Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
After the engine runs and warms up for about 5 minutes the engine dies and won't restart until the engine is cold. any ideas?
Engine will die after warmed up
depends on what you mean by "warmed up". If you mean engine reaches normal working temprature and works normally then cuts out , but restarts wwithin 5 minutes and then carries on working normally until it cuts out again, and then restarts withing minutes...have the throttle position sensor checked. It may be that you have a warning code on the dash?
It might be the pedal position sensor alternatively.
If your engine works ok until fully warmed up this may be the problem.
If there are any symptoms before the cut out happens can you please add the details and repost thwe query
Oct 26, 2015 | Cars & Trucks
1991 F350 w/460 cu starts but runs rough until warm.
sounds like auto matic choke problem try a manual choke
Jan 02, 2014 | Cars & Trucks
No check engine, stalls cold start, dies after warm
If you haven't done it already you might have them run it for codes to see if it is showing any. Autozone does it for free too.
Dec 23, 2013 | Hyundai Santa Fe Cars & Trucks
1998tarus starts when engine is cold, won't restart when engine is warm, nothing, no clicking
sounds like either the starter solenoid is dying or a bad connection at the battery
Jan 28, 2012 | 1998 Ford Taurus
Jeep liberty 2002 3.7when starting cold starts-stalls unitl hot
Check the temperature sensor feeding the ECU and O2 sensor.
Apr 12, 2010 | 2002 Jeep Liberty
Sounds like it's going to die until it warms up...
Katrina, the fact that your car runs (like a beauty) when shes warmed up, indicates a fuel air mixture problem when cold. Your car is equipt with electronic fuel injection. This system utilizes a series of sensors that detect conditions such as engine temp, outside temp, humidity and air pressure to determine what mixture is perfect for the prevailing condition. For example, on a cold start, the sensors should know that the engine is not up to the proper operating temperature and provide more fuel and less air, (a richer mixture), until the engine warms, this emulates a choke on a vehicle equipt with a carburator. The problem either lies in the sensor itself, or the brain that interprets these inputs to decide what fuel/air mixture to deliver.
Sep 18, 2009 | 2001 Mazda Tribute
Runs 5 minutes then dies. Won't start until engine is cold.
Try the WD-40 spray in intake of throttle body with air intake hose off, to see if it will kick at all, even for a second or 2. We need to confirm whether your losing fuel or spark when it dies. Ignition & fuel, can cause similar symptoms in this case.
Apr 12, 2009 | 1990 Acura Integra Hatchback
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
