Question about TurboChef TORNADO Electric Oven
My oven is showing F6 EC TEMP on the screen how do I fix it? Please let me know.
    Scholar:
  • 75 Answers
F6: EC (Electrical Compartment) Temperature High
Fault is displayed when the EC thermocouple
exceeds 158?F (70?C). It is monitored once per
minute.
The electrical compartment is overheating. Remove the panel on the right side and clean out all the dust. Check the fan at the back and see if its blowing alot of air. Sometimes this fan can get so clogged up with dirt, it slows down the air flow.
Posted on Nov 01, 2010
What means code F6
I believe f6 ec temp is your code. That means the electrical compartment is getting to hot. Most common is the fan on the back of the oven is weak and not moving the air fast enough. Also the electrical compartment could be loaded with dust.
Dec 11, 2013 | TurboChef TORNADO Electric Oven
My toaster showing f5 mag temp and it only toast for 6 seconds then stops any ideas???
assuming its been fixed by now.
thermal-couples on mags trigger at 160F i believe.. forces shutdown for safety.
possible causes..several
mag fan working?
EC fan working?
mag cooling fins packed with dust?
wave guides full of crud causing arching?
mag tip burnt?
faulty mag thermal-couple, unlikely
Nov 07, 2012 | TurboChef TORNADO Electric Oven
Hi i have turbochef speed oven in subway and on display show F6 ec Temp . what is problem
F6 faults occured when temperature reached to 150 degree faharanite in the electrical compartment.
Solutions
1. Clean the dust in the electrical compartment.
2. There is an temperature sensor on the controle board which gets dirty and throw wrong values.Clean it and then try.
3. Check the exaust fan in the top rear location is working properly.
4.Check for proper air ventillation.
Apr 15, 2011 | TurboChef TORNADO Electric Oven
My general electric stove oven does not turn on.. code come out f7 and 5 6..what does t mean
F4
or
F5 Humidity sensor open or shorted Replace humidity sensor. F6 Shorted temperature probe This code will occur if temp. probe is detected as shorted continuously over 5 seconds. Replace temperature probe. F6 Shorted temperature probe This code will occur if temp. probe is detected as shorted continuously over 5 seconds. Replace temperature probe.
Nov 06, 2010 | Ovens
Tornado ngc oven has an F6 code. IR heats up to 1160 degrees but never says ready
unplug oven. Discharge Caps- if you don't know how to do this stop here and call a professional.
push the small red reset switch rear lower corner of oven. IR is a little higher than i like to see.
Test electrical compartment thermal-couple. located under top cover about 2 inches from the rear in center.
Test Electrical compartment cooling fan.
EC Thermocouple (P/N 700-1199)
Type K Thermocouple. Thermocouple measures the
temperature of the electrical compartment. If the
temperature within the electrical compartment is
above 158?F (70?C), the control displays F6: EC
TEMP. The control board checks the EC temperature
every 60 seconds.
Oct 26, 2010 | TurboChef TORNADO Electric Oven
ERROR CODE F6
F6 error code relates to the power board excessive temperature,this points to the cooling fan situated on top of the oven unit being faulty.
You already said it was noisy which is most certainly coo;ing fan.
Hope this helps.
Apr 16, 2010 | AEG CB8920-1-M Electric Single Oven
ERROR F6
HI, the reason for the non responsive control is being caused by a major fault within the control circuits. the entire control board will need to be replaced. it has failed at this point.
Replacing the Oven control board will solve this issue.
Jul 19, 2009 | Ovens
E2 F6 ??? What the? Oven came with house, no manual.
Your oven temperature sensor has failed(e-2) as well as your electronic control board(f-6). The oven temp sensor, electronic control board and the touchpad must be replaced . Approximate cost of parts is $500.00. Before you decide what to do, check the thermal fuse at the control panel first. If blown, replace it and the temp sensor. If you are lucky the control board may still be good.
Jun 12, 2009 | Whirlpool RBD305PD Electric Double Oven
F5 - Mag Temp
Hi. this is a control fault. the board has lost the ability to communicate its commands to the temp relay. the sensor is also not working. Due to this malfunction, the control board cant regulate the temperature correctly and you will have to replace the board and temp sensor and relay in order to restore this oven to optimal performance.
Please rate and god bless:)
Apr 03, 2009 | TurboChef TORNADO Electric Oven
Turbo chef oven F6 ec code
Hello. There is a temperature sensor built into the control board, and the temp in that area, is getting too hot. On the back of the unit, right top, there is a cooling fan that comes on at a certain temperature, if the intake is clogged, you will get this error, clean the intake. Inside the unit may be so dirty, it may require cleaning as well. The fan itself could be bad, and does not run, then it will need replacement.
Hope that helps, and thank you.
Feb 04, 2009 | TurboChef TORNADO Electric Oven
TurboChef TORNADO Electric Oven Logo
275 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Shehu Pro
Shehu Pro
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
