Question about Avanti W789SA Top Load Washer
Where can I buy plastic magic filter for Avanti washing machine model w751sc?
5 Suggested Answers
  • 1294 Answers
SOURCE: washing machine
Possible your outlet filter is blocked, find it and clean out. Look into yr users' manual
Posted on Sep 15, 2007
  • 1314 Answers
SOURCE: Avanti W851 Top Load Washer, Self Cleaning Lint Filter
they should be able to order one from any appliance pars store but if not contact avainti here ive worked for them for years most of the time if you contact them they might send you one if not they will get you one http://www.avantiproducts.com/
Posted on Jan 30, 2008
  • 3741 Answers
SOURCE: My washing machine turns on but wont rinse my clothes
If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Posted on Aug 20, 2009
  • 109 Answers
SOURCE: replace chuck absorber
why would you want to absorb chuck anyway shirley says hes a good guy lol
Posted on Jul 28, 2010
My washing machine avanti model no w798ssbelt is not broken but why is not spinning plz help. Thanks??
perhaps the motor or control board has failed . only a tech that can lay hands on can really assist you
Feb 06, 2017 | Avanti Washing Machines
I have the Avanti washer machine model w797 and I tried to remove my hose water filters and the plastic piece to remove them broke. How can I now remove the filters and what do I replace them with?
If they are not threaded, punch a hole in the screen and hook it with something and pull it out. You might have to buy a cheap screw driver and bend it into sort of a hook. If that doesn't work, try cutting the filter gently with a small box knife and pulling out the debri with small needle nose pliers.
May 24, 2016 | Avanti Washing Machines
Buzzing when pumping out water
This will probably be something rattling inside the pump chamber, unplug the appliance, unscrew the filter and there will probably be some plastic or other debris in the filter or wrapped on the impeller
Apr 09, 2014 | Avanti Washing Machines
Replace chuck absorber
Jul 28, 2010 | Avanti W1092F Front Load Washer
Washing machine not rensing well
there is a magic clean filter on bottom of basket. it has been removed from newer models because it builtup **** and never cleaned itself. need to remove agitator and basket to clean tub and remove plastic filter from bottom of basket. special tool required for basket
Mar 14, 2009 | Washing Machines
Avanti W789SA Water valve problem
Where do you live.I know some chenese guys who sell the spare parts.
Dec 14, 2008 | Avanti W789SA Top Load Washer
Jan 30, 2008 | Avanti W851 Top Load Washer
Washing machine
Sep 08, 2007 | Washing Machines
Avanti W789SA Top Load Washer Logo
138 people viewed this question
Top Avanti Washing Machines Experts
Jim Thurston
venugopal durairajan
Kolbrun...
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
