Question about Ricoh Aficio MP 2000 Black and White Copier
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
  • 5 Answers
Sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Posted on Sep 06, 2010
Testimonial: "Sir, Thank you so much for your help, let me try in my copier and revert back once the problem is solved. Thanks Gopalkrishna T N"
    New Friend:
My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 101
Posted on Nov 18, 2010
SOURCE:
RICOH MP4500 SC 390 DISPLAYS WHAT TO DO
Hello.
That error is related to TD sensor error.
I advise you to call a trained Technician
Mar 16, 2015 | Ricoh Savin Lanier Genuine Toner Type Mp...
The Ricoh Mp 2000 copier displays "Error occured Sc:545 Functional problem"
It's a fuser overheat error enter service mode to clear, if it comes back service call ( push in sequence clear modes(yellow) 1 0 7 hold down stop for 5 or so seconds, screen will change, power down, red switch. -Carl
Jan 30, 2014 | Ricoh Aficio MP 2000 Black and White...
Our Gestetner MP 2000Le have an error sc551 and we can't troubleshoot it using the (Clear mode+107+hold the Clear/stop button) ..can you pls. advice us for other options ? tnx
Enter in the service mode: Clear(yellow key) 107 press/hold Clear/Stop more 4 second,enter in the SP mode open the front cover ,turn OFF the copier,wait 1-2 minutes close the front cover and turn ON the copier.
Jan 30, 2013 | Ricoh Aficio MP 2000 Black and White...
Error occured SC:302 Functional Problem Turn main power switch off and on if the error appears again. Call Service
SC:302
Charge roller current leak
Symptom: A current leak signal for the charge roller is detected.
Possible Cause:
?? Charge roller damaged
?? High voltage supply board defective
?? Poor connection of the PCU
May 27, 2011 | Ricoh Aficio MP 1600L Black and White...
How to reset MP161 Ricio
The Ricoh Aficio MP 161 LN give error code - SC 302
Please adivse
Nov 21, 2010 | Ricoh Aficio MP 161 Black and White Copier
Functional problem sc 302 in ricoh photocopier model aticio1600
the charge roller in the drum unit is faulty or need to be cleaned.strip the drum unit and clean the unit
Sep 06, 2010 | Ricoh Aficio MP 1600 Black and White...
Functional Problem SC 302
SC 302 has to do with you charge corona wire.  It's unrelated to the toner spill.  It could be a bad conora wire.  Sometimes it's the power supply.  There could be a lot of troubleshooting and repair to do on this one, you might want to contact a dealer in your area since the have the right tools for the right job.
Sep 30, 2008 | Ricoh Aficio 1013F Copier
Ricoh Aficio MP 2000 Black and White Copier Logo
3,543 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
