On screen show osd lock.pl.send solution. - Computers & Internet
  • 570 Answers
Here is the solution for your problem,
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
1.If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
2.If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Thanks.
Have a great day.
Posted on Sep 04, 2010
Control locked how can i unlock it?
To unlock the On Screen Display (OSD) lock, hold down the menu button for 20 seconds until OSD unlocked shows on the screen.
Please rate my answer if this helps,
Chris
Mar 03, 2011 | LG Flatron F700B 17" CRT Monitor
"OSD LOCKED" box on my screen
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
Can not stop monitor from truning on then off. then it says osd locked.
OSD Lock
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for 10 seconds.
plz do rate the solution if helped
Nov 22, 2010 | HP L1506 15" LCD Monitor
My monitor says the OSD is locked I can't unlock it
  • If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
  • If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD
Or else you can try this method also, Hold the menu/ok button for ten seconds, to unlock the OSD. If this doesn't solve the problem, then it's probably the button that got stuck. Remove the casing, locate the menu button's contact switch on the circuit board, and try to release it using something thin like a screwdriver, x-acto knife, or set of plyers.If this doesn't work, chances are the menu button is stuck on a loop, sending a continuous signal to the board (which keeps locking/unlocking the OSD).
If so, your only solution (other than take it to a repair shop) is to remove it, by prying it off with a screwdriver or set of plyers. Of course, you'll lose access to the OSD features, but I guess this is better than to have a message stuck on front of your screen all the time..
May 18, 2010 | LG 22" FLATRON LCD Monitor
Show "OSD Locked".in that cause i-Menu is not working. what i do?
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD. Source(s): http://h10025.www1.hp.com/ewfrf/wc/docum…
May 15, 2010 | Computers & Internet
How can i unlocked the menu of my philips lcd monitor i70t4?? pls help me i cant configure the settings of the brightness and everything..
Question My monitor shows the message: OSD MAIN CONTROLS LOCKED. What can be the cause of this message? Answer To unlock the OSD Controls press the “MENU(OK)” button for more than 10 seconds while there is video input from PC.
User manual, support, FAQ: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=190B6CS/00&slg=en&scy=GB
Apr 27, 2010 | Philips 190B6CB/27 19" LCD
Problem in TFT
  • If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Jun 09, 2008 | LG L1915S 19" LCD Monitor
Osd problem
Did you try factory reset? If not, you should do it.
Mar 15, 2008 | Liquid Video L17LCD2 17" Flat Panel LCD...
Computers & Internet Logo
183 people viewed this question
David Payne
David Payne
