Question about Sony Cyber-shot DSC-W70 Digital Camera
The camera dsc-w120 is having problems. When you turn it on the lens zooms in and out then stays out but the picture part says turn the power off and on again and won't take the picture! When I turn it off and on then it just repeats the process . Please help I'm on vacation
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 146 Answers
Check the memory card.Format it.and replug it.
Posted on Sep 04, 2010
Sony Cyber Shot DSC-W120 My camera has been dropped, whilst the lens was out. When I turn the camera on now, the lens goes in an out several times and on the display it says "Turn the power off and on...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Oct 29, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
Sony cybershot dsc-w120 lens goes crazy whenever I turn it on and tells me to turn it off.
The camera should go off automatically when faulty. attempt to explore teh functions on the camera is discover the unique experience beyond power shut down requests. When powered on, capture a snap shot immediately or else the camera takes charge to poweroff to save batteries. Also, attempt to power charge since the insufficeient battery does not allow the camera to stay on long.
Jan 29, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
My sony dsc w120 digital camera registers only blank picture when clicked with the flash on. Any idea what could be the problem? thanks in advance.
The problem is in the lens housing, the shutter is closed and not working because the motor that runs it has seized, or the gears have jammed. The only solution is bring it to a camera technician to see if he can repair the lens.
Jan 16, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
Sony camera wont take pictures
It is problem of lens mechanism that does not send initialize signal to system control chip and camera tries 3 times for that then give up so that error message comes in result.
Replace lens assembly to fix the problem.
Local camera repair shop will help you to replace it.
Thanks.
Jun 13, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
Possible Duo Pro issue?
duo pro stick failed not to be used
Mar 01, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
My Sony Cyber-Shot DSC-W120 Super Steady Shot zoom won't work!
Follow this procedure to troubleshoot if the zoom function does not operate.
NOTES:
  • The zoom function will not operate with some AE modes.
  • The zoom function is not available while shooting a movie on all cameras. Refer to the owner's manual for information regarding the functions available on the camera. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  1. Change the Auto Exposure (AE) mode on the camera.
  2. Ensure the camera is not set for movie mode.
  3. If the camera has a conversion lens setting in the menu, set it of OFF.
  4. Reset the camera back to factory settings. To reset the Camera, please select Initialize under Settings and Main Settings 1.
NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required .
Sep 20, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
My Sony Cybershot DSC-W120 Super steady shot Camera won't turn on
I have the same problem, but when I remove the MS Pro Duo card (1GB) from the camera it works fine again. The memory card works fine in a pc memory card reader. Is there a problem with the Sony camera built-in card reader?
Aug 21, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Everytime i open the camera flash the screen always turn off and turn on again,but we did not use to take the picture,
Hi, This erroe is related to optical lens, Actueally the slide motor start malfunctioning of the zoom lens this is why the error shows"turn of the power and on again". The remady of this problem is that you have to replace the optical block assymbly.For this please contact any nearest SONY SERVICE CENTRE or contact any parts store and get the optical blok assy Part No. Description A-1512-913-A LSV-1250A (SERVICE) One more thing to add here that if you want to need replacement of lens block on component level then you must contact SONY SEVICE CENTRE.This will reduce the cost of repair. Thanks for using fixya.
Jun 04, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
