Question about 1ST DOWN SHOP COLUMBUS BLUE JACKETS 20pk AREAGYM CARPETRUG FLOOR TILES
I have an ARCAN LL35 (3.5 ton) floor jack. It will not hold a load. I put fuild in it and the lift will go up but it is not strong enough to lift the car. No fluid is leaking. Is there an adjustment to be made? If so what is it? Thanks, Peter
I too have this same problem. I noticed that 1 of the 2 plungers that the handle compresses is stuck in the down position.
Posted on May 10, 2014
  • Tanner Cerny
    Tanner Cerny Jul 22, 2016
    what did you do to fix it? mine is doing the same thing
How to remove oilpan on 97 firebird 3.8 liter
The Engine needs to be lifted up 5" so the pan can be slid out around the crossmember.
Nov 07, 2013 | 2000 Pontiac Firebird - 3.8 L V6, with...
What is a jack lift?
"A jack lift is a mechanical device used as a lifting device to lift heavy loads or apply great forces. Jacks employ a screw thread or hydraulic cylinder to apply very high linear forces.
A mechanical jack is a device which lifts heavy equipment. The most common form is a car jack, floor jack or garage jack which lifts vehicles so that maintenance can be performed.
More powerful jacks use hydraulic power to provide more lift over greater distances. Mechanical jacks are usually rated for a maximum lifting capacity (for example, 1.5 tons or 3 tons)." (Wikipedia)
Oct 07, 2013 | Hoisting
What size floor jack do I need for a 1987 toyota camry?
Any roll away floor jack from a autoparts store will be fine and strong enough
Mar 04, 2013 | 1987 Toyota Camry
Owners manual for arcan ll35 floor jack
Here is the phone number 1-800-879-7316 they are now owned by sunextools.com Costco no longer carries any jacks.
Feb 28, 2013 | Cars & Trucks
How do I safely lift the front end of a 2000 chrysler concorde with a floor jack?
first, I would use jack on one side of car then put it on jack stands, then go and jack other side up and put it on jack stands, just the way I would do it
Oct 04, 2012 | 2000 Chrysler Concorde
How does a floor jack work
Place jack under what you want lifted and close valve and put rod in jacker and jack up till your height is good,to let down turn valve counterclock wise.
Sep 13, 2012 | Automotive HEAVYDUTY Hydraulic Bottle Jack...
How do i replace my starter for my 1992 Lincoln Town Car?
First disconnect battery. Use a floor jack to lift vehcile from passenger side. Use floor jack to help hold up car for safety. The starter will be located ton the passenger side. It is held by two bolts. There will be one wire to a 10 mm nut. remove. There will be a couple of wires in cluding one from the baterry to a big bolt remove the nut. Remove the two bolts being careful as starter may drop. You can use the floor jack to help you since the floor jack is suppporting the vehicle. Reinstall in reverse.
Nov 17, 2009 | 1992 Lincoln Town Car
What Jack and stand to get for my '04 Ram 1500 Short Bed V6?
THE SAFEST CHOICE IS THE 3 TON.. YOU COULD GO WITH THE 2 OR 2.5 TON, BUT WITH THE SIZE OF YOUR TRUCK YOU NEED THE 3 TON..REMEBER TO ALWAYS USE THE JACK STANDS..GOOD LUCK KEITH...
Mar 14, 2009 | 2004 Dodge Ram 1500
Sears 4 Ton Hydraulic Automotive Floor Jack-Will Not Lift ?
I have a Sears 1 1/2 ton floor jack. I was able to buy a repair kit from Astro Pneumatic Tool Company 372 OLD U.S. Hwy 52 South Mount Airy N,C 27030-8093
1-800-221-9705
John
Sep 27, 2008 | Plumbing
1ST DOWN SHOP COLUMBUS BLUE JACKETS 20pk AREAGYM CARPETRUG FLOOR TILES Logo
1,106 people viewed this question
Top 1ST DOWN SHOP Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a 1ST DOWN SHOP Exercise and Fitnes Expert? Answer questions, earn points and help others
