Question about Canon Office Equipment & Supplies
How to install canon clc 2620 onto network switched on, conected to network switch/router loaded drivers to a computer on network
suben
  • 214 Answers
SOURCE: how do i install my printer onto my new computer if i lost the CD
download the driver from canon.com
Posted on Dec 04, 2008
SOURCE: File needed: Printer driver INF for EDOX CLC 1150_Canoncolor
I believe the CLC1150 is a copier only, not a printer.
Posted on Apr 18, 2008
Soulvisitor
  • 1113 Answers
SOURCE: Cannon printer problems
53d292c.jpg Are you talking about one of these.. if so, get up walk over to it and read display, it is offline, out of paper, needs toner, off paper size missmatch or somethin
Posted on Dec 17, 2008
  • 1602 Answers
SOURCE: canon clc 900 Error E020
go on line type in
canon printer error e020 and look at all the ideas to help you fix your problems
rod
Posted on Feb 03, 2009
spinal
  • 287 Answers
SOURCE: error E00020-01b0
Hi. This code means that the device has detected a problem with the yellow drum assemly. USUALLY you merely need to replace the yellow drum.However, when the device does a self check, the first color looked at is yellow. So in the event you have a larger problem, an error code for yellow would be the first the device would notice.I hope you understand my point. But I'd say you have a 95% chance of success if you replace the yellow drum assembly which is quick,easy and relatively cheap. I hope this helps and good luck!!! :-)
Posted on Apr 03, 2010
How to connect canon clc 1150 to my pc
just install the driver then use the usb cable to connect the same.
Sep 26, 2012 | Canon CLC 1150 Color Copier
I keep getting the error message E004-00002 ( Set off and on again) everytime I put on my Canon CLC 1000. Pleaae
Switch off machine From Mains & take out plug. Open the m/c from backside & clean all 8 contacts of four drum heater conections (Carbon contacts) . Put on the m/c & reset E000 From service mode.
Sep 12, 2011 | Canon CLC 1120 Color Copier
My computer will conect to the internet on wireless but not on hardwire conection what should i do
It can be several problems.
1. Driver of wired network adapter is not properly installed. Try reinstalling the driver. 2. Your LAN wire is defective. Try a different wire. 3. If you are using a router or switch. There might be a problem with it. Check that. 4. Your wired network settings is not properly setup. Try resetting it to default.
Feb 13, 2011 | HP Compaq Presario V2000 Notebook
We can not install it as a network printer. it is conected to our router but we can not fint it in our network. how can we intsll it to work properly?
its very simple.just connect the copier to the router.Now put the printer driver cd in the one of the computer which is also connected to same switch or router.Install the driver or software or printer. and you gotchha. if after installation the problem presits try adding a printer in a control panel. you can contact me on amrinder@techtweaks.in
Dec 28, 2010 | Canon imageRUNNER 5000 Copier
Canon clc 1100 series printer requires login and password but not
Go to the driver properties and check device settings tab to see if job accounting is enabled. Un-check if not used.
Jun 16, 2010 | Canon Office Equipment & Supplies
I have 3 color copy machines irc3200n,clc 2620 all the machines
the cause of the problem is ,the transfer belt is not rotating properly ITB rollers must cleaned throroughly (cleaned by isopropyl alcohol) to prevent slippage of transfer belt that causes mis alignment /misregistration of color,but copying BW is ok,In other words ITB unit needs servicing ,Run also gradation adjust QUICK and FULL adjust (for IRC 3200)
Aug 04, 2009 | Canon Office Equipment & Supplies
Making a Canon Imagerunner 400S a network printer
connect network cable from the machine to the switch or router, and give ur machine ip address compitable with ur network, then load the driver on ur computer and u will be fine.
Jul 06, 2009 | Canon imageRUNNER 400S Copier
Canon clc 1110 gives E 803 0000 error. What could be the solution ?
the 24v is faulty
the dc power cut relay is faulty
the dc pcb is faulty the dc driver pcb faulty
during copy operation the cpu does not detect 24v out put for 5 seconds when the transfer unit lever switch,front cover switch,and delivery cover switch is closed
May 17, 2009 | Canon CLC 1110 Copier
Booting problems with Canon CLC 1150 Copier
The copier itself doesnt have a hard drive. Since you are talking about Fiery I assume you mean the colorpass RIP attached to the copier. A CD with the software on it actually came with the RIP but it was probably swiped by the dealer. In any case it needs a SCSI CDROM in order to load it. But all is not lost. The hard drive actually keeps a backup of the software on the hard drive itself. Kinda like a system restore partition on some computers. When you switch it on hold down the top right button until the diagnostics pass. then press "restore backup". this will take quite some time. Once it is done you will have to go back into setup mode and re-enter all the network settings. Dont forget the default paper size.
Apr 28, 2008 | Canon CLC 1150 Color Copier
Mar 26, 2008 | Canon CLC 1150 Color Copier
242 people viewed this question
old marine
old marine
