length.
Aug 12, 2008 | Fujitsu AMILO Pro V1000 Notebook
Headphone jack broken speakers wont work
Yes, since the Headphone pin is stuck in the Jack, you are not getting audio from Speakers.
You should have noticed that connecting the headphones to the Jack will block the audio coming from the Speakers and the same is the current situation.
You can either try removing the blocked part using a Tweaser or get it repaired.
Jul 31, 2008 | HP Pavilion dv9000z Notebook
Looking for a schematic diagram
It would be less trouble to disable the internal speakers from the television's setup menu and connect to a set of powered speakers or a receiver using the built-in audio outputs. It will be a challenge to get good sound quality and levels from the headphone jack.
Apr 26, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Harman Kardon CDR2 2-Disc CD Recorder Logo
44 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
