Question about Acer Aspire One AOA150-1570 Notebook PC
Hi, my acer aspire one though is on, its screen "dead"
  • 25 Answers
If your Aspire One will not start and you get a black screen, IT IS NOT DEAD, hopefully! It has a problem booting.
Here is the procedure posted some time ago by a guy call Macles. His blog page seems to have 'disappeared'. I have revived my AOA150/ZG5 a number of times using this procedure.
Although the Aspire One is a bit old now I am posting this here in the hope someone with this problem will find it and fix their Aspire One. You need to read the instructions carefully.
Acer Aspire One BIOS Recovery
The Acer Aspire One has a built-in BIOS recovery routine, which can boot into a minimal BIOS environment via a special boot block to re-flash the BIOS, even if the system does not pass POST and does otherwise not boot anymore. This procedure is also known as Crisis Disk.
First format an USB flash drive with FAT. It does not need to be bootable.
Download the latest BIOS, and extract all files. Put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the flash drive. The files must not be in a folder. Rename the BIOS file to ZG5IA32.FD before proceeding. It only works with this exact filename.
Turn the AA1 off, and verify both battery and AC adapter are plugged in.
Press Fn and Esc simultaneously, keep them pressed and press the power button. Release Fn+Esc after a few seconds. The power button starts blinking at this point. Press it once. The AA1 will now access the files on the flash drive and initiate flashing the BIOS. After a while the power button stops blinking, and the AA1 reboots by itself. Wait patiently.
If it doesn't reboot, but keeps blinking, wait at least a few minutes before turning it off, and try again.
The bios is available here :-
http://global-download.acer.com/GDFiles/BIOS/BIOS/BIOS_Acer_3310_A_AOA110%20&%20AOA150.zip?acerid=633850493862245097&Step1=NETBOOK,%20CHROMEBOOK&Step2=ASPIRE%20ONE&Step3=AOA150&OS=ALL&LC=en&BC=ACER&SC=EMEA_27#_ga=1.14312051.514957353.1425219603
Posted on Mar 01, 2015
For future viewers, as this is over a year-old issue and the original poster has probably already solved his/her problem. I'd like to point out that Acer Aspire One AOA150 used LED backlight and so it has no need for high voltage inverter. I'd personally suspect the screen to be faulty or the display cable having lost its connection, or if the device seems completely dead (no indicator LED activity, no hard disc sounds etc) that the BIOS needs reprogramming. Acer Aspire One ZG5's (including this model) are known to seem completely dead, but they are recoverable through a BIOS reprogramming procedure with a USB memory stick. This is well documented on various web sites and Youtube so I won't go into detail here.
Posted on Feb 27, 2012
  • Guest Starr Feb 27, 2012
  • 2,567 Answers
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Posted on Sep 06, 2010
Acer 4552 dead screen
hi,
check lcd cable
replaced lcd panel
Apr 06, 2014 | Acer Aspire 4552 Series Laptop Power AC...
I am trying to set up Wi-Fi from my acer notebook to my new stereo, could you please send me a network sercuity key
hi there!
The Acer Aspire One is a miniature laptop that includes many of the same features larger laptops have. The Acer Aspire One is about the size of a diary and features an 8.9-inch LED LCD display, an 84-key keyboard, two built-in stereo speakers and Wi-Fi capability. Though smaller than most laptops, the Aspire One functions much like other computers. The Aspire One uses the Windows operating system, so it connects to a wireless network the same way that any other Windows computer does.
Instructions
  1. Click the "Start" menu in the bottom left corner of the screen.
  2. Click the "Connect To" option from the menu that appears. The "Connect to a network" screen will appear.
  3. Click on one of the networks listed on this screen to select it.
  4. Click "Connect" at the bottom of the window. You now have set up a wireless connection on your Acer Aspire One.
The network security must be established by you.
Hope it helps,
fossildude
Nov 09, 2010 | Acer Aspire One Netbook 8.9" Notebook
How to change screen bulb for Acer Aspire 1642zwlmi
I am assuming you are referring to the "back light tube"? If so they are easy to change however rarely the issue. Most likely your lcd screen is dead. Here is a step by step:
http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Mar 28, 2010 | Acer Aspire 1642WLMi Notebook
I can turn on my Aspire One, but nothing on the screen is dead
You need to flash your BIOS back to standard. Full details of how to do this can be found here:
http://macles.blogspot.com/2008/08/acer-aspire-one-bios-recovery.html
Hope this helps!
Jul 10, 2009 | Acer Aspire One PC Notebook
Screen stays black when powered on
I replaced my screen on my 5570z, i purchased it off of ebay for 130.00 shipped, but make sure you check out there feedback, and make sure they have a ZERO dead pixel return policy. Some are sneaky and will not let you return it if you have less than 3 dead pixels.
May 17, 2009 | Acer Aspire 3680-2022 PC Notebook
Hi, I have recieved a used laptop from a friend.It is an Acer Aspire 1690LCi ZL3. The unit powers on,battery is good,DVD drive opens but the screen is dead.Please help. Sam
A few things to try. First turn on the unit, and after it seems to have booted up (like at a windows login or something), take a flashlight and in a darkened room shine it on the screen. If you can see a picture, it means your backlight is out. Go on ebay or elsewhere online and look for an acer aspire 1690LCi backlight. Then open up your screen and replace it (there should be tutorials online for this). If you don't see an image, your screen maybe be out or have more serious problems (video card, LCD dead, etc.).
May 04, 2009 | Acer Aspire 1690 Notebook
Hi,when i switch my acer aspire 5100 on,it boots up but the monitor(screen)does not come on
Is your monitor turned on? If so, then you likely have a dead monitor. Try plugging a different monitor into your computer and see if it works. Then get a new monitor.
Good Luck!
Feb 20, 2009 | Acer Aspire 5100 Notebook
Booting
Press the FN F5 screen to see if you can toggle the screen on. If you have a external monitor plug it in to the notebook and see if you have video. If it show in the external monitor your LCD screen has gone out.
I hope this helps.
Feb 19, 2009 | Acer Aspire One PC Notebook
Acer ASpire laptop
sounds like its trying to load windows but the harddrive is failing to respond, most of the time if it loads everything up to the windows itself its all done before initalizing the harddrive itself.. try putting the harddrive into another computer or usb external to check if its dead.. you might just need a new one =T not 100% sure though but its worth trying.
Jul 28, 2008 | Acer Aspire 5100 Notebook
Open Questions:
See all Acer Aspire One AOA150-1570 Notebook PC Questions
Acer Aspire One AOA150-1570 Notebook PC Logo
187 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
