Question about Kenmore Refrigerators
Our kennmore side by side referigerator bought two years ago seems to have lot of ice in the freezer compartment. there is ice formed over the vents in the referigerator side and things (milk) is getting bad in 2 days,
  • Kenmore Master
  • 2,699 Answers
Is the ice on the back wall or was the door left open?also send the model number,you'll find it in the fridge side on the right hand wall up near the ceiling,it will start with like 106. or similar
Posted on Sep 04, 2010
We have a GE side-by-side refrigerator (GSS23QGTA); it's about 6 or 7 years old and has been working just fine until about a month ago when we noticed that the freezer was not freezing food. The temp had...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 16, 2011 | Refrigerators
The bottom freezer portion of my gladiator freezerator forms ice
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Nov 09, 2009 | Gladiator Freezerator Top Freezer...
GE GSS25WGMCC, Ice Forming On Freezer Interior Surfaces
i had the same problem and i replaced the defrost heater and it worked fine for about one month but now having the same issue. Most of the time from what I have heard it is the defrost heater (about $60 part). I might have another issue going on with mine like a defrost thermostat. Your defrost heater is right under the panel on the inside of the freezer section. remove white panel on back side of freezer section and remove two screws and two wires and replace it and you should be fine.
Apr 15, 2009 | GE Refrigerators
Sears Coldspot 17 frostless freezer not defrosting
One reason for the fan running is that it is trying to distribute the air in the compartment. Look at the very rear of the freezer on the bottom and see if the little vents, which allow water to disperse, are not filled with frozen ice. If so, turn off the fridge (unplug it) and use a hair dryer to melt that ice until it is all gone. That will probably fill the condensation pan under the unit and you'll need to empty it.
Feb 01, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice forming on condenser copper tubing GE referigerator
is your drain line plugged up under that coil? another thing to check is if the door asket pinched that wold allow ait to infiltrate into the freeze and freeze up the coil. remember to clean under the unit once a year to keep the unit working properly and not having to struggle to condense the refrigerant. Hopt this solution's work for you and have a Happy New Year.
Jan 05, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Freezer compartment accumulating snowy ice
sounds like an air leak. the ref. is sucking air in and condensing and freezing on that spot. check the gaskets really good.
Jul 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Flat ice forms at the bottom of the freezer compartment
check your freezer door see if it (ajar) what you can do if you can unplug unit clar drain with hot water then get apiece of shave wire hook on the defrost heater and put in drain line 1/8 in the drain line put back wall back together and plug unit in
Apr 07, 2008 | GE Profile 21.6 cu. ft. Side-by-Side...
Fresh Food Compartment not cold enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 08, 2007 | GE Profile PSS26NGS Side by Side...
Refrigerators Logo
69 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
