Question about Hotpoint Washing Machines
Cant find filter on washing machine hotpoint wt965
SOURCE: pump filter blocked
Actually it was quite easy, unplug from mains lie it down on its back and unscrew the 4 screws around the filter/pump it will then come out enough for you access it easier, unplug the connection which has 2 black wires from the pump and unscrew the 3 torx screws which will then separate the pump from the filter and anything stuck inside will fall out before reassembly make sure the impeller is not damaged on the pump if it is you may have to replace the pump I'm told is quite cheap to replace, reassemble and away you go. Whole job only took me a couple of hours and saved me a fortune.
Posted on Dec 28, 2008
  • 135 Answers
SOURCE: i cant find my filter
It is either behind the kick plate at the front or in the pipe on the bottom of the drum which runs to the pump.
This is acessed by removing the panel at the back.
Hope this helps & thankyou for using Fixya.
Posted on Jan 19, 2009
amgm
  • 32 Answers
SOURCE: can you remove hotpoint bwm 12 washing machine filter
Hi, yes it is. Hotpoint bwm12 is a built-in washing machine, the filter is located at the bottom (black round knob). Undo the filter by turning it to the left (please be sure there's no water inside the machine, or getas much as possible out before opening the filter).
Cheers
Posted on Feb 19, 2009
  • 197 Answers
SOURCE: hotpoint 1600 wt965 washing machine it has f-18 error message
Not good news - need to book an engineer, F18 is
Communication error the main module could be at fault (PCB)
This is located byhind the switches under the top, don't attempt to have a look though
Posted on Oct 25, 2009
  • 118 Answers
SOURCE: i have a hotpoint ultima washing machine wt965 and
F05 - Pressure switch jammed on full - Check pump for blackages. Also resetting the machine sometimes solves the problem switch off at plug for 5 mins then switch back on and try again. hop this helped
Posted on Sep 27, 2010
Leaking hotpoint ultima washing machine
Hotpoint ultima wt965 washing machine This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 16, 2012 | Hotpoint Washing Machines
Hotpoint WT965 is making a loud noise when spinnig
Suspect bearings. With door open wiggle the top of the silver drum If it moves up and down inside the tub, replace the bearings
May 15, 2012 | Washing Machines
I have a hotpoint ultima washing machine wt965 and the display is flashing f-05
Sep 26, 2010 | Hotpoint Ultima WF865 Front Load Washer
My washine machine is displaying code f-01 the make is hotpoint wt965
f01 isa indicator of motor problems. If it were my unit, I would unplug machine for several hours to see if problems are corrected. If not, I would inspect wiring going to motor for corrosion
Nov 05, 2009 | Washing Machines
Hotpoint 1600 wt965 washing machine it has f-18 error message
Oct 25, 2009 | Washing Machines
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Jan 18, 2009 | Hotpoint Ultima WD72 Front Load...
Test on display cant use washer
turn the machine on while you press the start and on buttons at the same time until dOFF appears.
Dec 17, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint WT965 ultima fault code F05
I have a ultima WMD940 won't drain and comes up code F05. Please can you help my washing is piling up
Aug 27, 2008 | Washing Machines
Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
you have a blocked filter, unplug from mains, take off back panel you will see a black sump hose coming from the tub to the pump, tilt the machine forward and put a dish or bowl under sump unscrew clamp and pull off slowly to release any water in the drum. You will find a blockage, also what appears to be a ping pong ball dont throw away it is meant to be there.
Mar 06, 2008 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
523 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
