Question about Insignia IS-LCDTV32 32 in. Television
TV won't turn on
Our Visco 32" LCDHDTV turns on, but no picture -- like it is in sleep mode. How do we get it to turn on with picture and sound? Thanks.
  • 5 more comments
  • Anonymous May 31, 2008
    Mine will not turn on either 600$ paper weight.
  • bjck01 Jun 04, 2008
    red light blinks light changes blue but never turns on..my tv is less than 2 weeks old...
  • Anonymous Jun 05, 2008
    My problem is more like the one beneath this one. The red light comes on, which is tv-off indicator, but the blue light does not come on that is usually on when the tv is on or running. I've had the tv a little over a year. No problems until it popped off in the middle of viewing and would not come back on. Please post your solution.(cdotcarter1@yahoo.com)
  • cdot1 Jun 05, 2008
    My problem is the same as bjck01: the red light comes on but the blue light that indicates the tv is on does not. The tv won't come on. My tv is a little over a year old. If I'd just bought it I would return it to the store and get a Samsung, Sharp or Sony. I've had no problems before today when it popped off in the middle of viewing. Please post your solution. BestBuy wants $100 just to come out.
  • Roxanne Robertson Mar 11, 2009
    I have sound but no picture, I have a Visco, which some say is no good. Ijust want to fix it if possible.
  • devariojay Mar 20, 2009
    I have a similar problem.
    My Visco 32 inch LCD TV usually works fine, until I started using the VGA port.
    The voltages on the VGA must have done something to the tv because even regular channels started losing sound. I would have to turn it off via the plug and restart it to get it to work properly.
    Recently it actually got fuzzy and distorted on the VGA.
    Seeing as how I was using it as a computer monitor...this was very upsetting. Now the TV lost all responsiveness. It would work but nothing would respond. U pulled the plug put as always, which usually fixes the problem, but then it never turned back on.
    The red light didn't even turn on. I just unplugged the VGA cord and all the others cords and im going to reposition the power cord in a little bit to see if it works. Again.
  • bpd607 May 01, 2009
    Ive had my Visco for almost 2 years now and never have had any problems. Has a great picture but poor sound quality but I also have surround so its not a problem. But last I turned it on and the red light went to blue and nothing happened. I can't shut it off it just does nothing. It use to make a weird sound when you turned it on too, almost like a video game and I just relised it hasn't done that in quite a while. It usually makes the speakers pop if I have my amp turned on with the volume too loud. No longer does that either, which I never understood why it did in the first place. Anyway I'm sure it needs a new board or something expensive. Just wondered if any of you have found solutions and what they ended up costing you. Currently the local electronic store that apparently is the only place that repairs tv's here in town wants $75 dollars up front to even look at it. Anyone have the manufacturers website? That would help me too.
    Thanks!
    Brian
I called an electronics repair person who said he thinks a panel has gone bad and can replace it. I'll let you know if it works.
Posted on Jun 01, 2008
These tvs are no good its was waste of my money but thats what u get when u try and go the cheap way out.
Posted on May 31, 2008
I have a VISCO 32' tv & lost the remote. Model # VSC-32V1. I need a remote to use to get to the HDMI area. I tried a universal but it only turns it on & does channel.
Check the operation manual and note down the model number and go and fetch it from any electronics shop nearby. These are available freely now in the market.
Jul 19, 2012 | Televison & Video
I have a Sharp 32"
try checking the system for timer or sleep mode operation try to setting it off
Jul 16, 2011 | Sharp 25R-S100 25" TV
Im using my tv as a monitor, when i turn on my music and then leave the computer to do chores, the computer goes to no signal and i cant listen to my music, how do i keep it from doing this?
Sounds like either your computer is in hibernation mode or your TV is set to sleep, what type of connection to your computer are you using? I do believe in this model Vizio there is a sleep option on each of the Video sources. But I would guess its your computer going into either sleep mode or in your running windows 7 Hybrid sleep mode.
Jul 02, 2011 | Vizio L32 32 in. LCD HDTV
Hi I have a VISCO Flat screen tv MOdel#VSC-32v3 we turn tv on and the orange light is on but no picture does the tv need reset
The orange light typically indicates that it has not detected a video signal. Using your remote, or the front panel buttons, try changing the input source to a known working input. Make sure that your cable from your receiver / dvd player / etc hasn't come loose.
Feb 13, 2011 | Insignia IS-LCDTV32 32 in. Television
Phillips lcd 32 inch(PFL-3403) tv picture is going off after 10- to 15 minutes of working since 26.01.2011.
Check whether timer is ON mode or OFF. If it is ON set it to OFF mode.
Check whether sleep after 15 mins is after
set it to NEVER or OFF mode(sleep means if you won't change any channel or iuf you din't did any thing for 10 it will goes to sleep mode..... and again you have to turn it ON)
Thank you
Jan 27, 2011 | Philips Televison & Video
We have a 32" Visco LCD TV (about 5 yrs old), we have sound but have no picture. I tried the service desk but can no longer find Visco help anywhere. A company that sells parts directed me to your web...
I can only sggest you go back to your supplier to seek advice. They should hopefully know where a company that supports this set will be.
Sorry.
Oct 22, 2010 | Televison & Video
Cineplus tv, loud popping sound, no picture? Warranty co. gone!
having a hard time turning on my Cineplus LC-32R25C
Cineplus 32” High Definition LCD Television...when i hit the power button..thered light on tv goes to yellow..as it it was in sleep mode..and i dont know wat to do to get it out of that state to turn it on..is there a sequense of buttons on the remote i gotta push to get it to work?
Sep 13, 2009 | Televison & Video
No picture
IF YOU NEED MORE INFORMATION ABOUT THIS MODEL
VISIT
www.tv-solutions.redtienda.net
Aug 07, 2008 | Zenith R40W46 40" Rear Projection...
Sleep
If you unplug the unit for an hour or overnight, it should go out of sleep mode. If this dosent work then its not in sleep mode and the set has a problem in the power supply or the sweep circuit. Sorry you should seek a pro to assist you in this repair. Good Luck
Jun 30, 2006 | Sylvania SRT2232S 32" TV
Insignia IS-LCDTV32 32 in. Television Logo
499 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
